Adney
Here's a detailed breakdown of the parameter configuration of XGIMI Horizon Pro to see if it's worth buying.
X-VUE 2.0:
XGIMI's unique X-VUE image processing engine system greatly improves the sharpness and fidelity of dynamic images.
MEMC Motion Compensation:
Thanks to MEMC image interpolation technology, XGIMI Horizon Pro benefits from ultra-low latency and minimal image blur. The 60Hz motion compensation technology developed by XGIMI uses special algorithms to prevent jitter and drag when projecting dynamic images.
HDR 10 and HLG:
Even in dark or backlit environments, XGIMI Horizon Pro uses HDR 10 technology to give you impressive contrasts. Horizon Pro is compatible with the Hybrid Log Gamma broadcast standard and provides Full HDR images no matter what video is being played.
Brightness Adaptation:
XGIMI Horizon Pro has a built-in optical sensor that uses extreme AI to detect and respond to objects in its own way, as well as to change the ambient light. Automatic brightness adjustment ensures that the image stays bright and colorful as ambient light levels change.
X-VUE 2.0:
HDR 10 and HLG:
