Samuel Miller
1. WiFi password should be at least 8 digits;
2. Restart the device and reconnect.
3. Check whether the WiFi name has special characters, change the router WiFi name and password to English/numeric type, and then try to connect;
4. Build a hot spot with your mobile phone to see whether the device can be connected and check whether it is the setting problem of your router at home; If the phone can connect to the hotspot, please update the router firmware or reset the router.
