Yoton vs AKIYO vs antmap Mini Projectors: A Comparison for PS5 and Xbox Compatibility
Bellmeister
Yoton Mini Projector​
AKIYO Mini Projector​
antmap Mini Projector​
YotonMiniProjector.jpg​
AKIYOMiniProjector.jpg​
antmapMiniProjector.jpg​
$39.99​
$47.49​
$59.49​
Home Cinema​
Indoor/Outdoor​
Mini Projector Y3, User Manual, Remote Control, Power Cable, HDMI Cable​
Projector Stand​
User Manual, Power Cord, Remote, HDMI Cable​
Resolution: Native 1280*720, supports Full HD 1080P
Brightness: 120 ANSI lumens
Dimensions: 13.72x10.92x5.84 cm
Weight: 420 grams
Projection Size: Up to 120 inches, optimal 30-100 inches
Optimal Projection Distance: 1.3 to 3 meters
Keystone Correction: ±15° vertical
Zoom Function: 50%
Connectivity: HDMI, USB, audio ports
Compatibility: PCs, TV boxes, Firesticks, PS5, Xbox, USB sticks, DVDs
WiFi/Bluetooth: Not supported
Connection Type: iOS Wired Direct Connection (requires Lightning/Type C to USB cable)
Connections: HDMI, USB, 3.5mm audio output
Compatibility: PC, Fire Stick, PS5
Warranty: 2-year
WiFi: 5G/2.4G dual-screen
Bluetooth: 5.2
Screen Casting: P2P direct connection, no WiFi required
Native Resolution: 1280*720P
Supported Resolution: Full HD 1080P
Brightness: 200 ANSI
Contrast Ratio: 2000:1
Dimensions: 5.35*4.33*2.28 in
Weight: 420 grams
Design: Portable, pocket-sized
Content Playback Note: Limited support for copyrighted videos; recommend using TV Stick for playback
Resolution: 1920*1080P Full HD
Brightness & Contrast Ratio: Excellent brightness, high dynamic contrast
Bluetooth: 5.1 with built-in 3W stereo speakers
WiFi: 2.4G and 5G dual connectivity
Projection Size: 35-200 inches
Projection Distance: 3.3-17 ft
Keystone Correction: 17°
Ports: USB, HDMI, micro USB, earphone, power input
Compatibility: iOS/Android devices, Amazon Fire TV Stick, DVD players, laptops, external speakers, PS4
Use Case: Indoor & outdoor movie watching
Unboxing Experience​
Yoton Mini Projector:​
The Yoton Mini Projector has a compact and portable design, making it a suitable choice for those looking for a mobile projection solution. Its sleek appearance makes it easy to integrate into various settings, whether at home or for outdoor events. While some users noted that it may accumulate dust, it still maintains an appealing aesthetic. Overall, the design is practical, allowing for easy transport and setup.
AKIYO Mini Projector:​
The AKIYO Mini Projector is surprisingly compact, about the size of a large watch box, making it highly portable and easy to store. It has a simple, unassuming design that doesn't take up much space, which is perfect for those who want a projector without the bulk of traditional models. The included tripod enhances its usability, allowing for stable setups whether on a table or mounted to the ceiling. Overall, it looks quite modern and fits well in any casual home setting.
antmap Mini Projector:​
The Antmap Mini Projector is impressively compact, resembling the size of a medium book, which makes it highly portable. Its design is sleek and user-friendly, making it easy to fit into any room without taking up much space. Many users appreciate its aesthetic appeal, noting that it can comfortably blend into various environments, whether set up for a movie night or as a tool for work presentations.
30 Inches - 100 Inches​
32 Inches - 120 Inches​
50 Inches - 200 Inches​
1 Meters - 4 Meters​
0.6 Meters - 4 Meters​
3.28 Feet - 17.06 Feet​
5000:1​
5000:1​
High​
1920 x 1080 Pixels​
1920*1080 Pixels​
1920 x 1080 Pixels​
1280 x 720​
1280 x 720​
1280 x 720​
5500 Lumen​
5500 Lumen​
LCD 3.0​
Not Specified​
The viewing experience with the Yoton Mini Projector can vary greatly depending on the ambient light conditions. Users reported that it performs well in dark environments, producing a clear and bright image, though the focus can sometimes be lacking, especially towards the edges. While it offers decent quality for casual viewing, it may not meet the expectations of those needing sharper focus for detailed work, such as sewing or art projects. The audio quality, on the other hand, has been a common concern, with many finding it too quiet even when connected to external speakers.
The viewing experience is notably impressive for a projector in this price range. Once the lights are dimmed, the picture quality becomes bright and clear, producing a decent 1080P output that works well for movie nights and presentations. While the image quality falters in brightly lit conditions, it shines in darker environments. Users reported occasional connectivity issues when streaming wirelessly, but the overall experience was enhanced when using direct HDMI connections. The digital zoom feature is helpful for adjusting the picture size, although some users noted that uneven leveling could affect image quality.
The viewing experience with the Antmap Mini Projector can vary significantly depending on the lighting conditions. While it performs excellently in dark or dimly lit rooms, viewers have noted that clarity diminishes in bright environments. Most users report that the picture quality is satisfactory, offering vibrant colors and sharp images, especially when projecting onto larger surfaces. Many enjoy using it for movie nights, stating that it creates a cinematic experience at home.
LCD 3.0 Tech, High bright, Max support 1080P, Mini size, Speakers​
Built-In Speaker, Portable, Two-way Bluetooth 5.2, Built-In Cooling System, WiFi Connection​
AVI/MP4/MKV/MOV/MPEG1/MPEG2/H.264/XVID​
AVC​
H.264 or H.265​
3 Watts​
3 Watts​
6000 Hours​
55000 Hours​
30000 Hours​
Button Control​
Button Control​
App​
Remote, Touch​
USB, HDMI​
Wireless​
iPhone, Fire TV Stick, PC, PS5, Android​
38 watts​
38 Watt-hours​
Mount Type​
Ceiling/Tripod/Floor/Wall/Tabletop Mount​
Tabletop Mount​
Tabletop Mount​
5.4"L x 4.3"W x 2.3"H​
5.35"L x 4.33"W x 2.28"H​
6.81"L x 5.47"W x 2.76"H​
Setting up the Yoton Mini Projector is generally straightforward, although some users experienced confusion initially, even when following the provided instructions. Many found that once they got the hang of the setup, it became a seamless process. However, a few users reported issues with HDMI connections, which added to the initial setup frustration. Despite these challenges, the projector is praised for its ability to connect with devices like an Amazon Fire Stick, enhancing its usability.
Setting up the AKIYO Mini Projector was straightforward for most users. Many appreciated the clear instructions provided in the manual, which made the initial setup quick and efficient. It supports multiple connection options, including HDMI and Bluetooth, which adds to its versatility. However, some users did face challenges with device compatibility, particularly with newer devices requiring adapters or specific ports. Once the right connections were made, the projector reliably produced a good image.
Setting up the Antmap Mini Projector is generally straightforward, with detailed instructions provided in the manual. Users have reported that it connects easily to various devices, including smartphones, tablets, and laptops, via WiFi and Bluetooth. However, some have encountered challenges with screen mirroring and HDMI connections, particularly when using certain streaming services. Despite these occasional hiccups, the overall ease of setup has been a highlight for many.
• Affordable price point.
• Compact and portable design.
• Good performance in dark settings.
• Easy to set up once familiar with the process.
• Acceptable image quality for casual viewing.
• USB compatibility for direct video playback.
• HDMI connection issues reported by multiple users.
• Audio quality is insufficient without external speakers.
• Limited focus sharpness, particularly at the edges.
• Problems with Netflix and Hulu streaming.
• Dust accumulation affecting image clarity.
• Customer support responsiveness is lacking.
The Yoton Mini Projector offers a decent value for its price, particularly for those who need a portable projection solution for casual use, like movie nights or presentations. While it has some commendable features, such as being easy to set up and having a good performance in low light, its limitations like audio quality, HDMI connection issues, and less-than-stellar customer support may lead potential buyers to consider their options carefully. Ultimately, while it serves its purpose for many users, it may not fully satisfy those seeking a high-quality, multi-functional projector for detailed tasks.
• Affordable price point with good picture quality.
• Straightforward setup with multiple connection options.
• Includes a tripod for added stability.
• Solid customer service experiences reported by users.
• Sound quality from built-in speakers is underwhelming.
• Compatibility issues with newer devices may arise.
• Occasional connectivity problems when streaming wirelessly.
• Picture may appear uneven if the projector isn't perfectly leveled.
The AKIYO Mini Projector offers a great balance between performance and affordability. It is ideal for casual use, such as movie nights or gaming, especially in low-light conditions. While there are some limitations, particularly with sound and connectivity, the overall value is commendable. Many users have expressed satisfaction with its performance, making it a solid choice for anyone looking to enjoy a projector experience without breaking the bank. The customer service appears to be a standout feature, adding to the overall positive impression of this product.
• Bright and vibrant image quality (400 ANSI lumens)
• Built-in WiFi and Bluetooth for easy connectivity
• User-friendly interface
• Good for indoor and outdoor use during low-light conditions
• Performance is subpar in bright lighting
• Audio quality is often deemed inadequate without external speakers
• Some users faced difficulties with screen sharing and HDMI connections
• Occasional issues with overheating or power supply
In summary, the Antmap Mini Projector offers impressive value for its price, delivering a solid performance for home entertainment and casual presentations. It stands out for its portability and connectivity features, making it a versatile choice for users who appreciate convenience. While there are some drawbacks, particularly concerning audio quality and performance in bright settings, the overall consensus is that it provides a satisfying viewing experience, especially for those who prioritize ease of use and flexibility in their projector needs.
AKIYO Mini Projector, First Impressions:
- At first, I had a tough time getting this projector to read my external drive and it kept shutting off when I plugged in a USB hub. After a full reboot, that issue was sorted. I grabbed some flash drives and formatted them to FAT32, which the projector liked. Now I can watch shows off a USB, but it’s picky about video file types. I’ll update after I hear back from support.
- Samsung Dex works great with the included HDMI cable. Just hook up your phone/tablet to a USB-C hub, then to HDMI.
- Like most budget projectors, it has some light artifacts.
- Bluetooth has a lag and there's no fix for audio offset.
- Digital zoom is handy, and focusing is pretty straightforward.
- Screen mirroring works fine with Android devices.
- Don’t expect much from the built-in speakers.
- Setup is easy peasy; I read the manual just in case.
- Bluetooth sound is decent, with some adjustments for Bass and Treble, but still a bit flat.
End of first impressions.
Second entry:
-Customer service is awesome!
Happy7User
So I got the AKIYO Mini Projector, but it was a dud. The company reached out and offered me a refund or a replacement, so I went with the upgrade for a birthday gift instead of Christmas. I haven't used it yet since the birthday's not here, but I'll update later. The customer service was solid, but the projector? Total letdown. It works for like 5 minutes before a dark spot appears and it shuts off. I've tried everything to fix it—cleaning, cooling down, even trying to not care—and nothing works. And it’s a pain to turn on too! Honestly, skip this if you want anything more than a quick peek at a picture or video.
Gizmoitus
Got the antmap Mini Projector for my boys—got two! Super easy to use. My 6-year-old can hook it up to his phone and Xbox, and he’s loving it. Totally recommend it, especially for the price!
AlrightMister
I got the Yoton Mini Projector to project a spooky Halloween video onto my sheer curtains and it’s awesome! Way better than my old bulky projector that needed a laptop. This little guy is super compact and I can just plug in a USB with the video. It barely takes up any space on my shelf and is super easy to set up each night. I was shocked at how bright it is for its size! Sure, it’s not as bright as a big projector with the lights on, but it does great in the dark. I’m using it to cover two windows about 4 feet apart, and it looks fantastic! The 720p resolution is perfect for what I need, and the keystone correction makes it easy to get the image just right. Love it!
fosterzar
The Yoton Mini Projector is surprisingly bright for its size; I can see it fine even with the living room curtains open. It looks great in the dark, but the sound is super quiet, even when I hooked it up to a soundbar at full blast—still hard to hear from about 15 feet away. No wireless options, but you can plug in a Firestick, which is a plus. Overall, it's kinda just okay.
