LouiseWinner
Panasonic recently released its first real wireless noise reduction earphones RZ-S500W and RZ-S300W without noise reduction function. The selling prices of RZ-S500W and RZ-S300W are 199 US dollars and 129 US dollars respectively. RZ-S500W earphone is equipped with 8mm driver unit, which has highly customizable active noise reduction (ANC) function. It can provide 50 levels of internal and external mixed noise reduction mode.
RZ-S500W earphone supports Bluetooth 5.0, and is compatible with Amazon Alexa, Siri and Google Assistant. In addition, the RZ-S500W cavity side integrated control sensor can quickly turn on / off the noise reduction function and switch the ambient sound mode.
In other aspects, RZ-S500W integrated MEMS noise reduction microphone supports beam shaped directional pickup technology, has a new antenna design developed by Panasonic, and supports IPx4 waterproof. In terms of endurance, the headset is equipped with 85mah lithium battery, which provides 6.5 hours of single charge endurance, and 19.5 hours with a charging bin (800MAH). In terms of appearance, RZ-S500W earphone is available in black and white. In terms of weight, the headset weighs 7g and the charging compartment weighs 45g.
Compared with RZ-S500W, RZ-S300W lacks the active noise reduction function and beamforming technology, and becomes a 6mm driver unit, which provides 7.5 hours of endurance. It can cooperate with the charging bin for up to 30 hours, and has a unique color - light green.
These two earphones were first displayed by Panasonic during the CES2020 in January, and they have been officially released recently and will be available in the near future.
