Skyworth A63 First Mini LED TV, is it good?
Cloud745
Skyworth A63 Mini LED TV is the flagship Mini LED TV at 288 GHz, featuring a 288Hz refresh rate, ADS XDR display, Mini LED backlight, and 4GB+64GB storage.
Skyworth A63 TV Appearance​
The Skyworth A63 MiniLED TV features a multi-faceted design with black and bronze gold color schemes. The bezel is near can not be seen and the size is up to 75 inches. Two triangle feet are supporting the TV firmly at the table. You can put a soundbar beyond the TV and get better sound effects.
Skyworth A63 TV Display​
Skyworth A63 MiniLED TV supports 99% DCI-P3 wide color gamut, 800nits peak brightness, △E≤0.8 color accuracy, and full-channel 144Hz display.
The Skyworth A63 is normally equipped with a 4K 144Hz display, with HSR turned on in order to achieve a 288Hz high-brush display with 800nits peak brightness, and the A63 also supports AMD FreeSync Premium Pro, so gaming players can have a great experience.
Skyworth A63 TV Sound​
This Skyworth A63 TV is fitted with 60W sound with Dolby Atmos 2.0 support, which is built with HiFi-grade hardware wool paper cone, combined with a voice coil magnetic circuit and 16 core silk membrane for rich bass. They all offer unparalleled strength in performance, creating an unparalleled immersive audio experience for users.
Skyworth A63 TV System​
Skyworth's A63 MiniLED TV is equipped with the Kukai system9 with a built-in V3 full-featured AI chip. This TV is Skyworth's first Mini LED TV, so let's expect more breakthroughs.
