Unboxing Experience
- 1.1.1 AKASO WT50 Mini Projector:
- 1.1.2 TMY Ultra Mini Projector:
- 1.1.3 Yaber T2 Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 AKASO WT50 Mini Projector:
- 1.3.2 TMY Ultra Mini Projector:
- 1.3.3 Yaber T2 Projector:
- 1.4 Features
1.5
- 1.5.1 AKASO WT50 Mini Projector:
- 1.5.2 TMY Ultra Mini Projector:
- 1.5.3 Yaber T2 Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | AKASO WT50 Mini Projector | TMY Ultra Mini Projector | Yaber T2 Projector |
Picture | |||
Reference Price | $269.99 | $149.99 | $339.99 |
Recommended Uses | Home Cinema, Gaming | Home Cinema, Gaming | Home Cinema |
Built-In Media | 360° rotatable support bracket, possibly others | Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit | T2 Projector( Dongle not included)(For any issues, feel free to reach us at: [email protected]), Power Cord, Projector Lens Cover, Remote, HDMI Cable |
Highlight | Super Portable Projector: Dimensions 5.7 x 3.15 x 0.79 inches, Weight 0.64 lbs, Built-in 5000mAh battery, Approximately 2 hours of projection. Clear and Bright Projection: DLP technology, Good sharpness without pixelation, Higher brightness, Rich color effects. Multiple Connectivity Options: Wireless screen mirroring (AirPlay, WiFi display, EShare, DLNA), Interfaces: USB, HDMI, Audio, Micro SD. Built-in Android 9.0 System: Supports over 3 million apps from Google Play Store, Note on copyright content restrictions. Convenient Control Options: Remote control, Touchscreen panel, Automatic keystone correction. | Dimensions: 3.82*3.42*1.33 in Weight: 0.53 lb Battery: 5000mAh, 3.5 hours playback Projection Technology: DLP Connectivity: 5G WiFi, HDMI, MicroSD, USB Audio: Bluetooth speaker compatibility Usage: Portable, on-the-go entertainment | Product Name: YABER T2 Outdoor Projector Battery Life: Up to 2.5 hours video playback, 18 hours audio Resolution: Native 1080P Brightness: 450 ANSI lumens Screen Size: Up to 120 inches diagonal Audio: JBL & Dolby Audio, 8W*2 speakers, 16W Hi-Fi stereo speaker capability Bluetooth: Two-way transmission, supports external Bluetooth speakers Throw Ratio: 1.25:1 Aspect Ratios: 4:3 and 16:9 Zoom: 50% Connectivity: WiFi 6, Bluetooth, Ethernet, HDMI, audio jacks, USB drive support App Features: NFC for quick connections, remote control via smartphone Support: 24/7 support, 6-month returns, 3-year repairs Streaming Options: Compatible with T2 Google TV dongle (sold separately) for Netflix and Disney+ |
Unboxing Experience
The projector has a sleek and compact design, roughly the size of a Samsung Note, making it highly portable and ideal for various uses. Its weight gives it a premium feel, and it fits easily into a backpack or luggage, which is a significant advantage for those on the go. The inclusion of a standard quarter-inch mounting screw allows for versatility with tripods, enhancing its functionality. Overall, I found the design to be well thought out and aesthetically pleasing, which adds to the excitement of using it.TMY Ultra Mini Projector:
From the moment I unboxed the TMY Ultra Mini Projector, I was struck by its sleek and compact design. The projector is small enough to fit in the palm of my hand, making it incredibly easy to transport. It has a modern aesthetic that blends well with any decor, making it an attractive addition to my tech collection. The lightweight nature of the device is perfect for those on the go, and I love how it can fit into my travel bag or even my purse.Yaber T2 Projector:
The Yaber T2 projector boasts a sleek and stylish design that stands out in any setting. Its compact size enhances portability, making it perfect for both home use and outdoor gatherings. The build quality feels sturdy and well-constructed, avoiding the cheap plastic feel that some projectors in this price range exhibit. From the moment I unboxed it, I was impressed with the overall aesthetic, which makes it an attractive addition to my tech collection.Display
Screen Size | 3E+1 Inches - 120 Inches | - | 40 Inches - 120 Inches |
Throw Distance | N/A - 13.78 Feet | 5 - 0.5 Meters | 3.63 Feet - 10.89 Feet |
Contrast Ratio | [Probably at least] 1000:1 | > 1000:1 | - |
Maximum Resolution | 1920 x 1080 | 360 x 640 Pixels | 1980 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 640 x 360 | 1920 x 1080 |
Brightness | 50 lumen | - | 450 Lumen |
Display Type | DLP | DLP | LED |
Picture Enhancement | DLP | DLP | Integrated image processing technology for enhanced sharpness and clarity |
Viewing Experience
The viewing experience has been predominantly positive, with the picture quality being notably sharp and bright, even in somewhat lit environments. I was able to project images for various activities, such as cookie decorating and watching movies, with impressive clarity. However, I did notice that the projector performs best in darker settings, and while it can project large images, it occasionally requires some tweaking for proper alignment. The internal speaker is decent, though I found it beneficial to connect external speakers for a richer audio experience.TMY Ultra Mini Projector:
The viewing experience with this projector has been impressive, especially considering its size. The image quality is vibrant and sharp, and while it's best in dim lighting, I found that it still performs well in ambient light. With a resolution that supports 1080P, it brings movies and presentations to life. The short throw feature allows for a larger projected image without needing to place the projector far away, making it a great option for small spaces. However, I did notice that the built-in speaker's volume could be quite low, so connecting a Bluetooth speaker is advisable for a more immersive experience.Yaber T2 Projector:
The viewing experience with the Yaber T2 has been nothing short of fantastic. The resolution, while not true 4K, is impressively detailed, allowing me to see every pore on the actor's face during films. Color reproduction is generally excellent, though it can depend on the broadcast quality. I found that watching higher-quality content like 4K programs resulted in vibrant colors, while some lower-quality streams fell short. The sound quality from the built-in stereo speakers is commendable, with clear dialogue and immersive background sounds, though I still prefer connecting to my external soundbar for optimal audio.Features
Other Features | Portable, Digital Keystone Correction, Lightweight, Built In Wi Fi, Short Throw | Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready | !!!CONTACT US ANYTIME : [email protected] ①Built-in Battery ② Sound by JBL ③Native 1080P ④ Sealed Optical Engine ⑤ Auto Focus ⑥Auto Keystone Correction ⑦Intelligent Screen Alignment ⑧Intelligent Obstacle Avoidance ⑨ HDMI CEC ⑩ WIFI 6,Built-In 8W*2 Speaker |
Video Encoding | MP4, AVC | MP4 | MP4 |
Lamp Wattage | - | - | 8 Watts |
LightSource Life | 30000 Hours | - | 20000 Hours |
Controller Type | Touchpad Control | Button Control | Remote Control, App Control |
Control Method | Touch | Remote | App, Remote |
Connectivity Technology | Wi-Fi, USB, HDMI, 3.5mm Jack | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | Wireless/Wired/Bluetooth/WiFi/HDMI/USB/3.5Audio |
Compatible Devices | Smartphone, Gaming Console, Laptop, USB device, HDMI device | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Smartphone, Speaker |
Wattage | - | 15 watts | 8 watts |
Mount Type | Tabletop Mount | Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount | Ceiling Mount/Floor Mount/Tabletop Mount/Wall Mount |
L x W x H | 5.71"L x 3.15"W x 0.79"H | 3.78"L x 3.38"W x 1.14"H | 11.41"L x 5.51"W x 11.4"H |
Setting up the projector was a breeze. I appreciated how easily it connected to my Wi-Fi and other devices, such as my phone and streaming devices like the FireStick. The packaging was impressive and ensured that the projector arrived in perfect condition. Although I encountered some initial confusion with the setup of certain apps, particularly the EShare app for remote functionality, I managed to get it working with a little patience. Overall, the system is user-friendly and efficient, catering well to both tech-savvy users and those less familiar with technology.TMY Ultra Mini Projector:
Setting up the projector was a breeze, thanks to its user-friendly interface. Whether you're a tech novice or a seasoned pro, you'll find that the straightforward controls get you up and running in no time. The projector offers multiple connectivity options, including Bluetooth, HDMI, and USB, allowing me to connect it with my laptop, smartphone, or streaming devices with ease. Although there was some initial frustration with casting from my iPhone due to copyright restrictions, using an Apple TV or Fire TV Stick provided a smooth experience.Yaber T2 Projector:
Setting up the Yaber T2 was incredibly straightforward; I appreciated how user-friendly the entire process was. The projector quickly connects with external devices like Fire TV sticks and Roku, enhancing its versatility. The auto-focus feature is a standout, automatically adjusting the image to ensure it remains sharp and clear. I was particularly impressed with the calibration circular graph that appeared when I used the focus feature, making fine-tuning a breeze.Conclusion
Pros:• Excellent portability and compact design
• Easy setup with quick Wi-Fi connection
• Sharp and bright picture quality
• Versatile for various uses, including art and entertainment
• Strong customer service support
• Battery life is shorter than expected, typically around an hour
• The remote control can be unresponsive at times
• Some apps, like Netflix, are problematic or unsupported
My overall impression of this projector is overwhelmingly positive. It has proven to be a valuable tool for my artistic endeavors, particularly for projects requiring precision like cookie decorating. While some technical issues, such as app support and battery life, were frustrating, the projector's outstanding picture quality and customer service have made up for these shortcomings. I would recommend this projector to anyone looking for a reliable, portable option for both artistic and entertainment purposes.
Pros:• Compact and portable design
• Easy setup with versatile connectivity options
• Impressive picture quality for its size
• Good battery life for short movies or presentations
• Great value for the price
• Need for frequent refocusing during warm-up
• Low volume from the built-in speaker
• Limited functionality with certain streaming apps without a separate device
Overall, the TMY Ultra Mini Projector has exceeded my expectations. It is perfect for personal use, whether I'm watching movies in my bedroom, sharing videos while camping, or giving presentations on the go. The combination of portability, ease of use, and image quality makes this projector a fantastic choice for anyone looking for a compact yet powerful device. I would wholeheartedly recommend it to friends and family who want a reliable and affordable projector solution.
Yaber T2 Projector:
Pros:• Excellent picture quality with good detail and color reproduction
• User-friendly setup with quick connections
• Impressive auto-focus feature for easy adjustments
• Sturdy build quality and attractive design
• Good audio quality from built-in speakers
• Highly portable with a battery mode
• Limited onboard apps and streaming functionality
• Color accuracy can be inconsistent with certain broadcasts
• Requires external devices for full streaming capabilities
• Some issues with brightness and color grading in bright environments
• Remote control may have durability issues
My overall impression of the Yaber T2 projector is largely positive. It combines impressive picture and audio quality with a stylish and portable design, making it suitable for various viewing scenarios. While there are some limitations regarding streaming functionality and color accuracy, I found the customer service to be outstanding and very responsive to my concerns. The projector is an excellent choice for anyone seeking a versatile and user-friendly option for both indoor and outdoor viewing experiences.
