Xmint
Which one is the best smart thermostat in 2020? Compared with traditional old-fashioned thermometers, smart thermostats in 2020 have gradually entered our lives. What is the smart thermostat, as the name implies, is a remote control that can be controlled remotely by mobile phone. The smart thermostat is to control the floor heating in the home through a mobile phone, and the home will feel like spring all seasons. There is no need to worry about forgetting to turn off the floor heating and wasting energy. Smart thermostat. Mobile phone remote control, think about whether it is very happy for living.
Best Smart Thermostat Recommendation in 2020
The Nest
The nest smart thermostat, many people have heard or even used it. The nest smart thermostat's design is compact and the operation is very simple. Its built-in motion detection can detect whether there is anyone and automatically turn off the heating and cooling system. It can also be controlled remotely through the App Every year can help you save a lot of energy and electricity costs. It has a "self-learning" function that will change as users' habits change. Can be compatible with Alexa voice assistant to control.
EchoBee4
EchoBee4 is the latest generation of Amazon ’s smart thermostat. At the same price, it is more cost-effective. Because it has built-in Alexa voice assistant, it can be directly controlled by voice, or use other voice assistant functions, and it is also compatible with Apple HomeKit and other models. Popular hub. Comes with a room sensor (you can also buy additional sensors), you can sense the temperature of different rooms and whether there are people to intelligently adjust.
EchoBee3
EchoBee3 has the above functions, but lacks the built-in Alexa voice assistant. If you already have an Echo at home, buying it will save a little. In addition, this version also supports Apple HomeKit.
The Nest
EchoBee4
EchoBee3
