Yes, you can. However, it should be noted that the interface of the TV box is an HDMI interface or a VGA interface, and then depends on whether the display supports an HDMI interface or a VGA interface. If they are all HDMI ports or VGA ports, just connect directly. If it is not the same, just buy the conversion interface.
