ClokoWe vs AKIYO vs NICPOW Mini Projectors: Which Offers Better WiFi and Zoom Features?
ClokoWe Mini Projector​
AKIYO Mini Projector​
NICPOW Mini Projector​
$69.99​
$55.99​
$49.99​
Home Cinema​
Indoor/Outdoor​
Outdoor or indoor​
1 * Lens Cover, 1 * Remote Control, 1 * HDMI Cable, 1 * Power Supply, 1 * M8 Mini projector​
Projector Stand​
1 x NICPOW Projector,1 x HDMI Cable 1 x 3 inches (approx. 2.5 x 7.6 cm) AV Cable,1 x Power Supply ,1 x User Manual,1 x Remote Control, 1 x Tripod​
Model: 2024 Mini Projector
Brightness: 9000 Lux
Resolution: 1080P Full HD
Recommended Display Size: 60-100 inches (30-180 inches supported)
Dimensions: 6.74 x 5.28 x 2.96 inches
Weight: 0.72 kg
Connectivity Options: HDMI, USB, AV
Compatibility: iPhone, Android Phone, Tablet, iPad, Laptop, Macbook, Blu-ray Player, TV boxes, PS4, USB flash disks
Use Cases: Home theaters, video games, parties, outdoor activities
Audio: Built-in Hi-Fi stereo speakers, audio output port
Noise Reduction: 80% fan noise reduction
Warranty: Three-year product replacement warranty
Customer Service: Lifetime after-sales service, quick reply within 24 hours
Connection Method: P2P Direct Connection, no WiFi required
Wireless Technology: 5G/2.4G dual-screen WiFi, Bluetooth 5.2
Resolution: Native 720P (1280*720), supports Full HD 1080P
Brightness & Contrast: 200 ANSI brightness, 2000:1 contrast ratio
Size & Weight: 5.35*4.33*2.28 in, 420 grams
Keystone Correction: ±50° electronic vertical keystone
Zoom Function: 50% zoom via remote control
Projection Size & Distance: 32-120 in, optimal distance 3.28-9.84 feet
Input Interfaces: HDMI, USB, 3.5mm audio output
Compatibility: PC, Fire Stick, PS5
Warranty & Support: 2-year warranty, 24H service response
Updated System: Supports 1920x1080P resolution, original 1280x720P
Lamp Life: 65,000 hours
Projection Distance: 3.3 to 21.8 feet
Viewing Size: 32'' to 240''
Brightness: 7500 lux
Color Contrast: 6000:1
Aspect Ratio: 4:3/16:9
Keystone Correction: ±15°
Speakers: 2x3W HiFi stereo speakers with SRS sound system
Connectivity: HDMI, 2xUSB, AV, AUDIO interfaces
Compatibility: Works with smartphones, TV sticks/boxes, game consoles, PCs, tablets, laptops, DVD players, USB sticks
Warranty: 36 months replacement support and lifetime technical support
User-Friendly: Easy to operate, suitable for children and friends
Unboxing Experience​
ClokoWe Mini Projector:​
The CLOKOWE 2024 Upgraded Portable Mini Projector has a compact and sleek design that is surprisingly lightweight, making it easy to carry around. Despite its small size, the build quality feels solid and well-constructed, which gives it a premium appearance. The projector’s simplicity in design means it doesn’t take up much space, and it can easily blend into any setting, whether it be indoors or outdoors. I appreciate the straightforward interface and the clean lines, which contribute to a modern aesthetic.
AKIYO Mini Projector:​
Upon first glance, the projector boasts a compact and sleek design, significantly smaller than my previous model. Its lightweight construction makes it easy to handle and install, fitting seamlessly onto a shelf above my bed. The overall aesthetics are modern and unobtrusive, making it a perfect addition to my bedroom setup without the bulk of a traditional television. I appreciate how it integrates into my space while providing functionality.
NICPOW Mini Projector:​
The projector is compact and lightweight, resembling the size of an open hand, making it easy to handle and transport for various settings like camping or outdoor movie nights. It comes with a small tripod, although some users found it top-heavy and not very stable. The overall design is simplistic and functional, which aligns well with its budget-friendly pricing. While it may not be as aesthetically pleasing as high-end models, the practicality of its appearance certainly meets expectations at this price point.
30 Inches - 180 Inches​
32 Inches - 120 Inches​
32 Inches - 1E+2 Inches​
1 Meters - 4 Meters​
0.6 Meters - 4 Meters​
3.3 Feet - 22.9 Feet​
High Contrast Ratio​
5000:1​
6000: 1​
1920 x 1080 Pixels​
1920*1080 Pixels​
1920 x 1080 pixels​
1280 x 720​
1280 x 720​
7000 Lux​
5500 Lumen​
7500 lumen​
LED​
Not Specified​
I was pleasantly surprised by the viewing experience this projector offers, especially considering its affordable price. The full 1080p resolution delivers sharp and vibrant images, making movie nights feel like a cinema experience, even when projected on a simple wall. The brightness levels are impressive too, although I found it performs best in darker environments. The built-in speakers provide decent audio for small gatherings, but connecting external speakers can significantly elevate the experience for larger groups or more immersive viewing.
The viewing experience is where this projector truly shines. The clarity of the picture far exceeds my expectations, offering a sharp 1080P output that looks fantastic even in dimly lit rooms. I particularly enjoy the flexibility of projecting onto my ceiling, which elevates my movie-watching experience. However, I did encounter some playback issues when streaming from certain devices, where I found that a direct HDMI connection significantly improved stability and reduced lag.
The projector offers a surprisingly good viewing experience, especially considering its low price. Picture quality is rated around 7 to 8 out of 10, with support for 720p resolution and the ability to project up to 240 inches. Brightness performs well in dark environments, but users noted that it can diminish in brighter settings. The image clarity is commendable, although it is essential to maintain an appropriate distance to avoid losing sharpness. The sound quality, however, is generally viewed as lacking, prompting many users to connect external speakers for a more immersive experience.
Zoom 25%-100%, 2 HiFi Stereo Speakers, 1080P Support​
Built-In Speaker​
H.264 or H.265​
AVC​
AVC​
3 Watts​
75 Watts​
50000 Hours​
55000 Hours​
65000 Hours​
Remote Control, iOS,Android​
Button Control​
App​
USB, HDMI
Wireless​
MHL, USB, HDMI, VGA​
Laptop, Smartphone, Tablet, Gaming Console​
45 kWh​
38 Watt-hours​
50 watts​
Mount Type​
Ceiling Mount, Tripod Mount, Wall Mount, Tabletop Mount, Floor Mount​
Tabletop Mount​
Wall, ceiling, vertical, desktop mount​
6.7"L x 5"W x 2.96"H​
5.35"L x 4.33"W x 2.28"H​
8.66"L x 7.09"W x 3.94"H​
Setting up this mini projector was a very user-friendly experience. It truly is plug-and-play; all I had to do was connect it to a power source, choose the appropriate input, and adjust the focus. The included remote control made navigating through settings and options a breeze, allowing me to customize the picture quality easily. The availability of multiple connectivity options, such as HDMI, USB, and Bluetooth, further enhances its versatility, letting me seamlessly connect various devices like smartphones, laptops, and streaming sticks.
Setting up the projector was surprisingly straightforward. I connected it to my HDMI-equipped laptop, which allowed me to access all my streaming services with ease. The inclusion of WiFi and Bluetooth connectivity is a significant benefit, enabling me to cast from my iPhone effortlessly. I also added a 128 GB USB drive filled with movies and music, which the projector read without issue once formatted correctly. The manual was helpful, but I found that I didn’t need it as the setup process was intuitive.
Setting up this projector is straightforward and user-friendly. Users can easily connect it to devices via the included HDMI cable or compatible adapters. The projector automatically recognizes HDMI input, making it a breeze to get started. However, it’s worth noting that for smartphone connections, additional cables are often required, which are not included. The keystone and focus adjustments are simple to use, and many users appreciated the ease of mounting it on a tripod for larger displays.
- Incredibly easy setup and use
- Good image quality with vibrant colors
- Multiple connectivity options
- Quiet operation
- Portable and lightweight
- Great value for money
- Auto keystone correction
- Bluetooth audio support
- Sound quality could be better without external speakers
- May struggle in well-lit environments
- Some issues with iOS compatibility requiring firmware updates
Overall, the CLOKOWE 2024 Portable Mini Projector exceeded my expectations in terms of performance and versatility. It has become an essential part of our family entertainment, allowing for movie nights, gaming sessions, and even presentations on-the-go. While there are minor drawbacks, such as occasional sound issues and limited brightness in well-lit rooms, the advantages far outweigh them. For anyone seeking a portable and high-quality projector at an accessible price point, I highly recommend this product. It's been a fantastic investment, and I can't wait to use it for more outdoor movie nights and family gatherings!
- Excellent picture quality with clear 1080P output.
- Compact and lightweight design, easy to set up.
- Versatile connectivity options including HDMI, WiFi, and Bluetooth.
- Support for USB drives enhances functionality for media playback.
- Responsive customer support and hassle-free warranty replacements.
- Occasional connectivity issues with streaming services.
- Inconsistent Bluetooth audio lag.
- The built-in speakers could be better; external speakers recommended for optimal sound.
- Limited brightness adjustment leading to dark scenes being overly dim.
Overall, I am immensely satisfied with my projector purchase. It has become an integral part of my entertainment setup, allowing for cozy movie nights without the need for a bulky TV. The customer service experience has been outstanding, further enhancing my positive impression of the product. While some minor issues with connectivity and brightness exist, they are outweighed by the projector's portability, picture quality, and the joy it brings to my viewing experiences. I even purchased a second unit for my girlfriend, confidently sharing this fantastic product with her.
• Impressive display quality for the price.
• Easy to set up and use with multiple devices.
• Lightweight and portable, ideal for outdoor use.
• Satisfactory brightness levels in dark settings.
• Good customer support experiences noted by several users.
• Built-in speakers are underwhelming and often require external audio support.
• Limited keystone adjustment may hinder optimal image placement.
• The included screen is not effective; a better substitute is recommended.
• The tripod is unstable, making it difficult to set up securely.
Overall, this projector delivers great value for its price point, offering a solid performance for both casual movie watching and gaming. It excels in portability and ease of use, making it suitable for various settings, from home theaters to outdoor gatherings. While there are some limitations regarding sound quality and stability, the positives far outweigh the negatives. For anyone looking for an affordable projector that does its job well, this product is a no-brainer and would be a worthy investment for casual use or as a temporary solution before upgrading to a more expensive model.
ClokoWe Mini Projector is awesome for college kids! Perfect for our small apartment when friends come over. The picture quality is solid and the speakers are pretty decent too!
pricelesslambo
ClokoWe Mini Projector is awesome! Super compact and the picture quality is on point. The sound is great too—I hooked up my soundbar and it’s a perfect match. Love that it comes with a remote, and the color? No complaints!
Wwalmarts
I was a bit unsure about the ClokoWe Mini Projector at first since it seemed way too cheap for an HD projector. But honestly, it’s perfect for our movie nights with the kids!
