windstri85
Unboxing Experience
- 1.1.1 ClokoWe Mini Projector:
- 1.1.2 ELEPHAS Mini Projector:
- 1.1.3 AKIYO Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 ClokoWe Mini Projector:
- 1.3.2 ELEPHAS Mini Projector:
- 1.3.3 AKIYO Mini Projector:
- 1.4 Features
1.5
- 1.5.1 ClokoWe Mini Projector:
- 1.5.2 ELEPHAS Mini Projector:
- 1.5.3 AKIYO Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | ClokoWe Mini Projector | ELEPHAS Mini Projector | AKIYO Mini Projector |
Picture | |||
Reference Price | $69.99 | $79.99 | $55.99 |
Recommended Uses | Home Cinema | Indoor/Outdoor | Indoor/Outdoor |
Built-In Media | 1 * Lens Cover, 1 * Remote Control, 1 * HDMI Cable, 1 * Power Supply, 1 * M8 Mini projector | 1 x Remote Control, 1 x Projector, 1 x HDMI Cable, 1 x Manual, 1 x Tripod | Projector Stand |
Highlight | Brightness: 9000 Lux Resolution: 1080P Full HD Display Size: 30-180 inches (recommended 60-100 inches) Dimensions: 6.74 x 5.28 x 2.96 inches Weight: 0.72 kg Connectivity: HDMI, USB, AV interfaces Compatibility: iPhone, Android Phone, Tablet, Laptop, Macbook, Blu-ray Player, TV boxes, PS4 Audio: Built-in Hi-Fi stereo speakers, audio output port Noise Reduction: 80% reduction in fan noise Warranty: Three-year product replacement warranty Customer Service: 24-hour response, lifetime after-sales service | Product Name: Elephas Mini Projector Size: Comparable to smartphone, ultra-portable Technology: 2024 upgraded technology, Germany's LED projection Resolution: 1080P HD support Lens: German emerald glass lens Color Support: 24-bit true color (16.77 million+ colors) Screen Size: Up to 200 inches Audio: Built-in Hi-Fi speaker Cooling System: Efficient heat dissipation, reduced fan noise Connectivity: USB, HDMI, AV, Audio, Chromecast interface Compatibility: iOS, Android, Windows, various media devices (not supporting Netflix, Amazon Prime, Hulu due to HDCP) Included Accessories: Mini stand (portable power station not included) Certifications: CE, FCC, RoHS, PSE Warranty: 3-years factory support | Connection Type: P2P Direct Connection (No WiFi Required) Wireless Connectivity: 5G/2.4G dual-screen WiFi, Bluetooth 5.2 Native Resolution: 1280x720P Supported Resolution: Full HD 1080P Brightness: 200 ANSI Lumens Contrast Ratio: 2000:1 Size: 5.35x4.33x2.28 in Weight: 420 grams Keystone Correction: ±50° electronic vertical Zoom Function: 50% zoom via remote control Projection Size: 32-120 inches Optimal Projection Distance: 3.28-9.84 feet Input Interfaces: HDMI, USB, 3.5mm audio output Warranty: 2 years Customer Support: 24H service response |
Unboxing Experience
The CLOKOWE 2024 Mini Projector has a compact and modern design that immediately impressed me. Its small size makes it incredibly portable, allowing me to easily transport it for movie nights or presentations. The build quality feels sturdy despite its lightweight frame, and the aesthetics are simple yet appealing, which fits well in any environment, whether indoors or outdoors.ELEPHAS Mini Projector:
The ELEPHAS 2024 1080P HD Mini Projector is surprisingly compact for a projector, making it easy to transport and store. It comes with a well-made carrying case, allowing for convenient travel, which is a major plus for someone like me who enjoys outdoor movie nights and impromptu gatherings. Its sleek design doesn’t scream “tech gadget,” blending nicely into various settings, whether it’s in my living room or on a camping trip. However, I have noticed some inconsistency in product deliveries, as some orders have included the case while others have not.AKIYO Mini Projector:
Upon first glance, the projector appears compact and lightweight, making it an inviting option for those who value portability. Its design is straightforward, functional, and well-packaged, with a minimalistic aesthetic that doesn’t detract from its performance. While not the brightest when the lights are on, it holds its own in darker environments, producing a clear and adequately bright image. The included tripod enhances its usability, making setup convenient for movie nights or art projects.Display
Screen Size | 30 Inches - 180 Inches | 80 Inches - 200 Inches | 32 Inches - 120 Inches |
Throw Distance | 1 Meters - 4 Meters | 2.6 Feet - 14.5 Feet | 0.6 Meters - 4 Meters |
Contrast Ratio | High Contrast Ratio | 6000:1 | 5000:1 |
Maximum Resolution | 1920 x 1080 Pixels | 1920x1080 Pixels | 1920*1080 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 720 |
Brightness | 7000 Lux | 3500 lumen | 5500 Lumen |
Display Type | LED | LCD | LCD |
Picture Enhancement | - | - | Not Specified |
Viewing Experience
The viewing experience with this projector has been nothing short of fantastic. The 1080P resolution delivers bright, sharp images that are vibrant and clear, even projected onto a textured wall. It performs exceptionally well in darker rooms, providing a theater-like atmosphere for movie nights or gaming sessions. I found it impressive that despite its small size, the projector managed to fill up a significant space with quality visuals.ELEPHAS Mini Projector:
The image quality provided by this projector is beyond what I expected for its price. The 1080P resolution delivers clear and vibrant colors, especially when used in darker environments. I’ve projected onto both a white wall and a screen, and the quality holds up well. While the brightness is adequate for indoor use, outdoor settings require a darker atmosphere for optimal viewing. I’ve noticed some minor issues, such as flickering pixels and occasional noise in the image, but they do not significantly detract from the overall experience. The sound quality, while decent, is best enhanced through external speakers, which I've opted to use for a fuller audio experience.AKIYO Mini Projector:
The viewing experience can be quite enjoyable, especially in dimly lit settings where the projector shines. The image quality impresses for its price range, offering sharp visuals that work well for movies, gaming, or projecting artwork. However, there are reports of light artifacts and issues with screen mirroring, particularly regarding lag and connectivity. The built-in speakers deliver passable sound for casual viewing, but users looking for a more robust audio experience may want to invest in external speakers.Features
Other Features | Zoom 25%-100%, 2 HiFi Stereo Speakers, 1080P Support | HDMI Connectivity, Portable | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi |
Video Encoding | H.264 or H.265 | AVC | AVC |
Lamp Wattage | - | 38 Watts | 3 Watts |
LightSource Life | 50000 Hours | 50000 Hours | 55000 Hours |
Controller Type | Remote Control, iOS,Android | remote | Button Control |
Control Method | Remote | Remote | App |
Connectivity Technology | USB, HDMI | HDMI | Wireless |
Compatible Devices | Laptop, Smartphone, Tablet, Gaming Console | Smartphone, Laptop, Tablet, Television | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | 45 kWh | 60 watts | 38 Watt-hours |
Mount Type | Ceiling Mount, Tripod Mount, Wall Mount, Tabletop Mount, Floor Mount | Tripod Mount | Tabletop Mount |
L x W x H | 6.7"L x 5"W x 2.96"H | 6"L x 4.4"W x 2.4"H | 5.35"L x 4.33"W x 2.28"H |
Setting up the CLOKOWE 2024 Mini Projector was a breeze! It’s truly a plug-and-play device; I simply connected it to my HDMI source, selected the input, and I was ready to go. The user-friendly interface and remote control made navigation seamless, even for those who might not be tech-savvy. I appreciated the multiple connectivity options, including USB and compatibility with various devices like smartphones, laptops, and streaming sticks.ELEPHAS Mini Projector:
Setting up the projector was a breeze. I connected it to both my laptop and iPhone with minimal hassle, primarily using a Fire Stick for streaming. The instructions were straightforward, and I was up and running in under five minutes. However, I did encounter a slight hiccup with the iPhone connectivity; while it was advertised that a standard charging cable could suffice, an HDMI adapter was necessary for proper functionality. Additionally, the remote control is basic but effective, requiring two AAA batteries, which are not included.AKIYO Mini Projector:
Setting up the projector is largely a hassle-free experience. The interface is user-friendly, allowing for seamless connections to various devices via HDMI, USB, or Bluetooth. However, there are some caveats with device compatibility, particularly with newer MacBooks requiring adapters for HDMI connections. Additionally, the projector struggles with certain devices like the Nintendo Switch, which can complicate usage for some users. Despite these hiccups, many have found the setup process simple and intuitive, even for those less tech-savvy.Conclusion
Pros:- Incredibly easy setup and use
- Good image quality with vibrant colors
- Multiple connectivity options
- Quiet operation
- Portable and lightweight
- Great value for money
- Auto keystone correction
- Bluetooth audio support
- Sound quality could be better; external speakers recommended
- May struggle in well-lit rooms
- No Bluetooth functionality for some models
- Compatibility issues with certain iOS versions
Overall, I am thoroughly impressed with the CLOKOWE 2024 Mini Projector. It exceeded my expectations in terms of performance and value for money. While the sound quality is decent for small settings, using an external speaker greatly enhances the experience. Its portability, ease of use, and stunning image quality make it an excellent choice for anyone looking for a reliable projector for home entertainment, presentations, or outdoor movie nights. Highly recommend it to anyone in need of a budget-friendly yet high-performing projector!
Pros:• Excellent value for the price, delivering image quality comparable to higher-end models.
• Easy connectivity with various devices, allowing for quick setup.
• Portable and lightweight design, perfect for travel and outdoor use.
• Satisfactory image quality in dark environments, making it ideal for movie nights.
• Sound quality is mediocre; using external speakers is highly recommended.
• Some connectivity issues with certain streaming services, especially through iOS devices.
• Inconsistent product deliveries regarding included accessories like carrying cases.
Overall, I am extremely satisfied with the ELEPHAS 2024 Mini Projector. It has exceeded my expectations in terms of quality and ease of use, especially considering its affordability. Whether I’m using it for movie nights at home or for craft projects, its compact design and impressive image quality make it a worthwhile investment. Despite a couple of minor drawbacks, such as sound quality and connectivity quirks, I would highly recommend this projector to anyone looking for an affordable and portable option for big-screen entertainment.
Pros:• Good picture quality for a budget projector.
• Compact and portable design.
• Easy to set up and connect to various devices.
• Customer service is responsive and helpful.
• Versatile use cases, from movie nights to projecting artwork.
• Issues with certain device compatibility, particularly with newer USB-C models.
• Built-in speakers lack power; external speakers are recommended.
• Some users reported light artifacts and lag during wireless playback.
• Limited brightness in well-lit environments.
Overall, this projector represents excellent value for those seeking a portable and versatile solution for casual viewing. While it may not rival high-end models in performance, it meets the needs of many users looking for a cost-effective option. Despite some connectivity and audio limitations, the projector's impressive image quality and responsive customer service elevate its appeal. For anyone seeking to enjoy movies or art in a compact form factor, this projector is a solid choice.
