Jamsbond
To give full play to the sound effect, space conditions, equipment matching, speaker positioning and user fine-tuning, and other four major items are indispensable when install home theater. The best time to wire a cinema is before it is decorated. According to different sitting room environment, decide the installation of home theater. Here are some common problems with home theater installation wiring.
Problem 1: wiring on concrete
In foreign countries, some family houses have basements, in this kind of house home theater wiring implementation work is very easy, the installer only need to install the cable under the floor, connected to the various microphone, system components and display equipment. However, in our country, most people's houses do not have such conditions as a basement, and the houses are made of concrete material. In order to pass the cable through the room, holes need to be made in the room, which is troublesome to implement, and the beauty of the house is also greatly reduced.
Solutions:
1. If the user is willing to install the cable under the carpet and floor, he/she can make holes in the floor and implant the cable along the corresponding pipe, so that the cable can be fully protected.
2, in the cement ground to make a hole, the cable according to the path hidden in the way of the cable layout is good, but on the overall beauty of the room will have a greater impact, the overall project is more complex. If the user think engineering is too trouble, you can choose the flat cable, the cable is very thin, the thickness like a paper, if the installation between floor and floor, its ply basically negligible, user does not easy to detect, but there is a flaw in this way wiring, wiring is placed above the floor can't too heavy furniture.
3, wiring on the floor is the most commonly used way, through the wall wiring can be regarded as a good choice. The cable can be installed behind the wall panel, chair seat, etc.
Problem 2: insufficient ceiling space
In abroad, the house of a lot of families has a attic, this is wiring very ideal position, when projector and scrollscreen were used in home cinema, the action of attic is more apparent. There are two main advantages of using an attic for a home theater: the environment is very beautiful, and the user can place the projector, screen and other equipment all in the attic. If the user does not turn it on through the remote control button, others will not notice that there are so many messy devices in the room. Additional, still can support and move the annex of screen, projector to hide completely, let the room hold concurrently bedroom, home theater, office and so on mutifunction function. If there is less space on the ceiling of a home theater, there will certainly be less space for important system parts, but that doesn't mean users can't put those parts on the ceiling. We can figure out how to fix that.
Solutions:
1, add ceiling bottom: even if there is no space on the ceiling, users can still hide the automatic projector and screen in the special ceiling bottom. The ceiling is mainly used to support and hide the large machines in the home theater system, while adding some structures in the room according to the user's needs.
Install them on the wall: the screens and projectors that slowly descend from the ceiling to add color to your home theater can also be installed on the wall. For example, a flat-screen TV is installed directly in front of a wall, covered with a gauze curtain, and then a starter device is installed next to the TV. The gauze curtain is driven by the device to open or close, giving the audience a cinema-like sense of reality. On the other side of the room, install the projector on the back wall or hide it inside the coffee table.
Speakers on the side: if there is not enough room in the ceiling, it is not possible to install a ceiling speaker, in which case the user can choose a built-in speaker. If the user wants the speakers to be unobtrusive, the entire wall can be covered with sound structure panels to make the room look pretty. We can also use a simpler method to paint the color of the speaker to match the color of the wall.
Solutions:
Solutions:
