ELEPHAS vs AKIYO vs PURSHE Mini Projectors: A Comparison of HDMI and USB Features for Your Viewing Needs
KeyGood5298
ELEPHAS Mini Projector​
AKIYO Mini Projector​
PURSHE Mini Projector​
$79.99​
$55.99​
$48.99​
Indoor/Outdoor​
Indoor/Outdoor​
Home Cinema​
1 x Remote Control, 1 x Projector, 1 x HDMI Cable, 1 x Manual, 1 x Tripod​
Projector Stand​
Model: Elephas Mini Projector
Technology: 2024 upgraded, Germany's LED projection
Size: Comparable to a smartphone, portable
Resolution: 1080P HD
Lens: German emerald glass lens
Color Support: 24-bit true color (over 16.77 million colors)
Screen Size: Up to 200 inches
Sound: Built-in HIFI speaker
Noise Reduction: Efficient heat dissipation system
Connectivity: USB, HDMI, AV, Audio, Chromecast interface
Compatibility: iOS, Android, Windows, various media devices
Limitations: Does not support Netflix, Amazon Prime, Hulu (but compatible with Amazon Fire Stick or Roku Stick)
Certifications: CE, FCC, RoHS, PSE
Warranty: 3-years factory support
Includes: Mini stand, portable power station (not included)
Connection Type: P2P Direct Connection, no WiFi required
WiFi Standards: 5G/2.4G dual-screen WiFi, max speed 9.6 Gbps
Bluetooth Version: 5.2 (not compatible with smartphones)
Native Resolution: 1280x720P
Supported Resolution: Full HD 1080P
Brightness: 200 ANSI lumens
Contrast Ratio: 2000:1
Dimensions: 5.35 x 4.33 x 2.28 in
Weight: 420 grams
Keystone Correction: ±50° electronic vertical
Zoom Function: 50% zoom via remote control
Projection Size: 32-120 inches
Optimal Distance: 3.28-9.84 feet
Input Interfaces: HDMI, USB, 3.5mm audio output
Warranty: 2-year warranty
Tech Support: 24H service response available
Dimensions: 7 x 5 x 2.5 inches
Weight: Portable
Resolution: 1080P Full HD
Brightness: Upgraded brightness technology
Color Reproduction: Latest technology for vibrant colors
Bluetooth: 5.1
Audio: Built-in 3W stereo speakers
Cooling System: Advanced fan cooling, extends bulb life to 50,000 hours
Compatibility: Plug and play with Smartphone, Laptop, TV Stick, PS4, DVD player, Tablet, TV box
Use Cases: Indoor/outdoor movie nights, camping, BBQ gatherings
Unboxing Experience​
ELEPHAS Mini Projector:​
The ELEPHAS 2024 Upgraded 1080P HD Mini Projector has a compact and portable design that makes it ideal for those looking for an easy-to-transport projector. While it doesn't fit in a coat pocket as some misleading images suggest, it comfortably fits in a backpack or large purse. The sturdy build quality and neat carrying case enhance its grab-and-go appeal, ensuring that it can withstand being moved around without feeling flimsy. Overall, it presents a modern and practical aesthetic suitable for casual users.
AKIYO Mini Projector:​
I was pleasantly surprised by the compact design of this mini projector. It's significantly smaller than my previous projector, making it easy to set up and store. The aesthetics are modern and unobtrusive, blending well with my bedroom décor. The lightweight design is a bonus, allowing me to mount it under a shelf without any hassle. Overall, it feels well-built and designed for portability, which is perfect for my needs.
PURSHE Mini Projector:​
The projector boasts a sleek and compact design that is both lightweight and portable, making it easy to transport for various uses, whether indoors or outdoors. Its modern aesthetic is unobtrusive, allowing it to blend seamlessly into any room without taking up much space. The remote control is a convenient addition, though it’s worth noting that it requires two AAA batteries, which are not included. Overall, the build quality feels durable, promising longevity despite its small size.
80 Inches - 200 Inches​
32 Inches - 120 Inches​
32 Inches - 2E+2 Inches​
2.6 Feet - 14.5 Feet​
0.6 Meters - 4 Meters​
N/A - 12 Feet​
6000:1​
5000:1​
6000:1​
1920x1080 Pixels​
1920*1080 Pixels​
1920*1080 Pixels​
1280 x 720​
3500 lumen​
5500 Lumen​
9500​
Not Specified​
The viewing experience is surprisingly good for the price, especially in darker environments where the colors pop and the image remains sharp. While some users have reported issues like flickering pixels and limited keystone adjustment, with proper setup and adjustments, the projector can deliver a satisfying image quality that rivals more expensive models. The sound quality is a common concern, with many opting for external speakers to enhance their viewing experience, but the projector performs adequately for casual use.
The image quality is where this projector truly shines. I was initially skeptical about the clarity, but the 1080P output is sharp and vibrant, especially in dim lighting. Watching movies projected onto my ceiling has been a game-changer, providing a unique viewing experience. However, I did notice that scenes with darker tones can appear excessively dark, which detracted slightly from the overall enjoyment. The ability to adjust the focus and utilize digital zoom is a welcome feature that enhances the viewing experience, though the lack of brightness adjustment could be a downside for some users.
The picture quality is truly impressive, with vibrant colors and clarity that holds up even in moderately lit environments. I was captivated by the sharpness and detail during movie nights, and the projector can display images up to a massive 300 inches. The included 120-inch screen is a fantastic bonus, ensuring you have everything you need for an immersive viewing experience. While the internal speakers are decent, connecting to an external sound system is highly recommended for a more robust audio experience, especially during outdoor gatherings.
• **Pros**:
- Excellent picture quality with vibrant colors
- Easy setup and extensive connectivity options
- Portable and lightweight design
- Included projector screen for added value
- Reliable customer service support
• **Cons**:
- Built-in speakers could be better
- Remote requires batteries not included
- Some users reported Bluetooth connectivity issues
HDMI Connectivity, Portable​
Bluetooth, Built-in speaker, HDMI and USB connectivity​
AVC​
AVC​
AVC​
38 Watts​
3 Watts​
3 Watts​
50000 Hours​
55000 Hours​
5000 Hours​
remote​
Button Control​
App​
HDMI
Wireless​
Smartphone, Laptop, Tablet, Television​
Smartphone, Laptop, TV Stick, PS4, DVD player, Tablet​
60 watts​
38 Watt-hours​
3 watts​
Mount Type​
Tripod Mount​
Tabletop Mount​
Ceiling/floor/Tabletop/Tripod/Wall Mount​
6"L x 4.4"W x 2.4"H​
5.35"L x 4.33"W x 2.28"H​
7"L x 5"W x 2.5"H​
Setting up the projector was a breeze, taking less than two minutes to connect a Fire Stick and power it on. The controls are user-friendly, with easily accessible focus and keystone adjustment features. The inclusion of a small tripod and a 3-foot HDMI cable adds to the overall convenience. However, users should note that the short power cable necessitates setting up near an outlet or using an extension cord. The remote control is basic but functional, although the battery cover requires a bit of finesse to open.
Setting up the projector was a breeze. I followed the instructions provided and had it running in no time. The simplicity of the setup process is commendable, especially for someone who isn't tech-savvy. Once I connected it to my laptop via HDMI, I was able to access all my streaming services and media effortlessly. The option to cast from my iPhone added a layer of convenience that I didn't expect, although I found some inconsistencies when streaming directly from certain apps.
Setting up the projector was a breeze, taking me less than ten minutes from unboxing to watching my first movie. The user manual was clear, with translations done reasonably well, which is a refreshing experience compared to other products I've encountered. Connectivity options are extensive: it supports Wi-Fi, Bluetooth, HDMI, USB, and more, making it versatile for various devices. The seamless integration with smartphones and external speakers enhances the user experience, allowing for quick access to streaming services and media files.
- Excellent value for the price, delivering image quality comparable to higher-end models.
- Portability makes it great for travel and outdoor movie nights.
- Easy setup with quick connectivity to devices.
- Works well on light-colored walls, eliminating the immediate need for a projector screen.
- Customer service is responsive and helpful.
- Short power adapter cable limits placement options.
- Internal speaker quality is subpar, necessitating external speakers for better audio.
- Some users report connectivity issues with iOS devices and other streaming services.
- Limited keystone adjustment affects flexibility in setup.
The ELEPHAS 2024 Upgraded 1080P HD Mini Projector is an impressive budget-friendly option that offers great value and functionality for casual movie lovers and outdoor enthusiasts. While it has its flaws, such as the sound quality and connectivity limitations, the overall performance in delivering clear, vibrant images makes it an attractive choice. Its portability and ease of use further solidify its place as a go-to projector for impromptu movie nights or camping adventures. I would recommend this projector to anyone looking for a compact, affordable solution for their entertainment needs.
• Impressive picture clarity and color reproduction
• Compact and lightweight design for easy portability
• Simple setup process and versatile connectivity options
• Good customer service experience, with quick responses and helpful support
• Useful digital zoom feature for image adjustments
• Occasional connectivity issues when streaming wirelessly
• Lack of brightness adjustment can hinder viewing darker scenes
• Built-in speaker quality is subpar; external speakers are recommended
• Some users reported overheating and minor glitches during extended use
I am genuinely happy with my purchase of this mini projector. It fits perfectly in my lifestyle, allowing for cozy movie nights without the need for a bulky TV. The combination of great picture quality and ease of use makes it a fantastic choice for anyone looking for a compact projection solution. While there are a few minor drawbacks, they are easily outweighed by the positives. The excellent customer service I encountered further solidified my satisfaction, and I would wholeheartedly recommend this projector to others seeking a budget-friendly alternative to traditional TVs.
This projector is an outstanding value for its price, offering a rich feature set that caters to both casual viewers and home theater enthusiasts alike. Its impressive performance, including 1080p resolution and seamless connectivity, makes it a worthwhile investment for anyone looking to enhance their entertainment setup. I wholeheartedly recommend this projector for personal use or as a thoughtful gift for friends and family. It has truly revolutionized my movie-watching experience, and I can’t wait to explore more of its capabilities during outdoor screenings and family gatherings.
I was super impressed with the ELEPHAS Mini Projector! Super easy to set up, and the picture looks great—especially in the dark. The colors pop! Totally recommend it!
El_Frijol
I’m loving my AKIYO Mini Projector! It’s super tiny and easy to set up, plus the picture quality is awesome. It's lightweight too! I've used it for movie nights and even for photoshoots. Totally recommend it!
ZacRedact
I’m totally obsessed with the AKIYO Mini Projector! It shows a perfect picture, and it’s super portable, not heavy at all. Plus, I can adjust the sound. I’ve got it connected to my ROKU, and it’s easy to take anywhere if I want.
mvppaulo
El PURSHE Mini Projector lo tengo en mi cuarto proyectando en la pared. Generalmente lo uso con el teléfono para ver películas en YouTube y la imagen se ve genial. El ventilador es un poco ruidoso, pero en general está muy bien.
NetworkingJesus
PURSHE Mini Projector is awesome! Great price and quality, it looks super sharp like real 4K. You can use it in lots of ways, including Bluetooth. Totally recommend it!
manowar09
PURSHE Mini Projector rocks! Got it fast and super easy to set up. Connects to your phone and TV with an app. Picture quality is awesome! We’ve been watching videos in the yard, and the whole fam is loving it!
yodathekid
The PURSHE Mini Projector is awesome! Super easy to use, sounds great, and the picture quality is top-notch. I've been having a blast watching movies and gaming with it!
