Barend Ray
Active member
Unboxing Experience
- 1.1.1 GRC Mini Projector:
- 1.1.2 Yoton Mini Projector:
- 1.1.3 NICPOW Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 GRC Mini Projector:
- 1.3.2 Yoton Mini Projector:
- 1.3.3 NICPOW Mini Projector:
- 1.4 Features
1.5
- 1.5.1 GRC Mini Projector:
- 1.5.2 Yoton Mini Projector:
- 1.5.3 NICPOW Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | GRC Mini Projector | Yoton Mini Projector | NICPOW Mini Projector |
Picture | |||
Reference Price | $79.99 | $42.99 | $49.99 |
Recommended Uses | Home Cinema, Gaming | Home Cinema | Outdoor or indoor |
Built-In Media | User Manual, Power Cord, Warranty Card, Projector Screen, HDMI Cable | Mini Projector Y3, User Manual, Remote Control, Power Cable, HDMI Cable | 1 x NICPOW Projector,1 x HDMI Cable 1 x 3 inches (approx. 2.5 x 7.6 cm) AV Cable,1 x Power Supply ,1 x User Manual,1 x Remote Control, 1 x Tripod |
Highlight | Resolution: Native 720P (1280x720) with 1080P Full HD support Bluetooth: 5.1 for audio transmission only Included Accessories: Portable projector screen, tailored for home theater setup Image Size Range: 32” to 220” Projection Distance: 1.5-6m Aspect Ratio: 4:3/16:9 Contrast Ratio: 5000:1 Lamp Lifetime: 60,000 hours Compatibility: Connects with phones/tablets via HDMI adapter (not included); Lightning to HDMI adapter for iOS; MHL support for Android required. | Resolution: Native 720P (1280*720), supports Full HD 1080P Brightness: 120 ANSI lumens Dimensions: 13.72 x 10.92 x 5.84 cm Weight: 420 grams Projection Size: Up to 120 inches (optimal 30-100 inches) Projection Distance: 1.3 to 3 meters Keystone Correction: ±15° vertical Zoom Function: 50% Connectivity: HDMI, USB, audio ports Wired Connection: iOS direct via Lightning cable WiFi/Bluetooth: Not available | Resolution: 1920x1080P (original 1280x720P) Lamp Life: 65,000 hours Brightness: 7500 lux Color Contrast: 6000:1 Aspect Ratio: 4:3/16:9 Projection Distance: 3.3 to 21.8 feet (optimal 6.5 to 8.2 feet) Viewing Size: 32'' to 240'' Keystone Correction: ±15° Speakers: 2x3W HiFi stereo speakers with SRS sound system Connectivity: HDMI, 2xUSB, AV, AUDIO Compatibility: Smartphones, TV sticks/boxes, game consoles, PCs, tablets, laptops, DVD players, USB sticks Support: 36 months replacement support, lifetime technical support Ease of Use: Simple operation, suitable for children and friends |
Unboxing Experience
GRC Mini Projector:
Upon receiving the TMY Mini Projector, I was initially struck by its compact and lightweight design. It fits easily on a bedside table or can be tossed into a backpack, making it incredibly portable. The packaging was secure and aesthetically pleasing, and although the projector is small, it feels sturdy and well-built. The included projector screen is a nice touch, although I found that projecting onto a plain wall often yielded even better results in terms of image quality.Yoton Mini Projector:
From the moment I unpacked the projector, I was struck by its compact size, reminiscent of a Whopper. It's unobtrusive and easy to place in any room, which is a major plus given how limited my space can be. The build quality feels decent for the price, though I am mindful that it’s not built like a premium device. Overall, it’s a straightforward and functional design that fits well into my setup without drawing too much attention.NICPOW Mini Projector:
The projector has a compact design, roughly the size of an open hand, which makes it highly portable and easy to set up. It doesn't look overly fancy, but it has a modern aesthetic that fits well in both indoor and outdoor settings. It comes with a small tripod that, while not very sturdy, adds to its versatility for various projection needs. The overall impression is that of a budget-friendly gadget that prioritizes functionality over flashy design.Display
Screen Size | 32 Inches - 5 Meters | 30 Inches - 100 Inches | 32 Inches - 1E+2 Inches |
Throw Distance | 1.1 Meters - 6 Meters | 1 Meters - 4 Meters | 3.3 Feet - 22.9 Feet |
Contrast Ratio | - | 5000:1 | 6000: 1 |
Maximum Resolution | 1920 x 1080 | 1920 x 1080 Pixels | 1920 x 1080 pixels |
Native Resolution | 1280 x 720 | 1280 x 720 | 1280 x 720 |
Brightness | 95 Lumen | 5500 Lumen | 7500 lumen |
Picture Enhancement | 3LCD color calibrating and adjusting technology | LCD 3.0 | - |
Viewing Experience
GRC Mini Projector:
The viewing experience was remarkable given the projector's price point. The 1080P resolution provided sharp and vibrant visuals that made movie nights enjoyable, even in environments with some ambient light. The brightness and color accuracy were impressive, and I found the image quality to be clear and sharp, especially when projecting onto a smooth wall. While the built-in speakers were decent, connecting external speakers via Bluetooth amplified the experience significantly. Overall, the projector delivers an enjoyable cinematic experience, particularly for casual viewing.Yoton Mini Projector:
The viewing experience has been largely positive, especially for casual movie nights or art projects. The brightness is decent in low-light conditions, and I was impressed with the clarity when projecting my art onto canvas. However, I did find that the image quality could be inconsistent at times, especially when using keystone correction, which made it hard to achieve a perfect focus across the entire screen. Still, it does the job for family videos and streaming from my Fire Stick, making it a functional choice for our needs.NICPOW Mini Projector:
For the price, the viewing experience is quite impressive. The projector supports up to 1080p resolution and delivers a clear image quality that I would rate around 7 or 8 out of 10, especially when used in darker settings. Brightness is decent, but in bright rooms, the image might appear washed out unless curtains are drawn. It performs wonderfully for indoor movie nights, though it's not the best for outdoor use unless it's completely dark outside. The sound quality is somewhat lackluster, so for an optimal experience, I recommend connecting external speakers.Features
Other Features | Built-In Speaker | LCD 3.0 Tech, High bright, Max support 1080P, Mini size, Speakers | Built-In Speaker |
Video Encoding | AVC | AVI/MP4/MKV/MOV/MPEG1/MPEG2/H.264/XVID | AVC |
Lamp Wattage | - | 3 Watts | 75 Watts |
LightSource Life | 6E+4 Hours | 6000 Hours | 65000 Hours |
Controller Type | Remote Control | Remote Control | Remote Control |
Control Method | - | Remote | Remote |
Connectivity Technology | Bluetooth, USB, HDMI, 3.5mm Jack | USB, HDMI | MHL, USB, HDMI, VGA |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone | iPhone, Fire TV Stick, PC, PS5, Android | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | - | 38 watts | 50 watts |
Mount Type | Tabletop/Tripod/Ceiling Mount | Ceiling/Tripod/Floor/Wall/Tabletop Mount | Wall, ceiling, vertical, desktop mount |
L x W x H | 7.09"L x 5.31"W x 2.76"H | 5.4"L x 4.3"W x 2.3"H | 8.66"L x 7.09"W x 3.94"H |
GRC Mini Projector:
Setting up the TMY Mini Projector was a breeze. I was pleasantly surprised at how quickly I was able to connect it to my devices. The various connectivity options—including HDMI, USB, and Bluetooth—made it very versatile for different uses, whether I was streaming from my phone, laptop, or gaming console. While some users experienced minor issues with connectivity, I found the overall setup process straightforward. The included remote control made navigating through the menu simple, though I did have to supply my own batteries.Yoton Mini Projector:
Setting up the projector was a breeze, and I appreciated how quickly I could get it connected to my Echo Show for enhanced audio. While there were a few hiccups trying to connect it to my Samsung phone, it worked flawlessly with my iPad after I purchased a Wi-Fi adapter, which I found necessary. The initial confusion during setup was quickly resolved after a bit of fiddling, and I could start projecting images almost immediately.NICPOW Mini Projector:
Setting up the projector is a straightforward process. I was pleasantly surprised by how quickly I could connect it to my devices using the included HDMI cable. The projector natively accepts HDMI input, making it easy to hook up to my laptop or gaming console. The keystone and focus adjustments work smoothly, allowing for a clear image projection on various surfaces. However, I did notice that the included screen leaves much to be desired, as it is somewhat flimsy and not very effective at blocking light, which can be easily remedied by using a plain white bed sheet instead.Conclusion
GRC Mini Projector:
Pros:• Compact and lightweight design, making it easily portable
• Simple and quick setup process
• Impressive picture quality with vibrant colors
• Multiple connectivity options (HDMI, USB, Bluetooth)
• Good customer support and warranty options
• Built-in audio could be improved; external speakers recommended
• Some users experienced setup difficulties with specific devices
• Brightness may not meet expectations based on advertised lumens
The TMY Mini Projector is a fantastic value for anyone looking for an affordable and portable option for home entertainment. It has exceeded my expectations in terms of image quality and ease of use. While it may not compete with high-end projectors, it certainly delivers a satisfying viewing experience for casual movie nights or gaming sessions. I highly recommend this projector for anyone seeking a budget-friendly solution for their entertainment needs.
Pros:• Compact and portable design.
• Easy setup and connectivity options.
• Good brightness for dark environments.
• Decent audio quality when paired with external speakers.
• Affordable price for the features offered.
• Image quality can be inconsistent, particularly with edge focus.
• Dust collects inside, affecting clarity.
• HDMI cable quality is questionable; prone to breaking.
• Limited customer service response during troubleshooting.
• No wireless connectivity without adapters.
Overall, I find this projector to be a solid investment given its price point. It may not excel in every category, and I have faced some challenges with its functionality, but it performs well enough for my purposes. The size and ease of use make it a great option for creating a big-screen experience in a compact form. Despite some flaws, particularly with image sharpness and customer service issues, I still feel it offers good value for those looking for a budget-friendly projector for casual use.
Pros:- Affordable price point with good image quality
- Compact and portable design
- Easy setup with HDMI connectivity
- Sufficient brightness for dark rooms
- Reasonable built-in speakers for small gatherings
- Sound quality is weak; external speakers recommended
- Included screen is subpar and not very effective
- Short power cord may require an extension
- Limited Bluetooth connectivity options
Overall, I find this projector to be an excellent value for the price. It's ideal for casual movie nights, gaming sessions, or even presentations, given that you're not expecting high-end performance. I've been using it for a few weeks now, and it has exceeded my expectations, especially when considering its affordability. While it has its shortcomings, particularly regarding sound and the included screen, the projector does what it sets out to do, making it a solid choice for anyone looking for an inexpensive solution for their viewing needs.
