How to Connect iPad to TV: The Ultimate Guide
Want to enjoy your iPad content on a big screen? Whether you're streaming a movie, presenting slides, or playing a game, learning how to connect iPad to TV can elevate your viewing experience.
This guide walks you through all the working methods—both wired and wireless—so you can choose what works best for your setup.
Best Ways to Connect iPad to TV in 2025​
There are three main ways to connect your iPad to your TV:
  1. Using AirPlay (wireless)
  2. Using an HDMI cable with a Lightning/USB-C adapter (wired)
  3. Using third-party screen mirroring apps or devices
Let’s go through each option with clear step-by-step instructions.
Method 1: How to Connect iPad to TV Wirelessly Using AirPlay​
If you have an Apple TV or a Smart TV with AirPlay 2 built in, this is the easiest method.
Steps:
  1. Connect to the Same Wi-Fi
    Ensure your iPad and TV are connected to the same Wi-Fi network.
  2. Enable AirPlay on Your TV
    On Apple TV or compatible smart TVs (Samsung, LG, Sony, etc.), go to
    Settings > AirPlay and HomeKit > Turn On AirPlay.
  3. Open Control Center on Your iPad
    Swipe down from the top-right corner of your iPad screen.
  4. Tap “Screen Mirroring”
    Select your Apple TV or smart TV from the list.
  5. Enter Code (If Prompted)
    A code may appear on your TV. Enter it on your iPad to confirm the connection.
Your iPad screen should now appear on your TV.
Pro tip: For streaming videos from apps like YouTube or Netflix, tap the AirPlay icon within the app instead of mirroring the entire screen.
hdmi-cable-wired" >Method 2: How to Connect iPad to TV Using HDMI Cable (Wired)​
This is the most reliable and lag-free method, especially useful if your TV doesn’t support AirPlay.
What You Need:
  • For iPads with Lightning port: Lightning to Digital AV Adapter
  • For iPads with USB-C: USB-C Digital AV Multiport Adapter
  • A standard HDMI cable
Steps:
  1. Plug the Adapter into Your iPad
  2. Connect the HDMI Cable
    One end goes into the adapter, the other into your TV’s HDMI port.
  3. Switch TV Input
    Use your TV remote to select the correct HDMI input.
Your iPad screen should automatically appear on the TV. No apps or setup needed.
Method 3: Use Screen Mirroring Apps (Alternative Option)​
If your TV doesn’t support AirPlay and you don’t want to buy an adapter, you can try third-party apps like:
  • ApowerMirror
  • LetsView
  • TV Cast for Chromecast or Fire TV
These apps work over Wi-Fi and allow you to mirror or cast content, but they may come with some lag or ads.
Caution:
These apps often require both devices to be on the same network, and streaming DRM-protected content (like Netflix) may not work well.
Troubleshooting Tips​
  • AirPlay Not Working?
    Restart both devices and ensure they are on the same Wi-Fi network.
  • No Signal on HDMI?
    Double-check the adapter is Apple-certified and try another HDMI port on the TV.
  • Poor Video Quality?
    Use a higher-quality HDMI cable and avoid cheap third-party adapters.
Frequently Asked Questions​
Q: Can I connect my iPad to an older non-smart TV?
Yes. Just use an HDMI adapter and cable—no smart features required.
Q: Can I stream Netflix or YouTube?
Yes. Both work with AirPlay and HDMI methods. For best performance, use HDMI.
Q: Will the audio play through the TV?
Yes. When connected correctly, audio will transfer from the iPad to your TV automatically.
Now you know exactly how to connect iPad to TV using the best available methods in 2025. Whether you prefer the wireless freedom of AirPlay or the stability of a wired HDMI connection, both options are easy and effective.
By following the step-by-step instructions above, you can mirror your iPad screen, stream content, or make presentations on a bigger screen with confidence.
Related Reading:
How to Broadcast Phone to TV? Easy Guide
How to Mirror Android to TV: A Complete Step-by-Step Guide
