How to connect TV box to TV?
Gabe
1. Find the HDMI interface behind the TV, and the HDMI cable both ends of the box and the TV interface (if your home is an old TV, no HDMI interface, please use AV cable connection, AV cable operation method is much the same).
2. Use the remote control to select the signal source as HDMI (here according to the actual source access to select)
3. Connect the HDMI cable to the box as well.
4. The box can be opened after switching on the power supply.
Gabe
If the screen cannot be displayed, please check whether the HDMI interface is broken or the TV resolution is too low. At this time, AV interface can be used to check the cause.
