How to Get HBO Max on Samsung Smart TV? Complete Guide
Wondering how to get HBO Max on your Samsung Smart TV? You're not alone. Whether you're planning to binge “The Last of Us” or catch up on blockbuster movies, this guide shows you exactly how to install, log in, and start streaming HBO Max on a Samsung TV—quickly and correctly.
This step-by-step tutorial works for Samsung Smart TVs made in 2016 or newer, which run the Tizen operating system.
Compatible Samsung TV Models​
To install HBO Max, your Samsung Smart TV must:
  • Be manufactured in 2016 or later
  • Run on Tizen OS
  • Have access to the Samsung Smart Hub (the app store)
To check your model:
  1. Go to Settings > Support > About This TV
  2. Look for the Model Code
  3. The first two numbers after the letters usually indicate the year (e.g., Q80T is 2020)
How to Download HBO Max on Samsung Smart TV​
  1. Turn on your Samsung Smart TV and connect it to the internet (Wi-Fi or Ethernet).
  2. Press the Home button on your remote to open the Smart Hub.
  3. Navigate to Apps (bottom of the screen).
  4. Select the Search icon (magnifying glass) in the top-right corner.
  5. Type “HBO Max” into the search bar and select it.
  6. Click Install.
  7. Once installed, select Open to launch HBO Max.
How to Log in to HBO Max on Samsung TV​
  1. After launching the app, select Sign In.
  2. You'll see a 6-character code on your screen.
  3. On your phone or computer, go to hbomax.com/tvsignin.
  4. Enter the code displayed on your TV screen.
  5. Log into your HBO Max account (or sign up if you don't have one).
  6. Once authenticated, the app on your TV will refresh and grant access.
Having Trouble? Try This:​
1. App Not Found in the Store?​
  • Make sure your TV is 2016 or newer.
  • If it’s older, you can use a streaming device (Roku, Fire Stick, Apple TV) that supports HBO Max.
2. App Not Launching or Freezing?​
  • Go to Settings > Support > Device Care > Self Diagnosis > Reset Smart Hub.
  • Then re-install the app and try again.
3. Need to Update Your Samsung TV Software?​
  • Go to Settings > Support > Software Update > Update Now
Bonus Tip: Use AirPlay or Casting if App Isn’t Available​
If your Samsung TV is not compatible:
  • Use Apple AirPlay (iPhone/iPad):
    • Connect both devices to the same Wi-Fi.
    • Open HBO Max app, tap the AirPlay icon, and select your Samsung TV.
  • Use Chromecast (Android/Chrome):
    • Open HBO Max on your phone.
    • Tap the Cast icon and choose your TV from the list.
FAQs​
Can I get HBO Max on a 2015 or older Samsung Smart TV?​
No, the HBO Max app is not supported on Samsung TVs made before 2016. You’ll need an external streaming device.
Is HBO Max free with Samsung TVs?​
No, HBO Max requires a subscription. However, some Samsung promotions or carriers may offer a free trial.
How much does HBO Max cost?​
  • Standard: $9.99/month (with ads)
  • Ad-Free: $15.99/month
  • Ultimate Ad-Free: $19.99/month (includes 4K and downloads)
Final Thoughts​
Getting HBO Max on your Samsung Smart TV is quick if you own a supported model. Within minutes, you’ll be streaming high-quality shows, movies, and exclusive content. If your TV isn’t compatible, there are reliable workarounds like streaming devices or casting options.
