How to pair Dangbei Mars Pro remote?
LLLisa
Dangbei Mars Pro projector remote control is packed with the projector. It is compatible with 2 AAA batteries. When you get the Dangbei Mars Pro the first time, after turning on the projector and inserting applicable batteries on the remote, follow these steps and you will be able to pair Dangbei Mars Pro with its remote control successfully.
ㆍFirst, place the remote control within 10cm of the device.
ㆍThen, press the Home key and Menu key simultaneously until the indicator light on the remote flashing and hears a “Di” sound.
ㆍThis means that the remote control enters the pairing mode.
ㆍWhen a "DiDi" is heard, the connection is successful.
If pairing is unsuccessful, repeat the above steps after the remote control indicator light stops flashing. Dangbei Mars Pro remote control pairing is a must-have step when you use the projector for the first time, but you will find it easy with these tutorials.
