- 1 Quick Summary
- 2 Method 1: Use AirPlay to Pair iPhone with Smart TV (Wireless)
3
Method 2: Use iPhone Apps to Pair With Smart TV (As Remote)
- 3.1 Examples:
- 3.2 How to Use:
4
Method 3: Use a Lightning to HDMI Adapter (Wired Connection)
- 4.1 You’ll Need:
- 4.2 How to Connect:
- 5 Alternative: Use a Streaming Device (If Your TV Isn’t Smart)
- 6 Common Questions (FAQs)
- 7 Final Thoughts
Want to know how to pair your iPhone with a smart TV to stream videos, mirror your screen, or play music wirelessly? You're not alone. Whether you're using a Samsung, LG, Sony, or Roku TV, pairing your iPhone can unlock a more flexible and wireless entertainment setup — and it's easier than you think.
In this guide, I’ll show you exactly how to pair your smart TV with an iPhone, step by step — even if you’re not tech-savvy.
Most smart TVs made after 2018 support Apple AirPlay 2, including brands like:
If you want to control your smart TV with your iPhone, many TV brands offer official apps.
If your smart TV doesn’t support AirPlay, or you want a stable wired connection, use this method.
If you own a non-smart TV, or if your current TV doesn’t support AirPlay:
These devices allow you to pair your iPhone and stream directly to your TV wirelessly.
Pairing your smart TV with your iPhone lets you mirror your screen, stream apps, or use your phone as a remote. Whether you’re using AirPlay, a wired HDMI connection, or TV control apps, this guide has shown you all the ways to connect.
If you're having trouble, let me know your TV brand and model, and I’ll help walk you through it step by step!
Related Reading:
How to Mirror iPhone to TV: A Complete Guide for Seamless Streaming
How to AirPlay to TV: A Step-by-Step Guide for Seamless Streaming
Quick Summary
| Feature | Method | Requirements |
| Screen Mirroring | AirPlay | AirPlay-compatible TV or Apple TV |
| Streaming Video Apps | Cast or AirPlay from app | TV + same Wi-Fi network |
| Smart TV Remote | iPhone TV remote apps | Smart TV must support the feature |
| HDMI (Wired Option) | Lightning to HDMI adapter | HDMI cable + Apple adapter |
- Samsung
- LG
- Sony
- Vizio
- Roku TVs
- TCL (select models)
How to Pair via AirPlay (Wireless Screen Mirroring):
- Make sure your iPhone and Smart TV are on the same Wi-Fi network.
- On your iPhone, swipe down to open Control Center.
- Tap Screen Mirroring or AirPlay.
- Select your TV from the list of available devices.
- Enter the AirPlay code shown on your TV (if prompted).
- Your iPhone screen should now appear on your smart TV.
You can also stream videos from apps like YouTube, Netflix, and Apple TV directly by tapping the AirPlay icon inside the app.
Examples:
- Samsung SmartThings
- LG ThinQ
- Sony Bravia TV App
- Vizio SmartCast Mobile
- Roku App (Official Remote)
How to Use:
- Download the TV app from the App Store.
- Open the app and connect your TV (must be on the same Wi-Fi network).
- Use the app to browse apps, control volume, and navigate your TV.
hdmi-adapter-wired-connection" >Method 3: Use a Lightning to HDMI Adapter (Wired Connection)
You’ll Need:
How to Connect:
- Plug the Lightning adapter into your iPhone.
- Connect an HDMI cable from the adapter to your smart TV.
- Select the correct HDMI input on your TV.
- Your iPhone screen will automatically mirror.
Wired mirroring is great for gaming, presentations, and when Wi-Fi is unstable.
Buy one of these:
- Apple TV (best integration with iPhone)
- Roku Streaming Stick
- Amazon Fire Stick (with AirScreen app installed)
Can I pair my iPhone with my smart TV without Wi-Fi?
- Not wirelessly. You’ll need a Lightning to HDMI adapter to mirror without Wi-Fi.
Why doesn’t AirPlay show my TV?
- Make sure both devices are on the same Wi-Fi and that your TV’s AirPlay is enabled in settings.
Can I stream Netflix from iPhone to smart TV?
- Yes! Open the Netflix app, tap the AirPlay or Cast icon, and select your TV.
Final Thoughts
Related Reading:
