- 1 What You Need Before You Start
- 2 Method 1: Automatic Pairing for Genie Remotes (RC73, RC72)
- 3 Method 2: Manual Programming for Universal Remotes (RC66, RC65)
- 4 How to Reset Your DIRECTV Remote (If Needed)
- 5 Popular Smart TV Remote Codes
- 6 Pro Tips for Better Remote Control Experience
- 7 Summary: How to Program DIRECTV Remote to Smart TV
Looking to control your smart TV with your DIRECTV remote? Whether you're using a Samsung, LG, Vizio, or Sony TV, this guide will show you how to program your DIRECTV remote to your smart TV—fast and frustration-free.
This tutorial works with both DIRECTV Genie remotes (RC73, RC72) and Universal remotes (RC66, RC65).
This is the easiest way to connect your DIRECTV Genie remote to your smart TV.
Steps:
If you’re using an older or universal DIRECTV remote, follow this method.
Steps:
If things aren’t working as expected, reset the remote:
Once programmed, you can control your smart TV’s power, volume, and input using just your DIRECTV remote—no more juggling remotes.
- Your DIRECTV remote
- Your smart TV powered on
- Your DIRECTV receiver set up and running
- Optional: The 5-digit code for your TV brand (can be found on DIRECTV’s website)
Steps:
- Point the remote at your DIRECTV Genie receiver.
- Press and hold Mute + Enter simultaneously until the green light blinks twice.
- Your TV should display: “Applying IR/RF setup.”
- Once completed, your remote is in RF mode.
- Now press Menu > Settings > Remote Control > Program Remote.
- Choose your TV brand and follow the on-screen instructions to test volume and power functions.
If successful, your Genie remote should now control your smart TV’s volume, power, and input settings.
Steps:
- Slide the mode switch to “TV” at the top of the remote.
- Press and hold MUTE + SELECT until the green light flashes twice.
- Enter your TV’s 5-digit manufacturer code (e.g., Samsung: 10060, LG: 11423, Vizio: 11758).
- The light should flash twice again if the code was accepted.
- Test it: Try turning the volume up or powering off your TV.
If it doesn’t work, try another code from the DIRECTV remote code list.
- Press MUTE + SELECT until the green light flashes.
- Enter 981. The light will blink four times.
- Reprogram using one of the methods above.
Brand | Common Codes |
Samsung | 10060, 10814, 10702 |
LG | 11423, 10178, 11178 |
Vizio | 11758, 11756, 10120 |
Sony | 10000, 10810, 11317 |
- If you only want to control volume/power, programming to your TV is enough.
- To control additional devices (soundbar, DVD), repeat the same steps under a different mode.
- Make sure your batteries are fresh to avoid pairing issues.
Remote Type | Programming Method |
Genie (RC73) | Automatic setup via Menu |
Universal (RC66) | Manual code entry |
