I found a way to set up fire tv stick without remote. Share with you guys
If you don't have a remote control, you can use your smartphone to control the Firestick.
1. First, pick up your first phone, then go to the hotspot section, now you need to enter the SSID and password you used in the old WiFi network here.
2. After renaming, just open Hotspot and FireTV.
3. After turning on your TV, your TV will automatically connect to the hotspot, so connect your second mobile phone to the same WiFi at this time.
4. Here, you will be connected to the same IP address, so now open the Play Store or Apple Store, and then just download the Firestick Remote app.
5. Now you can control the Firestick directly from the second phone. Go to settings at this time and navigate to network settings. From here, find the new WiFi you want to connect to and enter the password.
That's it, now everything is complete, so you can now turn off the hotspot because we don't need it anymore. But please note that you must remember the old WiFi SSID and password for this. If there are any errors in this information, it will not be able to connect to it, so you must check my third method.
