Barend Ray
Active member
Keeping your Samsung Smart TV up to date is essential for optimal performance, improved security, and access to the latest apps and features. If you're wondering how to update Samsung Smart TV, this guide will walk you through every available method—including automatic updates, manual updates via settings, and updating via USB.
Updating your Samsung TV ensures:
Let’s dive into the update methods based on your preference and model.
Samsung Smart TVs can automatically download and install firmware updates when connected to the internet.
Steps:
If you'd like to check for updates manually:
Steps:
Note: The update process may take several minutes. Don’t turn off the TV or unplug it during the update.
If your TV isn't connected to the internet or the OTA update fails, updating via USB is your best option.
What You’ll Need:
Steps:
Your TV will scan the USB, install the firmware, and restart.
A: Typically 5–15 minutes depending on update size and internet speed.
A: No, updating the firmware won’t erase your apps or preferences.
A: No, your TV will restart during the update process and won’t be usable until the update is complete.
Knowing how to update Samsung Smart TV ensures your device stays fast, secure, and compatible with the latest content. Whether you prefer to update over the air or manually via USB, Samsung makes the process easy and user-friendly.
Pro Tip: Enable Auto Update to keep your TV always up to date without lifting a finger.
Why Should You Update Your Samsung Smart TV?
- Access to the latest Smart Hub features
- Improved app performance and compatibility
- Fixes for known software bugs or glitches
- Enhanced security and stability
How to Update Samsung Smart TV?
Method 1: How to Update Samsung Smart TV Automatically
Steps:
- Press the Home button on your remote.
- Go to Settings > Support > Software Update.
- Select Auto Update and turn it On.
From now on, your TV will automatically update when new software becomes available and the TV is turned on and connected to the internet.
Method 2: How to Update Samsung Smart TV Manually
Steps:
- Navigate to Settings > Support > Software Update.
- Choose Update Now.
- If a new version is available, your TV will start downloading and installing it immediately.
- Once done, your TV will restart with the latest firmware installed.
Method 3: How to Update Samsung TV via USB Drive (Offline)
What You’ll Need:
- A computer with internet access
- A USB flash drive (at least 1GB)
- Your Samsung TV’s model number (found in Settings > Support > About This TV)
Steps:
- Go to the official Samsung support website: https://www.samsung.com/support/
- Enter your TV model number and go to the Downloads section.
- Download the latest firmware file for your model.
- Extract the downloaded ZIP file to the root of your USB flash drive (not inside any folders).
- Insert the USB into your TV’s USB port.
- On your TV, go to Settings > Support > Software Update > Update Now.
- Select Update via USB and follow the on-screen instructions.
Troubleshooting Common Update Issues
No update option showing up?
- Make sure your TV is connected to a stable Wi-Fi network.
- Some older models may require updates via USB only.
TV stuck on “Searching for updates”?
- Restart your TV and try again.
- Try using a wired (Ethernet) connection instead of Wi-Fi.
USB not recognized?
- Ensure the USB drive is formatted as FAT32.
- Place the firmware file in the root directory, not inside a folder.
FAQs: Samsung Smart TV Updates
Q: How long does it take to update a Samsung Smart TV?
Q: Will updating delete my apps or settings?
Q: Can I use the TV while it’s updating?
