How's Haqu Q1max? Full specs & in-depth review!
adamnfool
Breaking the Budget Projector Mold: Haqu Q1 Max Redefines Value
The sub-$200 projector market has long been labeled as "just good enough." But the Haqu Q1 Max changes the game. Launched on May 9, 2025, this projector delivers 475 CVIA lumens brightness, true 1080P resolution, and AI-powered smart features—all packed into a sleek, portable design. Here’s a deep dive into its specs and performance:
Haqu Q1 Max Key Specs
Optics & Display
- RGB+B 4-channel LED for 125% sRGB color gamut (vibrant, accurate colors)
- 475 CVIA lumens brightness (great for daytime use with curtains)
- 2800:1 contrast ratio with deep blacks and no gray washout
- True 1080P resolution + 4K HDR10+ decoding
- EngineX sealed optical engine (prevents dust buildup)
Performance & Storage
- MT9-series chip (Antutu benchmark: 180,000+)
- 32GB eMMC 5.1 storage (apps launch 60% faster)
Smart Features
- AIVISION 3.0 system with 0.3s autofocus
- Full auto keystone correction (±45°)
- Auto obstacle avoidance & screen alignment
- Ambient light adaptation (adjusts brightness for day/night use)
- Dangbei OS 4.0 (6,000+ apps supported)
Connectivity
- Dual HDMI 2.1 (120Hz input for gaming)
- USB 3.0 (plays 8K video files directly)
- Wireless casting (Huawei Cast+, DLNA, NFC 28ms low-latency)
Audio
- 2×5W neodymium speakers
- DTS-HD decoding (92dB sound pressure, <1% distortion)
Battery & Charging
- 9,800mAh battery (3 hours offline playback)
- 65W PD fast charging (90-minute full charge)
Haqu Q1 Max Hands-On Review
Design & Portability
- Compact all-in-one body (6.4" × 7.5" × 10.8", 6.3 lbs)
- Matte finish + two-tone design (premium look)
- Adjustable gimbal stand (-15° to 135° tilt, 20,000+ rotation tests)
Picture Quality
- Bright enough for daytime (100-inch image stays clear with sheer curtains)
- 90% brightness uniformity (no hotspots)
- AI color enhancement (accurate tones, no overblown highlights)
Smart Features in Action
- Auto setup takes <10 seconds (focus, keystone, obstacle avoidance)
- Dynamic recalibration when moving the projector
- Night mode reduces blue light for eye comfort
Performance & Gaming
- Zero lag with 4K HDR playback (4 hours tested)
- 15ms input delay in Game Mode (no motion blur)
Audio & Battery Life
- Rich, theater-like sound (DTS-HD enhances movies)
- 3-hour battery (great for camping/backyard movies)
Final Verdict
The Haqu Q1 Max punches above its price tag, offering portability, sharp visuals, smart automation, and smooth performance. Ideal for:
- Budget-conscious families
- Casual gamers
- Frequent travelers who need a portable big screen
A true game-changer in the sub-$200 projector market.
