How's Haqu Q1max? Full specs & in-depth review!
mattsimis
Breaking the Budget Projector Mold: Haqu Q1 Max Delivers Premium Performance
In the projector market, budget models under $150 are often seen as "just good enough." But the Haqu Q1 Max changes the game. Launched on May 9, 2025, this projector redefines value with its 475 CVIA lumens brightness, native 1080P resolution (4K decoding), and proprietary AI-powered imaging tech—all packed into a fully sealed optical engine.
Starting at just $109 (with subsidies bringing it down to $87), here’s a deep dive into its specs and performance:
Haqu Q1 Max Key Specs
Optics:
- LED light source + LCD display
- 475 CVIA lumens (JD-certified, no false claims)
- 2800:1 contrast ratio
- True 1080P resolution (supports 4K decoding)
- EngineX sealed optical engine: 50% brighter + 50% sharper than conventional designs
- AI ColorBoost tech: Vivid, accurate colors with deep blacks and no overblown highlights
Hardware & Storage:
- Flagship MT9-series chip (found in high-end TVs)
- 32GB storage for snappy performance
- 5-second boot time, low-latency gaming mode, and Wi-Fi 6 for smooth streaming
Smart Features:
- Dangbei OS with full DeepSeek AI integration
- Voice control (high accuracy, multi-language support)
- Auto focus, keystone correction, obstacle avoidance, and screen alignment
- Ad-free casting (AirPlay/DLNA/Lebo/Dangbei protocols supported)
Connectivity & Audio:
- Ports: USB, HDMI, Audio out
- 6W speakers for immersive sound
- <26dB noise level (quiet operation)
Haqu Q1 Max Hands-On Review
Design & Portability:
The Q1 Max features a sleek all-in-one design with a built-in power adapter, measuring just 6.4" × 7.5" × 10.8". The matte white finish looks premium, while its adjustable gimbal stand allows ceiling projection or flexible angle adjustments.
Image Quality:
With 475 CVIA lumens, it outperforms most budget projectors:
- Watchable in daylight (with sheer curtains) on a 100-inch screen
- Brighter, more uniform at night
- All-glass lens + AI ColorBoost: Natural colors, no grayish blacks, and balanced highlights
Smart Features:
- AI auto-calibration adjusts focus/correction in real time when moved
- SGS-certified low blue light for eye protection
Performance:
- MT9 chip + 32GB storage ensures smooth operation
- Low input lag in gaming mode (no motion blur)
Entertainment:
- Rich content library (Tencent, iQiyi, Youku, MangoTV, Bilibili)
- 6W speakers enhance movie immersion
Verdict
The Haqu Q1 Max punches above its price tag, offering portability, sharp visuals, smart features, and lag-free gaming—ideal for budget-conscious families, casual gamers, and mobile users.
