- 1.1 Unboxing Experience
- 1.2 Display
- 1.3 Viewing Experience
- 1.4 Features
- 1.5 System Experience
- 2 Conclusion
Parameter | Magcubic HY300PRO Mini Projector | PONER SAUND Mini Projector | ear&ear HY300 Mini Projector |
Picture | |||
Reference Price | $86.99 | $48.88 | $59.99 |
Recommended Uses | Education, Movie Night | 家庭影院,教育,游戏 | Education, Home Cinema, Gaming, Business |
Built-In Media | User Manual, Remote, Adapter | remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable | User Manual, Power Cord, Remote |
Highlight | System Update Requirement: Manual update to the latest version recommended Built-in Apps: Access to 1,000,000 videos without external TV stick Control Type: Air Mouse remote with traditional remote and mouse functions, voice command support Resolution: Native 720P with 4K support Brightness: 200 ANSI lumens, 10000:1 contrast ratio Use Case: Suitable for casual use in various settings (bedroom, outdoor, living room) Design Features: Versatile mounting options (ceiling, table, tripod), 180-degree rotation, portable for home and travel | Wireless Connection: Multi-screen interaction, compatible with iOS and Android, no extra cables needed Resolution & Brightness: 1280x720P native resolution, 1920x1080P supported, 5500 lumens, 5500:1 contrast ratio Aspect Ratio: 16:9 / 4:3 Screen Size: 40” to 210” Projection Distance: 5ft to 15ft, recommended at 6.5ft Size & Weight: 7.87*5.90*2.95 inches, 2.5 lbs Speaker: Built-in powerful speaker Connectivity: HDMI, USB, AV, headphone Additional Features: Lifetime customer service | Operating System: Android TV 13.0 Resolution Support: 1080P/4K Brightness: 160 ANSI lumens Contrast Ratio: 1500:1 GPU: Mali-G31 Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks Audio Technology: 360-degree surround sound Keystone Correction: Auto and manual focus adjustment Projection Flexibility: 180° free rotation for wall, ceiling, or floor projection Noise Level: Below 25 dB Ports: HDMI, USB, audio ports Content Library: Over 500,000 movies and TV shows available |
Unboxing Experience
Magcubic HY300PRO Mini Projector:
When I first laid eyes on this projector, I was pleasantly surprised by its compact and lightweight design. It's portable enough for easy travel, which is a huge plus for anyone looking to use it on the go. The overall aesthetic is simple yet functional, making it a suitable addition to any media setup. However, the build quality feels somewhat modest, and while it won't win any design awards, it certainly serves its purpose without being an eyesore.PONER SAUND Mini Projector:
Upon first glance, the Poner Saund Model M8 projector stands out as an attractive and well-constructed device. It has a slightly bulkier design compared to my previous ViewSonic model, but its solid build quality suggests durability. The projector features multiple legacy connections as well as HDMI ports, which is a huge plus for my installation. The visible mounting screws are a bit of a design flaw, but at least they allow for ceiling mounting when the rubberized pads are removed. Overall, it definitely gives off a professional vibe that belies its budget-friendly price tag.ear&ear HY300 Mini Projector:
Upon unboxing the UP portable projector, I was immediately struck by its compact and stylish design. It has a sleek aesthetic that makes it visually appealing, fitting seamlessly into both home and office environments. The device is lightweight, which adds to its portability, allowing me to easily carry it in a bag for movie nights or presentations. Overall, the design is not just about looks; it feels well-built with high-quality materials, making it a practical choice for frequent use.Display
Screen Size | 40 Inches - 150 Inches | 40 Inches - 100 Inches | 40 Inches - 130 Inches |
Throw Distance | 0.9 Meters - 4 Meters | 5 Feet - 15 Feet | 30 - 130 |
Contrast Ratio | 10000:1 | 5500:1 | 1500:1 |
Maximum Resolution | 1980 x 1080 Pixels | 1280 x 800 | 4096 x 2160 |
Native Resolution | 1280 x 720 | 1280 x 800 | 1280 x 720 |
Brightness | 8000 Lumen | 5500 Lumen | 160 Lumen |
Display Type | LCD | LCD | LED |
Viewing Experience
The viewing experience was a mixed bag. On one hand, the picture quality is impressive given the price, producing a clear and vivid image when viewed in a dark room. I found that my optimal setup allowed for a 7 x 4-foot display, which looked fantastic. However, the brightness is lacking, and the projector struggled in moderately lit environments. Additionally, the sound quality left much to be desired, often requiring external speakers to enhance the audio experience, which detracted from the overall enjoyment.PONER SAUND Mini Projector:
The viewing experience on this projector is impressive, especially when utilized in a darkened room. The image quality is sharp, and the X-Y zoom adjustment helps in reducing the massive output to fit my screen perfectly. The 4-point keystone adjustment is another feature that simplified the setup process. While I did notice some lag when using RCA inputs for sound, switching to HDMI resolved the issue. The built-in speakers are surprisingly adequate for casual viewing, though for outdoor movie nights, connecting to a soundbar significantly enhances the audio experience. The projector's brightness does drop when projecting onto a white wall during the day, but it still performs well in less-than-ideal lighting conditions.ear&ear HY300 Mini Projector:
I was genuinely impressed with the viewing experience offered by the UP projector. The image quality is bright and detailed, even in rooms with some ambient light. It supports high resolutions like 4K and 1080P, which is remarkable for such a compact device. The automatic keystone correction feature worked flawlessly, ensuring that the image was perfectly aligned regardless of the projection angle. Whether I was watching movies, gaming, or giving presentations, the visuals were consistently sharp and vibrant, creating an enjoyable viewing experience.Features
Other Features | Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi | Wireless, Portable, Built In Wi Fi | Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player |
Video Encoding | AVC | 1080P | AVC |
LightSource Life | 20000 Hours | 52000 Hours | - |
Controller Type | Remote Control, Voice Control | Remote Control | Remote Control |
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI | wireless(Wi-Fi)/wired, HDMI, USB, AV, TF | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack |
Compatible Devices | Laptop, Gaming Console, Smartphone | ios system, android system | Laptop, Tablet, Smartphone, Speaker |
Wattage | - | 60 watts | - |
Mount Type | Tabletop Mount | table, tripod, ceiling (mount not included) | Tabletop Mount |
L x W x H | 12"L x 6"W x 10"H | 7.87"L x 5.9"W x 2.95"H | - |
Setting up the projector was relatively straightforward, and I appreciated that it came equipped with essential features like Bluetooth connectivity and HDMI ports. However, the user interface proved to be a bit cumbersome and not as intuitive as I would have liked. While I managed to connect it to various streaming apps, I encountered difficulties, especially with Netflix and other popular platforms. It seems that some extra patience is required to navigate through the setup process, but once everything is in place, it functions adequately.PONER SAUND Mini Projector:
Setting up the Poner Saund Model M8 was generally straightforward, although I did encounter some initial challenges. The dimensions of the mounting points were not readily available during my research, which led to some confusion. However, the compatibility of the screw threads made it easier to adapt my homemade ceiling mount. The menu system is a bit clunky; while it ultimately allows me to access the necessary features, it does take some getting used to. Once I figured out the setup, I was able to connect my ROKU box easily via HDMI, and I appreciated the multiple connection options for various devices, albeit some settings required a bit of trial and error.ear&ear HY300 Mini Projector:
The setup process for the UP projector was refreshingly straightforward. I was able to connect it to my devices with ease, thanks to various connectivity options such as HDMI and USB. The controls are intuitive, eliminating the need to sift through lengthy manuals. I appreciated that it didn't require any additional equipment, such as a tripod, and I could get started in no time. The built-in remote made navigating settings and selecting content a breeze, which is a huge plus for someone who values convenience.Conclusion
Pros:• Lightweight and portable design
• Excellent picture quality in dark settings
• Affordable price point
• HDMI and Bluetooth connectivity
• Easy to set up
• Limited brightness; best used in dark rooms
• Poor sound quality without external speakers
• Difficult navigation and connectivity issues with streaming apps
• User interface needs improvement
• Short power cord
Overall, this projector has its strengths, particularly its portability and decent picture quality for the price. However, it also has significant drawbacks, including sound performance and app connectivity issues that can be frustrating. While it might not be the centerpiece of a high-end home theater setup, it proves to be a decent solution for casual movie nights or on-the-go presentations. For the budget-conscious consumer, it’s a reasonable option, but I would recommend doing thorough research to ensure it meets your specific needs before making a purchase.
Pros:• Affordable price range with excellent features.
• Good image quality, especially in dark rooms.
• Multiple connection options, including HDMI.
• Adjustable keystone and zoom settings.
• Decent built-in speakers for casual use.
• Clunky menu system can be confusing.
• Limited brightness for daytime viewing.
• Some users experience lag with certain inputs.
• Fan noise is noticeable at 48db.
• Requires careful placement for optimal focus.
Overall, I am quite satisfied with my purchase of the Poner Saund Model M8 projector. It has proven to be a fantastic entry-level option for family movie nights and casual gaming. Despite its minor flaws, such as the lag with RCA inputs and the noticeable fan noise, the projector delivers excellent picture quality and versatility for the price. I appreciate the thoughtful features like the adjustable keystone correction and the variety of input options. This projector has successfully replaced my old ViewSonic and has quickly become a staple in my entertainment setup. Given its performance and affordability, I would highly recommend it to anyone looking for a budget-friendly projector.
Pros:• Compact and lightweight design
• Easy and intuitive setup
• Bright and detailed image quality
• Supports various connectivity options (HDMI, USB)
• Automatic keystone correction
• Built-in speakers could be improved
• Requires a full Netflix subscription for streaming
Overall, the UP portable projector exceeded my expectations in terms of performance and portability. It's a versatile device that works wonderfully for home entertainment, business presentations, and even for entertaining kids in their rooms. The combination of user-friendly features, impressive image quality, and stylish design makes this projector an excellent choice for anyone in the market for a reliable mini projector. I highly recommend the UP for those seeking a compact and powerful projector without compromising on quality or convenience.
