- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The Optoma GT2000HDR boasts a compact and modern design, fitting comfortably in smaller spaces without compromising on aesthetic appeal. It is lightweight, making it easy to mount or reposition as needed. Its understated style allows it to blend seamlessly into various environments, whether as part of a home theater setup or a golf simulator arrangement. Overall, it conveys a professional look that is both practical and visually pleasing.Introduce
| Parameter | Optoma GT2000HDR Projector |
Reference Price | $1199 |
Built-In Media | User Manual, Power Cord, Battery, Remote |
Highlight | DEPENDABLE LASER LIGHT SOURCE: DuraCore laser light technology eliminates lamp and filter replacements for up to 30,000 hours of virtually maintenance-free operation. IPX6 dust resistance rating ensures optical engine durability SHORT THROW LENS: Experience a 120" (10 foot) image projected from just 4' 4" away. It's great for smaller spaces and allows for easier installation 1080P HD RESOLUTION: Displays sharp and detailed 1080p (1920x1080) high definition content without downscaling or compression ENHANCED GAME MODE FOR LIGHTNING FAST RESPONSE TIME: Delivers low input 4K60Hz @ 1080p60Hz 17ms, 8ms @ 1080p120Hz, 16ms @ 1080p60Hz 4K HDR INPUT AND 300,000:1 CONTRAST RATIO: HDR10 and HLG support provides rich cinematic color, brighter whites and deeper blacks, and Dynamic Black delivers a stunning 300,000:1 contrast radio |
Screen Size | N/A - 3E+2 Inches |
Throw Distance | 1 Meters - 10 Meters |
Contrast Ratio | 300,000:1 |
Brightness | 3500 Lumen |
Display Type | Laser |
Viewing Experience | The viewing experience with this projector has been exceptional. With a brightness of 3,500 lumens, the image remains bright and clear even in rooms with ambient light, which is crucial for activities like using a golf simulator. Colors are vibrant, and the clarity is impressive, especially when watching movies or playing games. The low input lag is particularly beneficial for gaming, ensuring a smooth and responsive experience that enhances overall enjoyment. |
Lamp Wattage | 210 Watts |
Wattage | 98 watts |
Hardware Connectivity | USB, HDMI, 3.5mm Audio |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone |
Other Features | Low Power Consumption, Ultra-Compact, Laser Light Source, Short Throw |
L x W x H | 4.49"L x 10.79"W x 8.5"H |
System Experience | Setting up the Optoma GT2000HDR was a breeze. The intuitive design meant I didn’t need to consult the manual, as I could easily connect it to my devices via HDMI. Keystone adjustments were straightforward, allowing for fine-tuning without a hassle. The compact size of the projector made it easy to position and adjust according to my needs, ensuring I could achieve the desired projection size without difficulty. |
User Feedback
Pros:• Bright and clear image even in ambient light
• Easy to set up and use
• Compact and lightweight design
• Low input lag for gaming
• Supports 4K HDR input
• Built-in speaker quality is subpar
• Lack of optical zoom may complicate positioning
• Some users reported color calibration difficulties
• Limited adjustment options for mounting
After over a year of use, I can confidently say that the Optoma GT2000HDR is an outstanding projector that delivers on its promises. It excels in bright environments, offers an immersive viewing experience, and is user-friendly, even for those less tech-savvy. While the built-in speaker leaves much to be desired, using an external audio solution easily mitigates this issue. Overall, I would highly recommend this projector for anyone seeking a versatile and high-performing option for both gaming and home theater applications.
