PANSEBA Mini Projector vs HAPPRUN vs AKIYO: Which Compact Projector Offers the Best Sound Quality?
Barend Ray
Active member
PANSEBA Mini Projector​
HAPPRUN Projector​
AKIYO Mini Projector​
$79.99​
$79.99​
$55.99​
Home Cinema​
Indoor/Outdoor​
Indoor/Outdoor​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
1*Power Cord, 1*Remote, 1*HAPPRUN 1080P Projector, 1*HDMI Cable, 1*AV Cable​
Projector Stand​
Bluetooth Version: 5.2
Speaker Type: HIFI built-in
Screen Size: Up to 200 inches
Contrast Ratio: 8000:1
Resolution: 1080p
Brightness: 50% brighter than similar projectors
Clarity Improvement: 50% clearer images than similar projectors
Noise Level: Low noise
Lamp Life: 50,000 hours
Device Compatibility: Laptops, smartphones, tablets, USB drives, Xbox
Connection Requirement for Smartphones: HDMI adapter cable (not included)
iOS Connection: Lightning to HDMI adapter required (not included)
Android Connection: MHL support needed; otherwise, requires Chromecast
Usage Recommendation: Not compatible with Hulu via mirrored projectors
Native Resolution: 1920*1080 Full HD
Brightness: Excellent
Contrast Ratio: 10000:1
Bluetooth Version: 5.1
Built-in Speakers: Hi-Fi Stereo
Projection Size: 47"-200"
Projection Distance: 6.8-16.4 feet
Keystone Correction: 15°
Zoom Capability: 75%
Connectivity Ports: HDMI, USB (x2), AV, 3.5mm headphone jack
Compatibility: Fire TV Stick, Roku, DVD, Laptop, USB Flash Drive, Computer, Headphone, External Speaker, smartphones, Android, Apple iPad, PS5, PS4
Included Accessories: Native 1080P projector, AV Cable, HDMI Cable, Remote, User Manual
Connection Type: P2P Direct Connection, No WiFi Required
WiFi/Bluetooth: 5G/2.4G dual-band WiFi, Bluetooth 5.2
Resolution: Native 720P (1280x720), Full HD 1080P supported
Brightness/Contrast: 200 ANSI brightness, 2000:1 contrast ratio
Size/Weight: 5.35x4.33x2.28 in, 420 grams
Keystone Correction: ±50° electronic vertical keystone
Zoom: 50% zoom function
Projection Size/Distance: 32-120 in, optimal distance 3.28-9.84 ft
Input Interfaces: HDMI, USB, 3.5mm audio output
Warranty/Support: 2-year warranty, 24H customer service available
Unboxing Experience​
PANSEBA Mini Projector:​
The mini projector boasts a sleek and compact design that is both aesthetically pleasing and functional. Its lightweight build makes it highly portable, allowing me to easily transport it for movie nights or presentations. The included screen, while somewhat thin, adds an extra touch of convenience, enhancing the overall visual experience. Despite being small, the projector manages to pack a punch in terms of appearance, making it a stylish addition to my entertainment setup.
HAPPRUN Projector:​
The Happrun projector presents a sturdy and stylish design, slightly larger than many competing models. It features a well-constructed body that houses a larger lens, contributing to an overall better picture quality. Its aesthetic is modern, and despite being somewhat bulkier, it remains portable, making it suitable for various settings. The remote control, however, feels a bit cheap, which detracts slightly from the overall impression of quality.
AKIYO Mini Projector:​
The projector presents itself as a compact and unassuming device, making it easy to transport and position in various settings. Its lightweight design is complemented by a sleek form factor that doesn’t take up much space, making it a perfect fit for both casual movie nights and more serious presentations. The included tripod enhances its usability, allowing for a more stable setup. Overall, I find it to be an attractive option for those looking for a low-profile projector that still packs a punch in terms of performance.
HAPPRUN Projector​
32 Inches - 200 Inches​
47 Inches - 200 Inches​
32 Inches - 120 Inches​
2.65 Feet - 26.25 Feet​
2 Meters - 7 Meters​
0.6 Meters - 4 Meters​
8000:1​
10000:1​
5000:1​
1980 x 1080 Pixels​
1920 x 1080 Pixels​
1920*1080 Pixels​
1280 x 720​
95 Lumen​
5500 Lumen​
LED​
LED​
High Contrast Ratio and Full HD Resolution​
Not Specified​
The picture quality is surprisingly sharp for a mini projector, with vibrant colors and decent brightness levels, even in semi-lit conditions. It supports Full HD 1080p resolution, which enhances the overall viewing experience, especially during movie nights. While the built-in speaker is decent for casual use, connecting to external Bluetooth speakers significantly elevates the audio experience, providing a more immersive atmosphere for watching films or playing games.
HAPPRUN Projector:​
The viewing experience is impressive for a budget projector. The image quality features vibrant colors and sharp details, particularly in a darkened room. It performs admirably even in moderately lit conditions, providing a theater-like experience. However, some corners may appear slightly soft, and achieving a perfectly focused image requires careful alignment, especially since horizontal keystone adjustment is lacking.
The picture quality is impressive for a projector in this price range, particularly when viewed in dimmer conditions. I was pleasantly surprised by the clarity and brightness when the lights were off. However, the experience can be inconsistent depending on the content source and the connection method. For best results, a direct HDMI connection seems to reduce lag and improve overall picture quality. While the projector can handle outdoor settings well, the brightness does diminish in brightly lit environments, which may detract from the viewing experience.
HAPPRUN Projector​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
1920*1080 Native Full HD, 47"-200" Projection Size For All Rooms, Native Full HD 1080P, Bluetooth 5.1 & Bulit-in Speaker, Zoom 75%--100%​
H.264 or MPEG-4 AVC​
H.264 or H.265​
AVC​
200 Watts​
3 Watts​
50000 Hours​
100000 Hours​
55000 Hours​
Button Control​
App​
Wireless​
TV Stick, Smartphone, USB, SD Card​
55 watts​
70 watts​
38 Watt-hours​
Mount Type​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
Ceiling Mount/Tripod Mount/Table Mount​
Tabletop Mount​
7.28"L x 5.98"W x 2.95"H​
9.3"L x 8.1"W x 3.5"H​
5.35"L x 4.33"W x 2.28"H​
Setting up this projector was incredibly straightforward; I was able to get it running in under three minutes. It features multiple connectivity options including HDMI, USB, and supports wireless connections, which made pairing it with my streaming devices like Roku and Firestick seamless. The user interface is intuitive, resembling a basic tablet setup that my kids can operate with ease, making it user-friendly for the whole family.
HAPPRUN Projector:​
Setting up the projector is a breeze; it’s plug-and-play and user-friendly, allowing for quick adjustments of focus and tilt. The presence of a standard tripod screw hole at the bottom enhances its portability, making it easy to mount on a tripod or light stand. The projector remembers settings when powering on through HDMI, eliminating the need for a second remote, which is a significant advantage compared to other brands.
Setting up the projector has been a straightforward process, as I found the manual easy to follow. The connections are versatile, allowing for HDMI, USB, and wireless options. However, I did encounter some issues when trying to connect newer devices that only utilize USB-C ports, which required an adapter to connect via HDMI. The projector's compatibility with a variety of devices—including laptops, tablets, and gaming consoles—makes it quite versatile, though I did experience some hiccups when using certain streaming apps and devices.
• Impressive picture quality for a compact device.
• Easy setup and user-friendly interface.
• Lightweight and portable design.
• Versatile connectivity options (HDMI, USB, Bluetooth).
• Included projector screen enhances viewing experience.
• Excellent sound quality when paired with external speakers.
• Limited brightness in well-lit environments.
• Built-in speaker lacks depth and clarity compared to external options.
• Slight latency with Bluetooth audio; can be tricky to connect to mobile devices.
• The included screen is somewhat transparent, requiring a smooth, flat surface for optimal results.
Overall, this mini projector has exceeded my expectations, delivering great value for its price. It’s perfect for casual movie nights, outdoor use, or even small presentations. Despite a few minor drawbacks, such as the need for external audio for a fuller sound experience and brightness limitations in daylight, the portability, ease of use, and impressive picture quality make it a fantastic choice for anyone seeking an affordable yet effective projection solution. Highly recommended for those looking to enhance their home entertainment setup without breaking the bank!
HAPPRUN Projector:​
• True 1080 HD resolution with vibrant colors and sharp details.
• User-friendly setup with quick adjustments for focus and tilt.
• Lightweight and portable design compatible with tripods.
• Bluetooth connectivity for audio output.
• Excellent customer service and support.
• Limited keystone adjustment can lead to focus issues.
• Remote control feels cheap and lacks some functionality.
• Fan noise can be noticeable, especially in quiet environments.
• Requires a dark room for optimal viewing quality.
Overall, the Happrun projector offers exceptional value for its price, delivering a solid performance that surpasses expectations for budget options. While it does have its drawbacks, particularly regarding keystone adjustment and fan noise, the stunning image quality, straightforward setup, and portability make it an excellent choice for anyone looking to replace a TV or enjoy a cinematic experience at home. If you're on a budget, this projector is a worthy investment that won't disappoint.
• Good picture quality for the price
• Compact and portable design
• Easy to set up and connect to multiple devices
• Customer service is responsive and helpful
HDMI connection offers a stable viewing experience
• Built-in speakers are not powerful; external speakers recommended
• Connectivity issues, particularly with newer devices
• Brightness can be insufficient in well-lit settings
• Some video formats may not be compatible, requiring specific file types
Overall, my experience with this projector has been positive, especially considering its affordable price point. It offers a great balance of performance and convenience for casual viewing, making it ideal for movie nights or gaming sessions. While there are some limitations, particularly regarding sound quality and connectivity with certain devices, the projector has proven to be a valuable addition to my setup. The exceptional customer service provided by the company also adds to the overall satisfaction, giving me confidence in my purchase.
Wwalmarts
HAPPRUN Projector gives you a great picture and decent sound (could be better, but it’s cool for a regular room). Super easy to set up.
Skip trying to connect it with Apple stuff—it's a hassle. But overall, it’s a solid choice for movies and gaming, perfect if you don’t want a TV taking up space!
69Shelby1969
HAPPRUN Projector has totally taken over my TV! The picture is awesome and it can fill up an entire wall. I just hook it up to my Firestick for all my shows. Plus, it's super portable! Totally worth the money!
I’ve had the HAPPRUN Projector for about a year now, and I’m super happy with the quality for the price. Plus, their customer support is awesome! I had a problem with my remote, and they got back to me right away!
Gizmoitus
AKIYO Mini Projector is awesome! I've been using it every night for a month, super easy to set up. Only downside is the plastic thumb nut strips fast, but just swap it for a 1/4 20 nut and you're good to go!
