cullypants
- 1 Specs
- 2 Which to get
In the world of smart TVs, two contenders stand out: the Philips 7900 Series and the Roku Plus Series. On one side, you have the Philips 7900, boasting a vibrant 4K QLED display with Dolby Vision and HDR10 support, designed to immerse you in a cinematic experience. It promises not just color depth but also a sound experience that aims to elevate your movie nights with Dolby Audio.
On the other hand, the Roku Plus Series TV takes a different approach. It emphasizes a user-friendly streaming experience, crafted by the brand synonymous with easy access to your favorite shows and movies. This model offers 4K resolution and an auto brightness feature that adjusts to your room's lighting, ensuring you always have the best viewing conditions without the hassle of manual adjustments.
So, which TV truly delivers on its promise? Is it the high-tech, immersive options of the Philips, or the intuitive, value-driven design of the Roku? Let’s dive deeper into these two options to see which one is worth your investment.
The Philips boasts a 4K QLED display which sounds amazing for color depth and clarity, plus it has Dolby Vision & HDR10 for that extra pop in picture quality. The mention of Dolby Audio also has me curious about sound quality—definitely a plus for movie nights!
On the flip side, the Roku Plus is all about that user-friendly experience. It’s designed for easy streaming and offers breathtaking 4K resolution with auto brightness adjustments, which seems super convenient. But is the sound quality on par with the Philips?
Potential downsides? I’ve heard some say the Philips might have a higher price tag, while others think the Roku, being a smart TV, might be limited in terms of picture quality compared to a more specialized brand like Philips.
Would love to hear your thoughts! Which one would you recommend based on picture quality, sound, and overall system performance? Thanks!
Specs
Parameter | Philips 7900 Series TV | Roku Plus Series TV |
Screen Size | 50 Inches | 55 Inches |
Reference Price | - | - |
Model Year | 2023 | 2023 |
Specific Uses | home entertainment, streaming, and gaming | Home viewing, indoor environments |
Highlight | 4K QLED display allows for a greater color range and depth Dolby Vision & HDR10 support brings you closer to reality Dolby Audio for the ultimate movie experience | The smart TV that makes sense: Roku Plus Series TVs are thoughtfully designed by Roku to give viewers a premium entertainment experience at an incredible value. Made by Roku: From the brand you trust to make streaming easier comes a thoughtfully designed 55-inch smart TV powered by the delightfully simple Roku experience. Breathtaking 4K & auto brightness: Stunningly sharp 4K resolution brings out the rich detail in your entertainment. Avoid fiddling with settings with a screen that automatically adjusts based on your room’s lighting. |
Operating System | Roku OS | Roku OS |
Internet Applications | Netflix, HBO Max, Hulu, YouTube | Netflix, Disney Plus, Prime Video, Hulu, Apple TV |
Remote Control | Infrared | Bluetooth |
Controller Type | Remote Control, Voice Control ตอไป | Remote Control, App Control, Voice Control |
Control Method | App | App |
Aspect Ratio | 16:9 | 16:9 |
Display Technology | QLED | QLED |
Screen Finish | Flat | Flat |
Has Color Screen | - | Yes |
Resolution | 4K | 4K |
HDR Format | HDR10, Dolby Vision | HLG, HDR10+, Dolby Vision |
Backlight Setting | LED | Dimming |
Picture Enhancement | Dynamic contrast, 120 PMR, HDR10, Dolby Vision | QLED, Dolby Vision, HDR10+, and auto brightness |
Motion Enhancement | Perfect Motion Rate (PMR) 120 | - |
Audio Channels | 2.0 | 4.1 |
Audio Output | Dolby | Dolby Atmos |
Audio Input | HDMI | HDMI, USB, Optical |
Speaker Description | Stereo sound system, 2 x 10W output power (RMS) | Enhanced audio speakers with Dolby Atmos and Dolby Audio support |
Surround Sound | Dolby Audio | Dolby Atmos |
Video Encoding | HEVC | HEVC |
Screen Mirroring | Miracast | AirPlay 2, Miracast |
Water Resistance | - | Not Water Resistant |
Compatible Devices | - | Devices with USB, HDMI, Ethernet, or Wi-Fi connectivity |
Tuner Type | ATSC | ATSC |
Voltage | 120 Volts | - |
Line Voltage | - | 110 VAC 60 Hz |
Other Features | Smart TV | Bezel-Less Design, Local Dimming, HDR10+, Ambient Light Sensor, Dolby Vision |
D x W x H | 3.4"D x 25.4"W x 43.8"H | 10.1"D x 48.4"W x 31.1"H |
Connectivity Technology | Wi-Fi, HDMI | Wi-Fi, USB, Ethernet, HDMI |
Bluetooth Version | - | 5.2 |
Wireless Technology | Wi-Fi | Bluetooth, Wi-Fi |
Usb Ports | - | 1 |
HDMI Ports | 4 | 4 |
Connector Type | HDMI | Ethernet, HDMI, USB, Wi-Fi |
Signal Format | ATSC | digital, analog |
Which to get
Looking to upgrade my TV and torn between two options: the Philips 7900 Series TV and the Roku Plus Series TV.The Philips boasts a 4K QLED display which sounds amazing for color depth and clarity, plus it has Dolby Vision & HDR10 for that extra pop in picture quality. The mention of Dolby Audio also has me curious about sound quality—definitely a plus for movie nights!
