Projector Maintenance and Care: How to Use Projector Correctly?
Elena
How to use your projector correctly? This article will show you the maintenance and care for your projectors.
As a professional display device, the projector has an internal collection of chips, circuits and other precision devices, which should be used with relative care. After a period of use, the projector may experience a decrease in brightness and, in serious cases, unclear images.
This situation, on the one hand, maybe the normal decay of lamp life, on the other hand, maybe the daily use of the wrong operation caused by. In daily use, we should pay attention to the use of the projector and protection maintenance.
How to Use Projector Correctly?​
When you turn on the projector, it is in the start-up state, it is best to wait patiently until the indicator light stops flashing and the screen is fully lit before proceeding to the next step.
As the projector begins to work, the internal temperature will gradually rise. In the power-on state, it is best to keep the projector stationary, especially with projection products that use traditional lamps, serious shaking, which may risk blowing up the lamp.
In case of a sudden power failure in use and you need to start it up again, wait a bit at this time. Because the temperature of the equipment is high at this time, it is best to wait for the projector to cool down completely before turning it on again.
In addition, the projector should not be used for a long time, especially when the indoor ambient temperature is high, and the time of use should be controlled.
When you turn off the projector, do not cut off the power immediately, the projector's fan will continue to dissipate heat and you need to wait until the fan stops operating and the light stops flashing before cutting off the power.
There are also more details that require attention during the use of projectors.
1. Using the projector's original cord.
2. Storing the projector in a dry place.
3. Paying attention to dust control.
4. Keep away from high-temperature places when using.
5. Do not repair or open the machine by yourself.
6. Cut off the power when not in use.
7. Allow the projector to cool after use.
8. Hold and place the projector gently when moving.
In addition to these, keeping the lens clean, keeping the air inlet and outlet open, and replacing the filter regularly are also aspects to be aware of.
At present, in some of the projectors with new light sources, in terms of ease of use, durability, there has been a great improvement, but it is recommended that users still need to be careful when using.
