Repair method for broken TV capacitor
Graceli
What if your TV capacitor is broken? What are the TV repair methods? Here will provide you with possible repair methods for broken capacitor.
What are TV capacitors?​
Capacitors act as reservoirs of electrical charge, storing and releasing electricity in precise amounts. To test capacitors with a multimeter, set the above 10K and 1M ohmmeters in the high ohm reading range. Touch the meter leads to the corresponding leads on the capacitor, red for positive and black for negative. The meter should start at zero and move slowly towards infinity.
The tops of the burned-out capacitors will be curved slightly outward into a convex shape, rather than flat or slightly indented like a functioning capacitor. In general, capacitors sound a bit dull bass.
Why TV capacitor damaged and how to repair it?​
We can choose to replace the capacitor of the TV. Generally speaking, the specifications are the same as the original (referring to the same capacity and pressure values). It should be noted that the capacity cannot be smaller than the original, nor can it be much larger than the original.
The reason why it should not be too large is to increase the impact on certain components at startup. Sometimes the shutdown circuit is abnormal. Some machines use a bleeder circuit to shut down. Turn off the capacitor and power on when shutting down to eliminate the shutdown bright spot.
If the capacitor is replaced, some special phenomena will occur. For example, when the power is off, there is a lot of sound in the speaker. Therefore, practical factors must be considered when replacing capacitors.
On the other hand, the quality of capacitors is the most important, so when purchasing capacitors, you should choose regular manufacturers to ensure the service life of small appliances.
The above is the solution for TV capacitor damage, I hope it will help you. Finally, if you need equipment technical maintenance, it is recommended that you try to find professional maintenance technicians for help.
