Barend Ray
Active member
- 1 Specs
- 2 Which to get
In today’s video, we're diving into a showdown between two very different takes on portable television: the Sceptre E243PV-FHD HDTV and the Generic JE2612LEDWM Vehicle TV.
On one side, we have the Sceptre, a sleek and stylish 24-inch option that promises a full 1080p experience, complete with multiple HDMI and USB ports for versatile connectivity. Its pink design might attract those looking for a pop of color in their living room.
On the other side, we have the Generic JE2612LEDWM, a rugged choice designed specifically for the road. With a 12V DC power source and an integrated HDTV tuner, it's built for those who want to enjoy their favorite shows while on the move.
So, which one stands out for your viewing needs? Is it the aesthetically pleasing home setup of the Sceptre or the practical, travel-friendly design of the Generic option? Let’s break it down and see which one might just suit your lifestyle better.
First up is the Sceptre E243PV-FHD HDTV. It's a sleek little 24-inch LED with 1080P resolution, which sounds promising for picture quality. It comes with three HDMI ports and a USB port, so connecting devices should be a breeze. But, does anyone know how the sound quality holds up? Also, I wonder if the slim design might compromise durability?
Then there's the Generic JE2612LEDWM Vehicle TV. This one runs on 12V DC power, which is a plus for a vehicle setup. It has an integrated ATSC tuner, and the wide 16:9 LCD panel sounds decent. But, I’m curious about the picture quality compared to the Sceptre. Also, is the sound any good when you're bouncing around in a car?
What do you think? Any potential downsides to either that I might be missing? Your insights would really help me make a choice!
Specs
Parameter | Sceptre E243PV-FHD HDTV | Generic JE2612LEDWM Vehicle TV |
Screen Size | 23 Inches | 26 Inches |
Reference Price | $399.99 | $399 |
Model Year | - | 2018 |
Highlight | Sleek & Slim Pink 24 LED Class (23" Viewable) 1080P HDTV 3 x HDMI Port, USB Port ATSC/NTSC/Clear QAM | 12V DC Power Integrated HDTV (ATSC) Tuner High-performance wide 16:9 LCD panel |
Internet Applications | Browser | YouTube, Browser |
Controller Type | Remote Control | Remote Control |
Aspect Ratio | 16:9 | 16:9 |
Display Technology | LED | LED |
Screen Finish | flat | - |
Resolution | 1080p | 1080p |
Refresh Rate | 60 | 60 Hz |
Response Time | 5 Milliseconds | - |
Maximum Brightness | 2.5E+2 Nit | 3.5E+2 Nit |
Backlight Technology | - | LED |
Picture Enhancement | MPEG Noise Reduction, 3D Comb Filter | - |
Motion Enhancement | Yes | - |
Audio Channels | 2.0 | 2.0 |
Audio Input | USB, HDMI | RCA, HDMI |
Speaker Description | 2-channel, 6W total power output | 2x 10W speakers |
Video Encoding | H.264, H.265 (HEVC) | H.264, MPEG-2 |
Tuner Type | QAM, ATSC | NTSC ICE, PAL, ATSC |
Other Features | Flat | Flat |
D x W x H | - | 2"D x 25.2"W x 16.1"H |
Connectivity Technology | Auxiliary | HDMI |
Usb Ports | 1 | - |
HDMI Ports | 3 | 2 |
Connector Type | USB | - |
Signal Format | ATSC/NTSC/QAM, HDMI, USB | ATSC, HDMI, Composite Video |
Which to get
Hey everyone. I'm trying to decide between two TVs and could really use your thoughts.First up is the Sceptre E243PV-FHD HDTV. It's a sleek little 24-inch LED with 1080P resolution, which sounds promising for picture quality. It comes with three HDMI ports and a USB port, so connecting devices should be a breeze. But, does anyone know how the sound quality holds up? Also, I wonder if the slim design might compromise durability?
