Solution to edges of the JMGO O1 Pro projection screen appear wavy
Gabe
Wavy edges indicates that the surface of the wall for projection is not flat. Please follow the steps below to solve the problem,
1. Pair JMGO O1 Pro with the JMGO App (make sure both your smartphone and JMGO O1 Pro are connected to the same network).
2. Go to "Image Flattening" in the JMGO App.
3. Take a photo of the projection screen, hit the "Use Photo" button, and the screen will correct by itself.
sai
The uneven walls of the projection need to be used together with the screen, so that even if there are decorative paintings on the wall, it does not affect the projection.
WilliamP
yes, if you have a screen, the projection effect will be better
