Sony VPL-F650HZ and VPL-F750HZ are both powerful engineering projectors. They use laser light source and have ultra-high brightness performance. What is the difference between Sony VPL-F650HZ and VPL-F750HZ? Let's learn more about it below.
1. Different Brightness
The brightness of Sony VPL-F650HZ is 6500 lumens, while the brightness of VPL-F750HZ is as high as 8000 lumens. The high-brightness F750HZ has stronger resistance to ambient light interference, and the projected picture is brighter and clearer.
2. Different Prices
The Sony VPL-F650HZ is much cheaper than the VPL-F750HZ, and the overall price/performance ratio of the Sony VPL-F650HZ will be higher.
Apart from the above differences, the two devices are almost identical in other respects. They are basically the same in appearance, with a resolution of WUXGA, and support functions such as automatic color correction, automatic dimming, and lens shift.
Therefore, when the Sony VPL-F750HZ was iterating, it only increased the brightness of the device, and did not upgrade other aspects.
Difference between Sony VPL-F650HZ and VPL-F750HZ:
2. Different Prices
