In a world where larger screens and 4K resolution reign supreme, the Supersonic SC-2212 22-Inch HDTV challenges the notion of what we really need from a television. This compact model, with its built-in DVD player and impressive 1080p quality, begs the question: Can a smaller, seemingly outdated design still hold its own against the giants of the TV market?
As we dive into the features of this HDTV, we’ll explore whether it truly delivers a quality viewing experience worthy of your attention, or if it’s just another budget option that cuts corners. With a focus on portability and versatility, targeting those who want a TV for their RV or kitchen, the SC-2212 raises some interesting points about consumer expectations and the value of simplicity in a tech-saturated landscape.
So, let’s unpack this compact television, assess its strengths and weaknesses, and see if it’s worth your time—or if it’s best left on the shelf.
One of the biggest pros for me is the compact size—it fits perfectly in my kitchen without taking up too much space. The range of input options is impressive for a small unit, including HDMI and USB ports, which allows me to connect my devices seamlessly. The overall design is clean and modern, and I appreciate that it looks good in my kitchen setup.
Unfortunately, I can't ignore a couple of drawbacks. The sound quality leaves much to be desired, and the limited viewing angles can be a nuisance depending on where I’m seated. Additionally, I noticed a minor dead pixel, which is a disappointment but not enough to ruin my experience. Lastly, the warranty terms are a bit concerning; it feels like a gamble if something goes wrong after the initial period.
Overall, I’m quite happy with my purchase. This TV serves its purpose well, especially for a secondary kitchen unit. While it’s not perfect, the combination of decent picture quality, compact size, and built-in DVD functionality makes it a worthwhile addition to my space. I just need to keep my expectations in check regarding the sound and viewing angles. If you're looking for a small, versatile TV for a tight space, I would recommend it, but be prepared to enhance the audio experience for the best enjoyment.
Parameter | Supersonic SC-2212 HDTV |
Screen Size | 22 Inches |
Reference Price | $129.99 |
Model Year | 2020 |
Specific Uses | Home Viewing |
Built-In Media | DVD |
Highlight | ![]() ![]() ![]() ![]() ![]() |
Internet Applications | Hulu |
Remote Control | Radio Frequency |
Aspect Ratio | 16:9 |
Display Technology | LED |
Screen Finish | flat |
Has Color Screen | Yes |
Resolution | 1080p |
Refresh Rate | 480 Hz |
Response Time | 5 Milliseconds |
Viewing Angle | 90 Degrees |
Audio Channels | 5.1 |
Surround Sound | ATSC |
Audio Output | Digital |
Audio Input | USB |
Compatible Devices | HDMI-compatible devices, VGA-compatible devices, RF-compatible devices, USB-compatible devices, SD-compatible devices, PC audio-compatible devices |
Tuner Type | ATSC |
Voltage | 240 Volts |
Other Features | Flat |
Mount Standard | 100 x 100 mm |
Wireless Technology | Radio Frequency |
Usb Ports | 1 |
USB2.0 Ports | 1 |
HDMI Ports | 1 |
Connector Type | HDMI, USB |
Signal Format | Digital |
Hardware Interface | USB, HDMI, Secure Digital Card |
D x W x H | 15.35"D x 3.94"W x 11.42"H |
Item Weight | 5.9 Pounds |
Setting up my new TV was surprisingly straightforward. I appreciate a hassle-free installation, and this model delivered on that front. I simply aligned the stand, tightened a few screws, and it was ready to go. The quick setup guide was taped to the screen, which made the whole process a breeze. I was even pleased to see it powered up without any issues, connecting to my cable box smoothly.Viewing Experience
The picture quality is decent for the size, and I was pleasantly surprised by how sharp and clear it looked when viewed straight on. However, the viewing angles are a bit restrictive; if I lean to the side or look at it from below, the colors tend to wash out. It's not a deal-breaker, especially for a kitchen TV, but I had to adjust my seating to maintain a good view during movie nights.Audio Experience
Now, the sound quality is where things get a little tricky. While it’s okay for casual viewing, I can’t help but feel it lacks depth and richness. I found myself often cranking up the volume, especially when there are competing sounds in the kitchen. I’m considering investing in a small soundbar or external speakers to enhance the audio experience because I want to enjoy my shows without straining to hear dialogue over the clatter of pots and pans.Other Experience
I have to commend the built-in DVD player—it's a nice feature to have for those classic movie nights. However, I did notice that it can be a bit finicky. It took some trial and error to get the disc to load, which was slightly frustrating. I also observed that it performs better with unblemished DVDs, as it struggled with scratched ones. Still, it’s great to have this functionality without needing an additional device cluttering my space.Conclusion
Pros:One of the biggest pros for me is the compact size—it fits perfectly in my kitchen without taking up too much space. The range of input options is impressive for a small unit, including HDMI and USB ports, which allows me to connect my devices seamlessly. The overall design is clean and modern, and I appreciate that it looks good in my kitchen setup.
