SYLVOX Patio vs Pool Pro: Which Outdoor TV Better Handles Sunlight and Weather Conditions?
  1. 1 Specs
  2. 2 Which is better
When it comes to outdoor entertainment, choosing the right TV can make or break your experience. Today, we’re diving into a head-to-head comparison of the SYLVOX Patio Series Outdoor TV and the SYLVOX Pool Pro Series Outdoor TV.
On one side, the Patio Series boasts impressive specs with its 4K ultra-HD resolution and a brightness of 700 nits, designed to deliver crisp visuals while you unwind in your backyard. But is that enough to compete with the Pool Pro’s staggering 2000 nits of brightness? That’s a game-changer when it comes to visibility in direct sunlight, providing a clear picture when you’re lounging by the pool.
Both models feature an IP55 waterproof rating, but the Pool Pro is marketed for a wider range of outdoor conditions. Is it really more durable, or is it just a marketing tactic? We’ll also explore the difference in sound quality—while the Patio Series offers dual 15W speakers, can they match the immersive audio experience you get from the Pool Pro’s setup?
Join us as we break down the features, durability, and performance of these two outdoor contenders to see which one truly reigns supreme in your outdoor oasis.
Specs​
SYLVOX Patio Series Outdoor TV​
SYLVOX Pool Pro Series Outdoor TV​
43 Inches​
65 Inches​
$949​
$2999​
Model Year​
2025​
2023​
Specific Uses​
Home Viewing​
Home Viewing​
Stunning Picture Quality: Equipped with Sylvox's 5th generation high-performance LED panel, 4K ultra-HD resolution, and 700 nits of brightness, this smart TV delivers exceptional picture clarity, perfect for when you're unwinding.
Outdoor Weatherproof TVs: Featuring IP55 waterproofing, an IP66 waterproof remote, mist resistance, sunproof design, anti-glare, high brightness, and anti-scratch body. It’s easy to clean, has waterproof speakers, and operates in temperatures from 22°F to 122°F (-30°C to 50°C).
Outdoor Sound Quality: Designed for outdoor entertainment, the Patio Series Outdoor TV comes with dual 15W speakers for clear, powerful sound. Whether for backyard gatherings or daily viewing, enjoy a premium audio experience that elevates your outdoor fun.
4K UHD TV Designed for Outdoor: 4K ultra high definition picture quality gives you an immersive visual experience. Sylvox outdoor TV has an IP55 waterproof rating, which is more suitable for various outdoor environments than other TVs.
Smart TV Powered by Android: Get all the top apps and games on the APP store. Simply press the voice assistant button on your remote and control your TV with your voice. And cast your photos, videos, and music from devices to your TV easily with Chromecast built-in.
Ultra-high Brightness: The maximum brightness can reach 2000 nits, which is 6-7 times that of a home TV. You can adjust the screen brightness according to the intensity of outdoor light. Even under direct sunlight, there is no need to worry about screen radiation or unclear images.
Operating System​
Google TV​
Android​
Internet Applications​
Netflix, Hulu, Twitter, Facebook, YouTube​
Netflix, Prime Video, Hulu, Youtube and more​
Infrared​
Bluetooth​
Voice​
Aspect Ratio​
16:9​
16:9​
Display Technology​
LED, LCD​
LED​
Screen Finish​
Flat​
anti-reflective​
Has Color Screen​
Yes​
Resolution​
4K​
4K​
Refresh Rate​
60 Hz​
60 Hz​
Response Time​
8 Milliseconds​
HDR Format​
HDR10​
HDR10​
Maximum Brightness​
7E+2 Nit​
2E+3 Nit​
Backlight Technology​
LED​
Backlight Setting​
Adjustable backlight setting​
Sylvox 5th Generation LED Panel, 4K, 700 Nits​
4K UHD, HDR10​
Audio Channels​
2.0​
2.0​
Audio Output​
Stereo​
Surround​
Audio Input​
Coaxial​
USB, Optical, HDMI
Speaker Description​
Dual 15W full-range drivers with stereo audio output​
2 built-in speakers​
H.264, H.265 (HEVC), VP9​
4K UHD​
Screen Mirroring​
Miracast​
Google Cast​
Water Resistance​
Water Resistant​
[VARIOUS WIRELESS DEVICES & ATSC TUNERS]​
Cable boxes, streaming devices, gaming consoles, Blu-ray players, smartphones, tablets, computers​
Tuner Type​
ATSC​
ATSC​
Voltage​
110 Volts​
1.1E+2 Volts (AC)​
Line Voltage​
100-240 VAC 50-60 Hz​
110 VAC 60 Hz​
Flat​
Flat​
D x W x H​
3.44"D x 38.4"W x 22.63"H​
3.44"D x 57.61"W x 33.45"H​
Wi-Fi, USB​
Bluetooth Version​
5​
Wireless Technology​
Wi-Fi​
Wi-Fi​
Usb Ports​
2​
2​
HDMI Ports​
3​
3​
Audio Out Ports​
3​
Connector Type​
USB​
HDMI, USB, Ethernet, Bluetooth, Wi-Fi, Optical, 3.5mm audio output​
Signal Format​
ATSC​
HDMI, ATSC​
Which is better​
Compare​
Setting up the SYLVOX Patio Series Outdoor TV was surprisingly smooth. After unpacking, it took me about ten minutes to get everything out and ready, followed by another ten to mount it on the wall. I appreciated how straightforward the process was, especially since I was eager to enjoy it outdoors without any hassle.
Viewing Experience
The picture quality truly exceeded my expectations for an outdoor TV. It’s bright, sharp, and crystal clear, even in varying daylight conditions. I’ve used it for watching sports and movies, and the visuals are vibrant enough to keep me engaged. Although there is some glare when the sun hits it directly, I found that adjusting the angle slightly worked wonders in reducing it.
Audio Experience
While the sound quality is decent for casual viewing, I did find that it could be a bit underwhelming for more intense movie nights. It's clear enough for regular use, but I noticed that for outdoor settings, a soundbar would definitely enhance the experience. I often find myself wishing for a bit more depth and volume to match the excitement of what I'm watching.
Other Experience
My overall experience with the SYLVOX outdoor TV has been positive, but I did encounter a couple of hiccups along the way. Initially, I faced some issues with sound that would cut in and out, but customer service was incredibly responsive. They quickly arranged for a replacement, which was a relief. It’s nice to know that they stand behind their product and are there to help when you need it.
One of the standout features for me is the excellent customer service. The support team was professional and attentive, which made addressing any concerns feel easy and stress-free. Additionally, the sturdiness and construction of the TV give me confidence that it can withstand the outdoor elements without compromising quality.
On the downside, the sound could definitely use improvement, as it tends to be a bit tinny at times. Also, I noticed that the app selection is somewhat limited, which can be frustrating if you're used to a wider range of streaming options. I ended up connecting my Apple TV for a more comprehensive viewing experience.
In conclusion, the SYLVOX Patio Series Outdoor TV has been a great addition to my outdoor space. Despite some minor flaws with sound quality and app variety, the vibrant picture and fantastic customer service make it a worthwhile investment. I genuinely look forward to spending more time outside, enjoying my favorite shows and movies with friends and family. I would certainly recommend this TV to anyone looking for something reliable and enjoyable for outdoor entertainment.
When I decided to invest in the SYLVOX 43-inch Outdoor TV, I was pleasantly surprised by how easy the setup process was. Right out of the box, it felt solid and durable, which is exactly what I wanted for my outdoor space. Connecting it to my WiFi and outdoor Bluetooth speaker was a breeze, and I appreciated that many streaming services were already integrated. I remember feeling a sense of relief when everything connected seamlessly, allowing me to dive right into my favorite shows and sports without any hassle.
Viewing Experience
The picture quality of this TV has truly blown me away. It’s bright and vibrant, even in direct sunlight, which is something I had been worried about. I often found myself enjoying movies and games without straining my eyes or dealing with glare. The colors pop, and the sharpness is impressive—everything looks so lifelike. I love that I can host friends for a movie night and they can all see the screen perfectly, regardless of where they’re sitting.
Audio Experience
While the sound quality is decent, I did notice that I often had to crank up the volume to really hear the dialogue, especially when there was background noise from the outdoors. It’s something I hadn’t anticipated, but it’s manageable. I’m considering investing in a soundbar to enhance the experience a bit more, especially for the larger gatherings. Overall, I appreciate the effort that went into the audio design, but I know that an additional sound system will elevate my outdoor movie nights.
Other Experience
What truly stood out to me was the customer service experience. I had a minor issue with one of the remotes, and reaching out to their support team was a fantastic experience. The representative I spoke with was not only knowledgeable but also genuinely cared about resolving my issue. This level of customer service is rare these days, and it made me feel confident in my purchase. It’s nice to know that the company stands by their product and their customers.
There are numerous things I love about the SYLVOX Outdoor TV. The picture quality is exceptional, especially for outdoor viewing, and the build quality feels robust and reliable. The ease of setup and integration with streaming services made it user-friendly right from the start. Plus, I can't overlook the stellar customer support I received—they really went above and beyond to ensure my satisfaction, which is a huge plus for me.
Despite my overall satisfaction, there are a few drawbacks worth mentioning. The sound could definitely use improvement; it often lacks the volume needed for larger outdoor areas, which means I might have to buy a soundbar. Additionally, while it comes with some pre-installed apps, I wish there were more options to choose from directly on the TV. Having to rely on external devices for certain streaming apps can be a bit inconvenient.
In summary, I’m genuinely happy with my decision to purchase the SYLVOX 43-inch Outdoor TV. It has transformed my outdoor entertainment setup, providing a bright, clear picture that stands up to the elements. The minor sound issues and limited app selection are manageable, especially considering the excellent customer service I've experienced. Overall, I feel this TV is a worthwhile investment for anyone looking to enjoy outdoor viewing, and I would certainly recommend it to others!
manowar09
So, I just got the SYLVOX Pool Pro Series Outdoor TV, and honestly, it’s not living up to the hype. The picture isn’t as sharp as my indoor TVs, which is kind of a bummer. And the speakers? Ugh, they sound like they’re on their last legs—totally muffled. Plus, it wasn’t cheap either. Not exactly what I was hoping for!
MsPippiton1117
Yo, check it out! The SYLVOX Pool Pro Series Outdoor TV is seriously awesome. The picture quality is off the charts! Setting it up was a breeze—super easy. We hooked it up to a Roku, but the remote didn’t recognize the TV brand. No worries though, it comes with a tiny remote that’s perfect for outdoor use. Plus, the cables are all tucked away under a sealed metal panel, so everything looks neat. Honestly, I’ve got no complaints so far!
Roy_Knable
So, I grabbed the SYLVOX Patio Series Outdoor TV, and I was super pumped to set it up. But guess what? When I turned it on, all I got was a black screen. I mean, come on! It’s under a pergola, so it’s not even in direct sunlight. I tried reaching out to Sylvox support, and they promised they'd get back to me, but… crickets. Total letdown!
JavierMnS
So, I tried to be smart and snag a cheap indoor TV for our patio, thinking I could save some cash. Big mistake! It was so dim you could barely see it when the sun was out. And of course, after just two years, it up and died on me. So, I finally decided to just go for it and get a proper outdoor TV. Enter the SYLVOX Pool Pro Series. The picture quality is awesome, and it's got some pretty cool features. Plus, it’s built to withstand the elements, so fingers crossed it lasts for a long time!
MsPippiton1117
So, I got my hands on the SYLVOX Pool Pro Series Outdoor TV, and I’ve gotta say, I really like it! But here’s the kicker – I ordered it twice, and both times it showed up damaged. I thought about giving it another shot, but the price went up, so I decided to hold off. Plus, the customer service was pretty lackluster. Kinda frustrating, you know?
