TV Box or Smart-TV?
runra
Hi, a slight off-topic, but i'm absolute noob at this topic and found no other place to ask this, so .. here goes:
So i have a Smart-TV, which unfortunately lack support for a critically needed feature, so i'm weighing my options now ...
router login
I guess TV Box is a cheaper option, but what would be other important positive \ negative sides?
sasamomo
Certainly, considering a TV Box is a valid option for enhancing your Smart TV's features. Here are some important factors to consider, including both the positive and negative aspects:
Positive Aspects:
  1. Affordability: TV Boxes are generally more affordable compared to purchasing a new Smart TV.
  2. Versatility: TV Boxes come with various operating systems (Android TV, Roku, Apple TV, etc.), providing flexibility and a wide range of apps and services.
  3. Upgradeability: If your TV Box becomes outdated, it's often easier and more cost-effective to upgrade a small external device than an entire TV.
  4. Access to Apps: TV Boxes offer access to a multitude of apps, games, and streaming services, expanding your content options beyond what your TV originally supports.
  5. Portability: TV Boxes are small and portable, making them easy to move around and use with different TVs if needed.
Negative Aspects:
  1. Additional Device: You have to deal with an additional device and remote, which might be inconvenient for some users.
  2. Potential Compatibility Issues: While rare, there might be compatibility issues between the TV Box and your TV model.
  3. Setup Complexity: Setting up and configuring a TV Box might be more complex than using the built-in features of your Smart TV.
  4. Dependency on Internet Connection: For streaming services, you'll depend on a stable internet connection, and the quality of your content will be influenced by your internet speed.
  5. Limited Integration: While TV Boxes can enhance your TV's capabilities, the integration might not be as seamless as features built directly into a Smart TV.
Before making a decision, ensure the TV Box you choose is compatible with your TV model and meets your specific needs. Additionally, read reviews and consider user feedback to get insights into the performance and reliability of the TV Box you're interested in.
