ViewSonic PA503HD vs LS740W: Which Projector is Better for Education?
ViewSonic PA503HD​
ViewSonic LS740W​
Price​
$519.99
$884.99
Brightness: 4000 Lumens
Resolution: 1080p FHD
Optical Zoom: 1.1x
Vertical Keystone Adjustment: 40 degrees
Contrast Ratio: High native contrast via 0.65" DMD chip
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity: HDMI, USB Type A, compatible with most media players, PCs, Macs, and mobile devices
Brightness: 5000 Lumens
Resolution: WXGA
Lamp Life: Up to 30,000 hours
Zoom: 1.3x optical
Projection Angle: 360 degrees
Keystone Adjustment: H/V keystone and 4 corner adjustment
Auto Power: Yes
Remote Management: Compatible with Crestron, AMX, Extron, PJ Link, ATEN, ViewSonic’s vController
Side-by-Side Comparison​
ViewSonic PA503HD​
ViewSonic LS740W​
30 Inches - 300 Inches​
1 Meters - 10 Meters​
0.77 Meters - 9.98 Meters​
22000:1​
3000000:1​
Display Resolution​
1920 x 1200 Pixels​
1280 x 800 Pixels​
1280 x 800​
4000 Lumen​
5000 Lumen​
Laser​
ViewSonic SuperColor​
ViewSonic PA503HD​
ViewSonic LS740W​
240 Watts​
203 Watts​
Light Source Life​
4000 Hours​
20000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
High brightness, High native contrast ratio, Large Screen size, Easy multimedia access​
eco-friendly, Digital Keystone Correction, Lightweight, high brightness, 3d-Ready​
Connectivity​
ViewSonic PA503HD​
ViewSonic LS740W​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
HDMI, USB 2.0 Type A, 3.5mm Audio​
USB 2.0 Type A, HDMI, 3.5mm Audio​
Laptop, Television, Speaker​
Laptop, Television, Tablet, Speaker​
Measurements​
ViewSonic PA503HD​
ViewSonic LS740W​
13.3"L x 12.2"W x 4.5"H​
11.3"L x 5"W x 8.5"H​
Item Weight​
6 Pounds​
6.6 Pounds​
Product
PROS AND CONS​
ViewSonic PA503HD​
• Exceptional brightness (3600 lumens), allowing for earlier movie start times.
• Clear image quality with easy focus adjustment, providing a ‘movie theater’ experience.
• Superior build quality compared to competitors, enhancing durability and user experience.
• Compatible with Netflix audio, alleviating the need for additional workarounds.
• Longer throw distance allows for flexible setup options.
• Requires a longer projection distance (19 feet) compared to some competitors.
• Higher price point ($300) than budget options like Vankyo and QKK.
• Some users may still need to invest in additional audio equipment for optimal sound.
The ViewSonic PA503S stands out as a top-tier projector for outdoor movie nights, delivering impressive brightness and clarity that significantly improves the viewing experience. While it comes at a higher price than entry-level models, its superior performance and build quality justify the investment for those seeking a reliable and enjoyable outdoor movie setup.
ViewSonic LS740W​
Pros
• Bright and clear picture quality
• Fast performance with low noise
• Great for streaming and various uses (e.g., sports, band practice)
• Good value for the price
• Positive user experience compared to other products
Cons
• May require closer positioning in some setups
• Initial skepticism before trying the product
Overall Impression
The ViewSonic projector stands out for its impressive brightness, clarity, and versatility, making it an excellent choice for a variety of settings. Users have reported a highly satisfactory experience, particularly for streaming and presentations, with many praising its performance in comparison to other models. Overall, it offers great value and functionality for those in need of a reliable projector.
