ViewSonic PA503HD vs PS502X: A Business Comparison of Performance and Features for Your Presentation Needs
Ok_Camel
ViewSonic PA503HD​
ViewSonic PS502X​
Price​
$519.99
$494.84
Education, Business​
Brightness: 4000 Lumens
Resolution: 1080p FHD
Optical Zoom: 1.1x
Vertical Keystone Adjustment: 40 degrees
Contrast Ratio: High native
Chip Type: 0.65" DMD
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity: HDMI, USB Type A, compatible with most media players, PCs, Macs, and mobile devices
Resolution: XGA
Throw Ratio: 0.62
Projection Size: 100 inches from 4 feet (1.24 meters)
Setup: Plug & play
Lamp Life: Up to 12,000 hours in Eco mode
Connectivity: HDMI, USB, VGA, and more
Side-by-Side Comparison​
ViewSonic PA503HD​
ViewSonic PS502X​
30 Inches - 300 Inches​
60 Inches - 300 Inches​
1 Meters - 10 Meters​
2.4 Feet - 12.3 Feet​
22000:1​
15000:1​
Display Resolution​
1920 x 1200 Pixels​
1920 x 1080 Pixels​
1024 x 768​
4000 Lumen​
4000 Lumen​
DLP​
ViewSonic SuperColor​
SuperColor Technology​
ViewSonic PA503HD​
ViewSonic PS502X​
240 Watts​
240 Watts​
Light Source Life​
4000 Hours​
4000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
High brightness, High native contrast ratio, Large Screen size, Easy multimedia access​
Short Throw​
Connectivity​
ViewSonic PA503HD​
ViewSonic PS502X​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
HDMI, USB 2.0 Type A, 3.5mm Audio​
Laptop, Television, Speaker​
Measurements​
ViewSonic PA503HD​
ViewSonic PS502X​
13.3"L x 12.2"W x 4.5"H​
9.2"L x 12.2"W x 4.5"H​
Item Weight​
6 Pounds​
9 Pounds​
Product
PROS AND CONS​
ViewSonic PA503HD​
• Exceptional brightness, performs well in ambient light
• Long throw distance allows for large image sizes
• Simple and quick lamp replacement process
• Reliable performance over extended use (5640 hours)
• Good value for a budget projector
• Weak built-in speaker, requires external audio solution
• Limited connectivity options compared to other models
• Some compatibility issues with Bluetooth audio
This projector stands out for its impressive brightness, making it an excellent choice for environments with significant ambient light. While it may lack in audio quality and connectivity features, its performance in terms of image clarity and reliability makes it a top contender in the sub $300 category. If brightness is your primary concern, this projector is highly recommended for streaming and gaming in well-lit rooms.
ViewSonic PS502X​
• Great value for money, especially when compared to leading brands in the golf simulator projector category.
• Functions well for golf simulation and other applications like concerts, providing good performance.
• Durable and portable, suitable for traveling and handling during events.
• Easy to adjust keystone and image size for flexible setup.
• Capable of impressive visuals once properly configured.
• Menu settings can be confusing until familiarized.
• Brightness is only satisfactory, not exceptional.
• May experience freezing issues, potentially linked to older devices rather than the projector itself.
• Requires a significant throw distance despite being labeled as a short throw projector.
• Some users have reported serious failures (device malfunction).
The projector offers excellent value for users looking for an affordable option for golf simulation and other uses. While it has some usability quirks and potential reliability concerns, its performance and portability make it a solid choice for casual users and those needing a budget-friendly solution.
