ViewSonic PA503S vs PA503X: Which Projector Offers Better Right and Vertical Keystone Adjustment?
KeyGood5298
ViewSonic PA503S​
ViewSonic PA503X​
Price​
$315.99
$362.11
Business​
Business​
Brightness: 4000 Lumens
Resolution: SVGA
Optical Zoom: 1.1x
Keystone Correction: 40 degree vertical
Input Latency: 16ms
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity: HDMI, VGA, mini USB, compatible with media players, PCs, Macs, and mobile devices
Resolution: XGA
Optical Zoom: 1.1x
Vertical Keystone Correction: 40 degrees
Input Latency: 16ms
Connectivity: HDMI, VGA, mini USB, compatible with media players, PCs, Macs, mobile devices
Side-by-Side Comparison​
ViewSonic PA503S​
ViewSonic PA503X​
30 Inches - 300 Inches​
3.9 Feet - 43 Feet​
3.9 Feet - 43 Feet​
22000:1​
22000:1​
Display Resolution​
600 Pixels​
768 Pixels​
800 x 600​
1024 x 768​
4000 Lumen​
4000 Lumen​
DLP​
DLP​
SuperColor​
ViewSonic PA503S​
ViewSonic PA503X​
190 Watts​
190 Watts​
Light Source Life​
4500 Hours​
5000 Hours​
Mount Type​
Floor Mount​
Tabletop Mount​
Lightweight​
Ultra Short Throw​
Connectivity​
ViewSonic PA503S​
ViewSonic PA503X​
VGA, Mini USB Type B, HDMI
VGA, USB, HDMI
Hardware Connectivity​
USB, HDMI
USB, HDMI
DVD players; Blu-ray players; Amazon FireTV; AppleTV; Google Chromecast; Mac Computers; Windows Computers​
Measurements​
ViewSonic PA503S​
ViewSonic PA503X​
11.6"L x 8.6"W x 4.3"H​
11.6"L x 8.6"W x 0.2"H​
Item Weight​
5.5 Pounds​
4.85 Pounds​
Product
PROS AND CONS​
ViewSonic PA503S​
Pros
• Exceptional brightness, ideal for rooms with ambient light
• Clear image quality even at larger sizes
• Suitable for outdoor use during dusk or early evening
• Effective cooling system; fan operates quietly without overheating
• Easy setup for various activities, such as parties and gaming
Cons
• Weak built-in speakers; requires external audio solution for better sound quality
• Limited connectivity options compared to some competitors
• Longer throw distance may not be suitable for smaller rooms
• Issues with Bluetooth audio connection reported
Overall Impression
The projector stands out in the sub $300 category primarily for its impressive brightness, making it a top choice for environments with significant ambient light. While it may lack in built-in audio quality and connectivity options, its performance during events and gaming sessions, alongside a strong cooling system, makes it a solid investment for those prioritizing picture quality. Just be prepared to supplement the audio for an optimal experience.
ViewSonic PA503X​
Pros
• Amazing quality for the price
• Extremely bright, ideal for rooms with ambient light
• Clear image even at larger sizes (e.g., 110-inch screen)
• Easy lamp replacement process
• Reliable performance over 6 years without issues
• Good for streaming and gaming with HDMI connections
Cons
• Refresh rate is slower than modern equipment, noticeable in specific scenarios
• Reds may appear slightly off compared to other colors
• Weak built-in speakers; external speakers recommended
Overall Impression
This projector offers exceptional value for its price, especially for those seeking a bright and reliable option for home theater use in well-lit environments. While it has some minor drawbacks, such as color accuracy and sound quality, its performance and ease of use make it a strong contender in the budget projector market.
