ViewSonic PA503W vs LS740HD: Which Projector is Worth It for Your Home Cinema Setup?
Bellmeister
ViewSonic PA503W​
ViewSonic LS740HD​
Price​
$399.99
$967.47
Business​
Brightness: 4000 Lumens
Resolution: WXGA
Optical Zoom: 1.1x
Vertical Keystone Adjustment: 40 degrees
Input Latency: 16ms
Lamp Life: Up to 15,000 hours (SuperEco Mode)
Connectivity: HDMI, VGA, mini USB, compatible with media players, PCs, Macs, and mobile devices
Brightness: 5000 Lumens
Resolution: 1080p
Lamp Life: Up to 30,000 hours
Optical Zoom: 1.3x
Projection Angle: 360 degrees
Keystone Adjustment: H/V keystone and 4 corner adjustment
Auto Power: Yes
Remote Management: Compatible with Crestron, AMX, Extron, PJ Link, ATEN, and ViewSonic’s vController
Connectivity: HDMI and USB Type A, compatible with most media players, PCs, Macs, and mobile devices
Side-by-Side Comparison​
ViewSonic PA503W​
ViewSonic LS740HD​
30 Inches - 300 Inches​
3.28 Feet - 38.02 Feet​
1 Meters - 8 Meters​
22000:1​
3000000:1​
Display Resolution​
800 Pixels​
1920x1080 Pixels​
1280 x 800​
4000 Lumen​
5000 Lumen​
DLP​
DLP​
SuperColor​
ViewSonic PA503W​
ViewSonic LS740HD​
AVC​
200 Watts​
203 Watts​
Light Source Life​
5000 Hours​
20000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
Lightweight​
Built-In Speaker, Eco-Friendly, ultra-large screen, Long-lasting​
Connectivity​
ViewSonic PA503W​
ViewSonic LS740HD​
VGA, USB, HDMI
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
USB​
HDMI, USB 2.0 Type A, 3.5mm Audio​
Personal Computer​
Laptop, Gaming Console, Smartphone, Speaker​
Measurements​
ViewSonic PA503W​
ViewSonic LS740HD​
11.6"L x 8.6"W x 4.3"H​
11.3"L x 8.5"W x 5"H​
Item Weight​
2.2 Kilograms​
6.6 Pounds​
Product
PROS AND CONS​
ViewSonic PA503W​
• Great picture quality with clear, bright colors
• Easy to set up and mount
• Quiet operation during use
• Versatile input options for gaming consoles and other devices
• Keystone adjustment is user-friendly
• Affordable alternative for 3D viewing
• Comes with necessary accessories (power cord, remote, batteries)
• Limited to one HDMI port
• Internal speaker lacks bass and distorts at high volumes
• Menu navigation and remote control functionality could be improved
• Super Eco Mode settings reset easily, affecting bulb life
• Instructions are not detailed enough for setup
The ViewSonic PA503W projector is an excellent choice for those seeking an affordable home theater projector with solid image quality and versatility for various media types. While it has some limitations in terms of sound quality and menu functionality, the overall performance and ease of use make it a worthwhile investment for movie and gaming enthusiasts.
ViewSonic LS740HD​
• Simple installation
• Large image projection
• Sharp, clear, and bright picture quality
• No bulb to overheat or burn out
• Excellent performance for both golf simulation and movie viewing
• Almost silent operation
• Minimal warmup time due to laser technology
• Good zoom range and keystone settings
• Compact design with external power brick, which helps in cooling
• Random orange flashing glitch occurring several times a day
• No auto focus feature
• Proprietary power brick may initially seem like a negative
• Some issues with refund processing time
The LS740HD laser projector offers impressive performance with its sharp and bright image quality, making it suitable for various uses, including sports, movies, and presentations. While the projector has a significant glitch that may affect usability, its advantages like silent operation, quick setup, and compact design make it a compelling option for those seeking a reliable projector in its price range. However, potential buyers should be aware of the existing issues before making a purchase.
