Shelby_Compare
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | ViewSonic PA700X | ViewSonic PA503HD |
Price | $399.99 | $519.99 |
Recommended Uses | Education, Business | Education, Home Cinema, Business |
Highlight | Brightness: 4500 Lumens Resolution: XGA (1024x768p) Optical Zoom: 1.1x Keystone Correction: 40-degree vertical Lamp Life: Up to 12,000 hours in SuperEco Mode Connectivity: Dual HDMI, VGA, USB, compatible with most media players, PCs, Macs, and mobile devices | Brightness: 4000 Lumens Resolution: 1080p FHD Optical Zoom: 1.1x Vertical Keystone Correction: 40 degrees Contrast Ratio: High native Chip Type: 0.65" DMD Lamp Life: Up to 15,000 hours in SuperEco Mode Connectivity: HDMI, USB Type A, compatible with media players, PCs, Macs, mobile devices |
Screen Size | 30 Inches - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 1.18 Meters - 13.17 Meters | 1 Meters - 10 Meters |
Contrast Ratio | 22000:1 | 22000:1 |
Display Resolution | 1024x768 Pixels | 1920 x 1200 Pixels |
Native Resolution | 1024 x 768 | 1920 x 1080 |
Brightness | 4500 Lumen | 4000 Lumen |
Display Type | DLP | LCD |
Picture Enhancement | - | ViewSonic SuperColor |
Lamp Wattage | 240 Watts | 240 Watts |
Light Source Life | 4000 Hours | 4000 Hours |
Controller Type | Remote Control | Remote Control, Button Control |
Control Method | Touch | Remote |
Mount Type | Tabletop Mount | Ceiling Mount |
Other Features | UHP | High brightness, High native contrast ratio, Large Screen size, Easy multimedia access |
Connectivity
Connectivity Technology | USB, Ethernet, HDMI, 3.5mm Jack | USB, HDMI, 3.5mm Jack |
Hardware Connectivity | VGA, Ethernet, HDMI, USB 2.0 Type A | USB 2.0 Type A, HDMI, 3.5mm Audio |
Compatible Devices | Laptop, Tablet, Smartphone | Laptop, Television, Speaker |
Measurements
L x W x H | 9.2"L x 12.2"W x 4.5"H | 13.3"L x 12.2"W x 4.5"H |
Item Weight | 6 Pounds | 6 Pounds |
Product | PROS AND CONS |
ViewSonic PA700X | Pros • Large Screen Size: Capable of projecting a sizable image (up to 180 inches) suitable for presentations. • Brightness: Performs well in well-lit environments without needing to dim the room. • Affordability: Offers good value for the features provided, making it accessible for consumers. • Versatile Mounting Options: Supports various mounting configurations, including upside down and right side up. • User-Friendly Features: Includes keystone and white balance adjustments, as well as multiple input options. • Reliability: Viewsonic is well-regarded for producing dependable products. Cons • Inaccurate Image Size Projection: Fails to deliver the projected image size of 200 inches at the specified distance; actual size may be closer to 140 inches. • Limited Input Options: Does not support USB as a source for videos/photos, which may limit usability for some users. • Fan Issues: Reports of fan malfunction leading to automatic shutdown, indicating potential reliability concerns. • Build Quality: Feels lightweight and somewhat cheap, lacking the sturdiness of higher-end models. Overall Impression The Viewsonic PA700W projector offers an impressive combination of brightness, large image size, and affordability, making it a solid choice for conference settings and presentations. However, users should be aware of potential issues with image size accuracy and build quality. While it excels in many areas, such as versatility and reliability, some may find its limitations in input options and occasional fan problems to be significant drawbacks. |
ViewSonic PA503HD | Pros: • Superior brightness at 3600 lumens, allowing for earlier movie starts. • Excellent image quality with sharp focus and no edge softness. • Easy focus adjustment compared to competitors. • Built-in audio capabilities that support Netflix sound. • Solid build quality and reliability. • Ideal for outdoor use with a larger projection distance. Cons: • Requires a longer throw distance (19 feet) to fill a large screen. • May be pricier than entry-level competitors. • Limited portability compared to smaller projectors. Overall Impression: The ViewSonic PA503S is a standout choice for outdoor movie enthusiasts, offering remarkable brightness, clear image quality, and ease of use. While it requires a longer throw distance and comes at a higher price point than some budget options, its performance justifies the investment for an enhanced viewing experience. This projector is a solid upgrade for anyone looking to elevate their outdoor movie nights. |
