ViewSonic X2000B-4K Review: Is This Full-Feature UST Laser Projector Worth It?
KeyGood5298
First Impressions​
The X2000B pulls off a tricky balancing act: It's easy to use but offers the right adjustments needed to get the most out of what it has to offer hardware-wise. Each of the picture modes offers calibration controls. While you need a meter and software to perform a proper calibration, if you have the tools, doing so is straightforward, effective, and only takes a few minutes because you can achieve high accuracy with a basic 2-point grayscale adjustment.
ViewSonic equips this UST with a pair of HDMI 2.0 ports, one of which supports ARC. There is a stereo analog output on the X2000B that is usable as either a headphone jack or a stereo line output. With an appropriate adapter cable, the same jack can alternatively serve as a coaxial-digital output. Unfortunately, the lack of a variable audio output that tracks with the projector's volume control means you can't use it to feed an outboard subwoofer to supplement the built-in speakers. For Internet and network connections, it has both Wi-Fi and an Ethernet port.
ViewSonic X2000B-4K​
$2199.99​
Home Cinema​
Projector, power cable, remote control, Quick Start Guide,​
Highlight
Resolution: 4K UHD (3840x2160)
Brightness: 2000 lumens
Throw Ratio: 0.22 ultra short throw lens
Color Technology: Cinema SuperColor, 125% Rec. 709 wide color gamut, HDR, HLG
Audio: Built-in Dual Harman Kardon speakers, Dolby and DTS support
Setup: Warping and 4 corner adjustment for flat and curved surfaces
Streaming: Compatible with Netflix and Disney Plus (dongle not included)
Connectivity: Wi-Fi, Bluetooth, HDMI ARC, USB, supports most media players, PCs, Macs, mobile devices
65 Inches - 150 Inches​
0.08 Meters - 0.52 Feet​
3000000:1​
2160 Pixels​
3840 x 2160​
2000 lumen​
Laser​
HDR, HLG, 4K UHD​
Viewing Experience
The X2000B projector impresses with its versatility across different picture modes, allowing users to tailor their viewing experience according to personal preference and environmental conditions. Its peak brightness of 2,000 ANSI lumens shines particularly well in Movie mode while maintaining full brightness in Brightest and Gaming modes, making it suitable for various content types. The ability to switch color temperatures with minimal impact on brightness further enhances usability. Additionally, the built-in motion processing, especially when set to Low, effectively enhances image clarity without compromising the authenticity of movie content. Overall, the X2000B stands out for its adaptability and performance, making it a compelling choice for diverse viewing scenarios.
H.264 or H.265​
20000 Hours​
50 Watts​
225 watts​
Wi-Fi, USB 2.0 Type A, HDMI
Hardware Connectivity​
Ethernet, Bluetooth 4.0, HDMI, USB 2.0 Type A​
Ultra Short Throw​
22.7"L x 19.2"W x 7.4"H​
The ViewSonic UST projector features a 0.22:1 throw ratio, making it suitable for a range of screen sizes from 65 to 150 inches, which is a notable aspect of its design. This flexibility allows for proper focus across various display sizes, although the availability of compatible lenticular ALR screens is limited to 100 and 120 inches. The menu system is user-friendly, which enhances the overall experience. However, the built-in apps and streaming functionality fall short, particularly with issues related to the Netflix app and update failures. For optimal streaming of 4K content, it is advisable to utilize an external streaming device. Overall, while the projector offers versatility in screen size and a straightforward interface, its streaming capabilities are lacking, necessitating additional hardware for a complete experience.
User Feedback​
Pros
• Exceptional brightness and color performance on a black wall
• Smooth gaming experience at 4K 60Hz with PS5
• Easy configuration with height, distance, and focus adjustments
• Quiet operation (under 40dB) compared to older models
• Good sound quality from built-in speakers
• Impressive image quality, close to the rated peak lumens of 2000
Cons
• Remote control issues with inconsistent functionality
• High-pitched whine noted during operation
• Lacks true black contrast compared to higher-end OLED displays
Overall Impression
The ViewSonic X2000B delivers an exceptional viewing experience with its vibrant colors and impressive brightness, making it a strong contender for both casual use and gaming. While it has some remote control quirks and a high-pitched noise issue that might be a dealbreaker for some, its overall performance and ease of setup make it a worthy choice for those looking for a quality projector.
