Shelby_Compare
Unboxing Experience
- 1.1.1 VISULAPEX:
- 1.1.2 COOLKANGAROO:
- 1.1.3 Magcubic:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 VISULAPEX:
- 1.3.2 COOLKANGAROO:
- 1.3.3 Magcubic:
- 1.4 Features
1.5
- 1.5.1 VISULAPEX:
- 1.5.2 COOLKANGAROO:
- 1.5.3 Magcubic:
1.1
Unboxing Experience
2
- 2.1 VISULAPEX:
- 2.2 COOLKANGAROO:
- 2.3 Magcubic:
Parameter | VISULAPEX | COOLKANGAROO | Magcubic |
Picture | |||
Reference Price | $99.98 | $379.99 | $129.99 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Education, Bedroom, Ceiling, Outdoor, Home Cinema, Gaming, Camping, Backyard, Business | Education, Home Cinema, Gaming, Business |
Built-In Media | User Manual, VGA Cable, Remote, HDMI Cable, AV Cable | Projector, Projector Lens Cover, Remote Control, Warranty Card, HDMI Cable | User Manual*1, Magcubic Projector*1, Remote control*1(No Battery Included), Power cord*1 |
Highlight | 4K UHD Support - 4K and 1080P video decoding Native Resolution - 1280 x 720P Brightness - 300 ANSI lumens (15,000 lumens brightness) Contrast Ratio - 15,000:1 Audio - Built-in Hi-Fi speaker Control Method - Phone controlled, AirMouse functionality Device Support - Up to 3 devices simultaneously Screen Size - Adjustable 35”-120” Projection Distance - 1 to 3.5 meters Zoom - 50% zoom Projection Modes - Front, rear, ceiling Connectivity - Wi-Fi 6 (5G & 2.4G), Bluetooth 5.2 Signal Coverage - Up to 17 feet Lamp Lifespan - 80,000 hours Warranty - 1-month return, 3-year replacement Customization - Adjustable color temperature, brightness, sharpness, sound effects, mouse sensitivity, projection mode, wallpaper settings | Keystone Correction: 4P/4D Zoom Function: 20% Maximum Display Size: 500 inches Brightness: 1300 ANSI lumens Contrast Ratio: 25,000:1 Native Resolution: 1080P Lamp Life: 100,000+ hours Connectivity: WiFi 6, Bluetooth 5.3 (dual-mode) Inputs: HDMI, dual USB, AV, Audio Smart TV System: 2025 certified, built-in apps (Netflix, Prime Video, etc.) Warranty: 3 years Portability: Compact and lightweight | Built-in Licensed Apps: Smart TV OS, access to 1,000,000 videos, licensed apps (Netflix, Prime Video, YouTube) Resolution: Native 1080P, 4K support Brightness: 320 ANSI lumens, 10,000:1 contrast ratio Image Adjustment: Automatic vertical correction, 4-point keystone adjustment Connectivity: WiFi 6, Bluetooth 5.2, HDMI, USB ports Operating System: Whale OS, app downloading available |
Unboxing Experience
VISULAPEX:
Upon first glance, this mini projector impresses with its sleek and compact design. It’s lightweight and portable, making it easy to carry around, whether for home use or outdoor adventures. The white exterior gives it a modern aesthetic, ensuring it looks good in any setting. Its size truly lives up to the "mini" label, fitting seamlessly into a backpack and making it a perfect travel companion.COOLKANGAROO:
Upon first glance, this projector boasts a sleek and modern design that instantly appeals to tech enthusiasts and casual users alike. Its lightweight build makes it highly portable, allowing for easy transport whether you're setting it up in the living room or taking it outdoors for a movie night. The interface is user-friendly, ensuring that anyone can navigate through the various features without any hassle. Overall, the aesthetic is clean and minimalistic, which fits well in any home setup.Magcubic:
The Magcubic Smart Projector has a sleek and compact design that immediately catches the eye. Its portability is enhanced by the inclusion of a 180° adjustable stand, allowing for versatile placement in any room or outdoor setting. The device feels solid and well-constructed, making it a practical choice for both home and travel. The overall aesthetic is modern, fitting well with various décor styles while remaining unobtrusive.Display
Screen Size | 35 Inches - 220 Inches | N/A - 500 Inches | 30 Inches - 200 Inches |
Throw Distance | 3 - 7 | 1 Meters - 10 Meters | 1 Meters - 4 Meters |
Contrast Ratio | 15000:1 | 25000 | 10000:1 |
Maximum Resolution | 4096 x 2160 Pixels | 3840x2160 Pixels | 4096 x 2160 Pixels |
Native Resolution | 1280 x 720 | 4K Support, 1920 x 1080 | 1920 x 1080 |
Brightness | 300 lumen | 25000.0 lumens Lumen | 320 Lumen |
Display Type | LED | LED | LCD |
Picture Enhancement | - | Laser Hybrid Light Source, AI Image Enhancement, 4k, HDR10+ Pro | - |
Viewing Experience
VISULAPEX:
The viewing experience is generally favorable, particularly in dimly lit environments where the projector shines. While it supports up to 1080p HD resolution, it outputs at 720p, which many users find satisfactory for casual viewing of movies and shows. The built-in speakers provide decent sound quality, and when connected to external Bluetooth speakers, the audio experience is enhanced, creating a mini-theater atmosphere. However, some users have reported issues with streaming certain services, which can detract from the overall experience.COOLKANGAROO:
I must say, the viewing experience with this projector exceeded all my expectations. The 1300 ANSI brightness combined with 4K support produces a stunning and sharp picture quality, even in well-lit rooms. The colors are vibrant, and the clarity is just amazing. The projector can achieve a massive screen size of up to 500 inches, offering a truly immersive experience for both movies and gaming. The built-in Dolby Audio enhances the audio quality, eliminating the need for external speakers in smaller spaces.Magcubic:
The Magcubic Smart Projector impresses with its native 1080P resolution and 12,000 lumens, delivering vibrant colors and sharp details during viewing sessions. Its ability to stream Netflix directly from the device is a standout feature, making it convenient for binge-watching without needing additional devices. However, I’ve noticed that the picture quality can suffer when projecting from a short distance, leading to some blurriness. This projector seems to perform best when positioned straight on rather than at an angle, which can complicate setup in tight spaces.Features
Other Features | Built-In Speaker, Portable, Built-In Android 11, Bluetooth 6, Built-In Wi-Fi | Portable, 2025 Newly Android Smart TV System Built-in Apps, Built-In Cooling System,Built-in 15W 3D Speaker, Dust-Proof, 2o%-100%Zoom, 4P4D Keystone, 3-Year Warranty, 1300 Ansi Higher Lumens, 4k Resolution Native 1080P | Auto Keystone Correction, True 320ANSI, Netflix /Prime Video /YouTube Officially-Licensed, 1080P Native Full HD 4K Support |
Video Encoding | MPEG-4 | 4k | H.264, H.265 |
Lamp Wattage | - | - | 65 Watts |
LightSource Life | 100000 Hours | 100000 Hours | - |
Controller Type | Remote Control, Button Control | Remote, Button Control | Remote Control, Voice Control |
Control Method | Remote, Touch | App, Remote | Voice |
Connectivity Technology | Bluetooth, Wi-Fi, USB, Ethernet, HDMI | Wireless, Bluetooth, Wi-Fi, USB, HDMI | Bluetooth, Wi-Fi |
Compatible Devices | Laptop, Gaming Console, Smartphone, Speaker | Laptop, Television, Tablet, Smartphone, Android | Laptop/Tablet, Gaming Console, Television, Smartphone, Speaker |
Wattage | - | - | 60 watts |
Mount Type | Ceiling Mount | Ceiling Mount, Floor Mount, Tabletop Mount, Tripod Mount, Wall Mount | Front / Rear / Front Ceiling / Rear Ceiling |
L x W x H | 8.86"L x 3.54"W x 7"H | - | - |
VISULAPEX:
Setting up this projector is an absolute breeze, even for those who may not consider themselves tech-savvy. The connectivity options are plentiful, with HDMI and USB ports available, as well as built-in WiFi and Bluetooth capabilities. This allows for easy mirroring from various devices, such as smartphones and laptops. Many users have noted the simplicity of getting started, which is a significant advantage for those looking for a hassle-free experience.COOLKANGAROO:
Setting up this projector was a breeze. It comes pre-loaded with the Android operating system, allowing you to download a plethora of apps directly from the Google Play Store, including popular streaming services like Netflix and Prime Video. The WiFi and Bluetooth connectivity options are seamless, making it easy to link with other devices like smartphones and tablets. The lightweight design adds to the convenience, making it easy to relocate as needed, whether for indoor use or outdoor gatherings.Magcubic:
Setting up the projector is an overall straightforward process, aided by its user-friendly interface and the built-in App Store. The projector features an HDMI input, Bluetooth outputs, and a USB-A port for external media, making it easy to connect to various devices. Although the instructions could be clearer, the system provides on-screen guidance once powered on, simplifying the experience. However, the software can be sluggish, which detracts from the ease of navigation through the apps and menus.Conclusion
VISULAPEX:
Pros:• Cost-effective and great value for money
• Easy to set up and connect
• Compact and portable design
• Good picture quality in low light
• Built-in apps like YouTube and Netflix
• Limited to 720p output despite 1080p support
• Connectivity issues with certain streaming services
• Sound quality may not meet everyone's expectations without external speakers
• Some reports of lens issues after minimal use
In conclusion, this mini projector is an excellent investment for anyone seeking a portable entertainment solution or a handy tool for work presentations. It combines ease of use, decent image quality, and good portability at an affordable price. While there are some limitations regarding streaming capabilities and sound performance, the overwhelming positive feedback from users highlights its practicality and effectiveness for both home entertainment and outdoor fun. I would highly recommend this product to anyone looking for a budget-friendly projector that delivers solid performance.
COOLKANGAROO:
Pros:• Exceptional brightness and picture quality
• Lightweight and portable
• Easy to set up with built-in apps
• Supports wireless connections
• Affordable for the features offered
• May not compete with high-end projectors in brightness for daytime use
• Built-in speakers are adequate but not exceptional
Overall, this projector is a fantastic investment for anyone looking to enhance their home entertainment experience. It combines portability with high-quality visuals and sound, making it suitable for both casual viewing and immersive movie nights. The ability to directly stream content without additional devices is a game-changer, and the autofocus feature adds convenience to setup. I would highly recommend this projector to anyone seeking a reliable and versatile option for their home or outdoor entertainment needs.
Magcubic:
Pros:• Affordable price point, making it accessible for casual users.
• Compact and portable, ideal for travel and kids' movie nights.
• Direct streaming capabilities for Netflix and other apps without needing external devices.
• Image focus can be difficult when projecting up close, often resulting in a blurry display.
• The software and interface can feel laggy, affecting navigation efficiency.
• The fan noise can be distracting in quieter environments.
• Built-in speaker quality is average; external speakers are recommended for better sound.
The Magcubic Smart Projector emerges as a solid choice for those seeking an affordable and portable solution for casual viewing, particularly for kids or travel purposes. While it has its drawbacks, such as focusing issues at close range and a noisy fan, the device's ease of setup, built-in streaming capabilities, and decent picture quality for the price make it a worthwhile investment. If you're not overly picky about minor imperfections, this projector can provide a satisfactory viewing experience for a variety of media.
