What is the effect of XGIMI AURU and Fresnel frame curtain?
Hello everyone, has anyone used AURU with a Fresnel screen? I heard that the viewing angle of Fresnel is very small. Will there be any limitations if it is used in a larger control?
Eleanor8
Fresnel screens are known for their unique design that allows for a thinner and lighter display. However, they do have some characteristics that might affect their performance in certain scenarios:
  1. Viewing Angle:
    • You're correct that Fresnel screens often have a limited viewing angle compared to other screen types. The image may degrade or become less visible when viewed from extreme angles.
    • When used in a larger control or display setup, it's essential to consider the typical viewing positions of the audience to ensure that everyone gets a good viewing experience.
  2. Image Quality:
    • The image quality on Fresnel screens can vary based on the quality of the screen itself. Lower-quality Fresnel screens may exhibit issues like reduced brightness, hotspotting, or color shifts.
    • For critical applications, especially in professional or large-scale setups, it's recommended to invest in high-quality Fresnel screens to minimize these issues.
  3. Application Considerations:
    • Consider the specific application of AURU and whether the limitations of a Fresnel screen align with your usage scenario.
    • If the content you're displaying requires a wide viewing angle or demands high image fidelity, you might want to explore alternative screen technologies.
  4. Testing and Evaluation:
    • If possible, conduct tests or seek reviews from users who have employed AURU with Fresnel screens in similar setups. This can provide valuable insights into real-world performance.
In summary, while Fresnel screens offer advantages in terms of portability and design, their limited viewing angles can be a consideration, especially in larger control or display environments. Choosing a high-quality Fresnel screen and understanding its limitations will contribute to a better overall experience.
Leon
The viewing angle is a bit tricky, especially in larger setups. You might notice some limitations, like the sweet spot being more pronounced.
Now I use the UST screen with the latest anti-light technology,and the viewing angle is much wider than fresnel,which can be perfectly compatible with laser projector.
