Shelby_Compare
- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
TheXGIMI HORIZON Ultraisnt designed to be portable, as its decently heavy and doesnt have a battery, so it needs to be plugged in. However, the projector does have full auto keystone correction with object avoidance, so it detects if there are objects in the frame and adjusts it correspondingly. It also has autofocus, so you dont need to do manual image corrections on this projector, making it easy to set up. It has two 12W Harmon/Kardon speakers, so you won't need to worry about connecting it to a soundbar if you move it.TheXGIMI HORIZON Ultrais a dual light source projector, using both an LED lamp and lasers to create the light source. The projectors light source is rated to last for 25,000 hours. The projector doesnt do true 4k as it uses pixel shifting to create a higher resolution image. This offers better quality than 1080p but doesn't look as good as native 4k.
Parameter | XGIMI HORIZON Ultra |
Reference Price | $1499.99 |
Built-In Media | Adaptor, User Manual, Power Cord, Warranty Card, Remote |
Highlight | • Resolution: 4K • Dolby Vision: Yes • Light Technology: Dual Light (LED & Laser) • Brightness: 2300 ISO Lumens • Screen Adaption: Intelligent Screen Adaption 3.0 • Operating System: Android TV 11.0 • Color Accuracy: High • Color Gamut: Vast |
Screen Size | 40 Inches - 200 Inches |
Throw Distance | N/A - 16.66 Feet |
Brightness | 2300 Lumen |
Display Type | DLP |
Picture Enhancement | HLG, HDR10, Dolby Vision |
Viewing Experience | The XGIMI HORIZON Ultra impresses with its peak brightness and excellent brightness uniformity, making it suitable for moderately-lit rooms and capable of enhancing colors, especially in dim lighting. However, it falls short with a mediocre contrast ratio, resulting in raised blacks across all scenes. While it offers a good color gamut for SDR content, its performance with HDR content is limited due to struggles with the wider Rec. 2020 color space. Overall, the projector excels in brightness and color vibrancy but may not be ideal for dark room viewing or high-end HDR performance. |
Video Encoding | HEVC (H.265) |
Controller Type | Remote Control, Button Control |
Lamp Wattage | 12 Watts |
Wattage | 300 watts |
Connectivity Technology | Bluetooth |
Hardware Connectivity | USB, HDMI, Headphone, Bluetooth 5 |
Compatible Devices | Television, Gaming Console |
Other Features | Built-In Speaker, Auto Obstacle Avoidance, Auto Screen Alignment, Dolby Vision Intelligent Eye Protection DCI-P3 95.5% ISA 3.0 uninterrupted auto keystone, Auto Focus |
L x W x H | 10.4"L x 8.81"W x 6.69"H |
System Experience | Overall Impression: This projector offers a robust smart interface with Android TV 11, enhancing user experience through built-in casting capabilities with Chromecast and AirScreen. The inclusion of high-quality Harman/Kardon speakers provides an immersive audio experience. With two HDMI 2.1 ports, including one eARC port, along with advanced connectivity options like Bluetooth 5.2 and Wi-Fi 6, this projector is well-equipped for modern multimedia needs, making it a versatile choice for both entertainment and connectivity. |
User Feedback
Pros• Significantly brighter than older models, with a substantial increase in lumens
• Excellent image quality with crisp visuals
• User-friendly interface with WiFi connectivity eliminating the need for HDMI cables
• Effective auto focus and auto keystone features
• Compact and portable design, ideal for travel
• Loud sound output for its size
• Protective lens cover enhances longevity and aesthetics
Cons
• Brightness may not match higher-end projectors (480 ANSI lumens vs. higher models)
• Limited to budget-friendly features, which may lack advanced options found in premium models
Overall Impression
The XGIMI projector stands out as an excellent choice for those seeking an affordable and portable option without sacrificing brightness and image quality. Its user-friendly features and compact design make it particularly suitable for casual users and travelers. Highly recommended for first-time users looking for a reliable and effective projection solution.
