Xiaomi Xming Q1 Projector Review
LOVE-TVsBook
2021 Best Portable Xiaomi Xming Q1 Projector Review, One of the most attractive points of Xiaomi Xming Q1 is its portability. The cute shape of the small body can capture the hearts of many girls. For many student parties and renters parties who do not have much space in the dormitory, it is also eliminated. Nowhere to put and move onerous troubles. As far as the entry-level projector is thousands of yuan, Xiaoming Q1 is not bad at the same price. If you are just watching movies, then this product is really no problem and can meet daily life, but if you are pursuing a higher level of picture quality and sound effects , Brightness, etc., maybe this product is not so suitable for you.
Recognized as the prime choice at the first release, Xming Q1 projector turn techies' head with its exclusive WANOS AVE Technology for upgraded audio experience. Also portable for daily carry and storage. Most of all, the amazing price of Xming Q1 projector is as low as a wholesale
It is very simple to really want to improve the quality of life. A Didi meter can make your child a home theater and solve the problem of occupying the place. The family student party does not occupy space in the dormitory. If you have not used a projector before, you can. Buy a dexterous sailor with a thousand dollars of projection. The recent experience of Xming Q1 is a meta-level entry-level projection.
The overall appearance of Xming Q1 is sleek, the color is white, and the body measurements are 134 x 115 x 175mm, and the design is more compact, without the squareness of traditional projectors. The compact body can be held in one hand even by a girl. The square lens in the front is matched with a golden frame. Seeing this, the image of the little yellow man appeared in the author's mind, and the big eyes are indeed more lovely in it.
The specific size can refer to the following figure. I can hold the projection with one hand and take photos with the other.
The back of Xming Q1 integrates a power switch + expansion interface, and Xiao Ming's logo is displayed above the air outlet. The expansion port mainly includes the power switch, Type-C interface, HDMI 2.0 interface, USB2.0 interface and 3.5mm headphone jack. Although not much, it is still enough for daily use.
The screen size of Xming Q1 is 40-150 inches, and the screen can be adjusted according to the distance. The screen resolution is 1920x1080dpi, the picture is still clear in the dark, and the clarity and color saturation are at a normal level. According to the test, the best viewing distance of the projection is about 1.2 meters, this distance is also in line with the size of the living room of most families, and the eye viewing is the most comfortable.
In terms of brightness, the official release brightness is 250 ANSI lumens. In my experience, I think it is suitable for viewing in a dark environment. The viewing effect is not ideal when the light is turned on indoors, and many details are not clear, so I bought this machine There is a trade-off between bright light and viewing effects. The following is the display effect of the different pages of turning on the light and turning off the light. You can see that the overall picture is white after turning on the light, with a layer of fog, and it is obviously much better after turning off.
The color video performance is okay, the details are obvious, and the details of the dark video in the dark part are still mediocre, and the two films have a blueish color temperature.
Xming Q1 technology uses LCD technology. Compared with DLP technology, LCD technology has better colors and lower price, while DLP technology projectors will be brighter and more expensive.
Xming Q1 supports four-point keystone correction. Unfortunately, it does not support automatic keystone correction, but requires manual adjustment by the user, which is not convenient in terms of user experience. In terms of storage, 2G+8G of memory is used, which is enough without downloading a lot of software.
Summarize:
LOVE-TVsBook
In terms of projection function, Xiaoming Q1 supports Android devices, ios, mac OS, HUAWEI Cast+, Xiaomi projection, etc. There will be some delay after projection. The following is a comparison of the original mobile phone screenshots and projection screens.
LOVE-TVsBook
It is worth mentioning that Xiaoming Q1 has obtained the low blue light eye protection certification from the German Rhein Institute, which is very rare in thousands of yuan products. The projected color is soft and not dazzling, and it is also a caring guard for the user's eyes.
In terms of sound quality, Xiao Ming Q1 is equipped with two 3W speakers on both sides, supporting China's panoramic sound effect, and adopts WANOS virtual sound field technology. When watching movies, the sound quality is quite satisfactory without external speakers. However, with the addition of panoramic sound effects, some fighting screen sound effects do have an immersive feeling.
Atmos is a new and most representative cinema audio technology in recent years. It can perform three-dimensional rendering of sound objects based on video scenes to achieve dynamic sound effects and create immersive auditory effects. It can be implemented on a projector at this price. good.
