Hisense TV has always been a popular TV brand with many series and models. So How to choose the most suitable Hisense TV? Let's have a look.
1. TV hardware configuration
● CPU processor: The CPU is the TV processor, which plays a role in solving the central volume, chroma, contrast, brightness and so on of the TV. Generally speaking, TV CPUs are divided into dual-core and quad-core, and the computing power of quad-core is faster than that of dual-core. If you want to watch high-definition 4K TV or large-screen games, it is recommended to choose a quad-core processor TV.
● TV memory: memory is divided into running memory and storage memory. The larger the memory, the more programs can be opened in the background of the TV. At present, the TV memory is more than 2GB, and it is best not to buy a TV with less than 2GB. Storage memory refers to the amount of resource space that the TV can store, such as music, software, and games.
2. TV size
Many users think that the bigger the TV screen size, the better, but this is not the case. The choice of TV size also depends on the surrounding environment as well as viewing distance, budget, transportation and other factors. But generally speaking, the bigger the size, the better the eye protection.
3. Cost budget
Hisense has a wide variety of TVs and offers quite a few budget TVs. Regarding the budget, choose the best TV from the recommended Hisense models in your budget range.
4. TV picture quality
● Resolution: Resolution refers to the display resolution, that is, how many pixels the screen can display. Generally, Hisense has been divided into 4K and 8K resolutions. Under the same source, the higher the resolution, the clearer the picture will be, and of course, the price will be higher.
● Contrast: Contrast refers to the contrast in a static state. Simply put, it is the ratio between the brightest and the darkest under the test image, so that the texture and authenticity of the image can be seen.
● Color Gamut and Color Depth: Wide color gamut is the foundation of color expression, and color depth combines brightness and color quantity. Hisense's primary color quantum dot technology can make the color purity higher, the color reproduction ability will be stronger, and it is more environmentally friendly.
● Screen: Hisense TV has an exclusive floating full-screen design. Compared with the full screen, the floating screen is more prominent and comprehensive. And combined with ULED quantum dot technology and 140% quantum dot high color gamut, Hisense TV has dynamic backlight capability. Some Hisense models add ELED ultra-thin technology and have their own side-illuminated backlight, making them truly ultra-thin.
5. TV sound quality
● DTS sound effect: Dolby DTS sound effect with DTS processor effect can enhance the surround feeling.
● Dolby Atmos: Dolby Atmos brings powerful sound effects. The large volume speaker is equipped with a bass guide tube design, which can release steady bass and bring all-round stereo surround sound.
What should you look into when choosing Hisense TV?
2. TV size
Screen Size(inch) | Best Viewing Distance(m) |
30 | 0.92-1.24 |
40 | 1.22-1.66 |
45 | 1.37-1.86 |
50 | 1.53-2.06 |
55 | 1.68-2.28 |
60 | 1.83-2.48 |
65 | 1.98-2.69 |
75 | 2.29-3.10 |
3. Cost budget
5. TV sound quality
