The TV input lag problem is always a big pain for people, whether it is Samsung, LG,or Hisense. So, if you have TV input lag problem, please refer to the following solutions, these are the general methods.
1. Turn on the game mode
If your TV has game mode, you need to make sure that game mode is turned on. This is important because an off game mode can adversely affect the input performance, especially when playing games.
2. Use the latest HDMI cable
When using your TV, you should of course go back to using an HDMI cable to get the best performance rate. However, if the input is lagging, the HDMI cable may be worn or damaged. If the cables are fine, simply remove them and reinsert them to ensure a solid connection.
3. HDMI Setup
In addition to the HDMI cable, you also need to pay attention to the HDMI settings. You will need to change the HDMI input setting from Auto to HDMI 2.0, which will use the HDMI cable to its maximum capacity and promises simplified input performance.
4. Restore factory settings
If there is nothing to fix the input latency for you, there may be errors in the TV and these can be eliminated by restoring the factory settings. Restoring factory settings is the most viable option you can use to get your TV back to its original state.
For more info, refer to TV Forum.
3. HDMI Setup
