WilliamP
This article will show you 5 ways to solve USB not working on Haier TV. Sometimes you may want to play the content from your USB, but it's frustrating when it can not work, so here are solutions.
1. Check if you selected the corresponding USB channel. And try to update a U disk test.
2. Try to access another USB port on your Haier TV.
3. Change another U disk and see if it works.
4. Restart your TV.
5. Try to factory reset the TV.
4. Restart your TV.
