radiogaga
The Amazon Fire TV Stick 4K isn't big, and it looks pretty tame. That's the point of the device, which means it's plugged into the back of the TV and doesn't appear during most of its working hours. The device is plain, black, a bit chunky, with the amazon logo on top, an HDMI port in the front and a micro-usb port on the side for power. Its size may mean it won't be easy to plug into certain HDMI ports on certain TVS, but amazon has helpfully included HDMI extenders in its sales packages to overcome this problem.
There's also A USB type-a to micro-usb cable, A wall adapter for power supply, and the Alexa voice remote for controlling the Fire TV Stick 4K. If your TV has a USB port to power the Fire TV Stick 4K, you don't need a wall adapter. The device has 8GB of internal storage for applications, a quad-core 1.7ghz CPU and bluetooth 5.
The Amazon Fire TV Stick 4K interface looks great, divided into family, movies, TV shows, apps and Settings, but it's easier to find specific content through the search feature. In addition, for all titles that can be streamed in 4K or have subtitles available, the content is marked with UHD and CC tags. It's worth pointing out that most 4K games are amazon original series, but amazon Prime video also has plenty of uhd hits. You can also see other typical features on Amazon Prime Video, such as X-ray and the ability to quickly browse videos.
One big advantage of the Fire TV Stick 4K on Google Chromecast is that it works on its own, rather than as a bridge between a smartphone and a TV. The Fire TV Stick 4K is easy to set up and operate because of its remote control, or if you have one at home, it works with the Amazon Echo speaker.
The Amazon Fire TV Stick 4K is in our opinion the best streaming device on the market right now, and while some might argue that Apple TV and Apple TV 4K are better than their Amazon Cousins, the cost of these devices is much higher, and the Amazon Fire TV Stick 4K is definitely worth it.
