Android box with 64 bit OS
Christophoros
I have an android box T95 and mecool km2. I want to install the citra and athersx2 but it requiring a 64 bit run OS, the mecool and T95 run 32 bit OS. The CPU of the android box can run 64 bit OS. Can i install an 64 bit OS? And if i can how i can do it?
KL111
Did you mean that your mecool and Android T95 run 32 bit OS, but the CPU of android box T95 run 64 bit OS?
If so, you can have a try.
PLAY GAME
Download AetherSX2 and Citra from Google Play Store and then install them on your device. If they are compatible, they should run well
Christophoros
My android devices have a CPU capable of handling a 64 bit OS but the OS of them is 32 bit. Can i upgrade the OS of my android devices and make it 64 bit OS?
